YAESU FT8900 REPEATER SPLIT
HI, NEED HELP ON ABOVE RADIO, REMOVED RESITOR ACCORDING TO MODS.DK FOR EXTENDED TX. NOW MY .600 SPLIT AUTO HAS MOVED TO AMERICAN BAND. IS THERE ANY OTHER WAY TO KEEP EXTENDED TX/RX BUT WITH THE AUTO REPEATER SHIFT FOR MY COUNTRY.
THANK YOU
GREETINGS
NICO OELOFSE
ZS4N SOUTH AFRICA
Agent Aaron
  • 265 Answers
SOURCE: American PS3 in South Africa
Hey thomas952,
While they may not be region-coded, PS3 consoles and games sold within the United States are going to be NSTC compliant, instead of the PAL format used in the United Kingdom and South Africa. What this means is that in order for any game to display properly (or even operate) it must be purchased from the same region of the world as the console itself - NTSC games can only be played on NTSC consoles.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Posted on Jul 28, 2008
SOURCE: Yaesu FT 11R
figured out how to solve this, with the radio off, push and hold both up and down scan buttons, while powering the radio on. This will fix the problem.
Posted on Jan 10, 2009
  • 40 Answers
SOURCE: YAESU HAM RADIO FT270R DIAGRAM
http://www.radioamateur.eu/schemi/FT270_sch.pdf
google is your friend
Posted on Jan 23, 2009
in9876388918
  • 170 Answers
SOURCE: Can`t change mms settings since I changed countries
DEAR FRIEND,
YOU CAN GO TO MENU, MENU TO SETTINGS, SETTINGS TO CONNECTIONS, CONNECTIONS TO CONNECTION SETUP. HERE U CAN GET ANY SETTING OF ANY COUNTRY OR NETWORK SETTINGS.
ALWAYS CONFIGURE YOUR INTERNET SETTINGS FROM CONNECTION SETUP. THEN U WILL NEVER GET ANY PROBLEM NEXT TIME.
THANKS ALOT,
SANJEEV KUMAR
Posted on Jan 25, 2009
SOURCE: VW Golf 1 - Idle problem
exactly same problem on mine m8.....a good service fixed the problem.....new air filter, oil, oil filter, spark plugs, distributor cap, rotor. when i took the air filter out and looked at the air flo pipes they were clogged up with white gunk....means the engine wasnt breathing rite. i cleaned it with break cleaning fluid. i dnt no which 1 of these solved the problem....but my guess wud be the pipes
Posted on Mar 04, 2009
Need to couple Astatic D-104 mike to Yaesu FT-847 Radio
Check the wiring diagram online for both. It's a pretty simple connection setup.. Look at mods.dk for possible answers.
Feb 12, 2014 | Yaesu Radio Communications
Ft-8800r yaesu service manual
Check on Mods.dk:
mods dk Modifications for radioamateur
They have lots of manuals available - you may have to pay a nominal fee to "join".
Jan 25, 2014 | Radio Communications
My 857 receives fine, but when I key the mic it turns off. The 857 works fine on HF both receiving and transmitting.
I would have a look at the FT-857's extended service menu by holding in A, B, C buttons and pressing power button for a couple seconds. The default setttings are on the mods.dk website. Should also ensure regular menu settings are correct/appropriate. I can tell you that it is possible to change extended menu settings by getting RFI into radio. Also, although unlikely, it sounds like you could inadvertently have done a write to the radio's EEPROM, which can be determined by using a program such as Ham Radio Deluxe, a CAT cable, and procedures also posted on mods.dk website under how to open radio up for 60m, ext tx/rx, without any hardware mods. As to whether you can do all this while still mounted mobile,,,,,maybe with a laptop? Good luck, Link, WV4I....
Oct 22, 2013 | Yaesu FT-857D transceiver
Yaesu ft 416 ver a2 need reset to get extended receive
You may find detailed instructions for this on www.mods.dk
Jul 03, 2011 | Vertex FNB-27SM,...
Yaesu FT-40R user's manual
Check on "www.mods.dk" they have a lot of manuals for download. You may have to pay for a membership, but it will be reasonably priced.
Oct 25, 2010 | Vertex FNB-40, YAESU,FT-10R,FT-40R,FT50,...
I want a manual for a yaesu vx-5
You can probably find it on www.mods.dk - you may pay a small fee, but they have manuals for most ham radios.
Sep 27, 2010 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
Service manual/parts list for yaesu ft41r or ft11r
You should be able to get the keypad from Yaesu parts: \
(714)827-7600
You may be able to download the manuals at: www.mods.dk
Sep 02, 2009 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
Hi, I need to adjust the modulationand power output on the yaesu vertex 2000 vhf radio. Can someone please tell me what vr to adjust.
You should be able to find a service manual at: www.mods.dk.
You may need to go into the "setup" menu to access the modulation settings. On some Yaesu radios, it's NOT a VR setting.
Aug 26, 2009 | Vertex Radio Communications
Yaesuft767gx cutting out on recieve and no sideband
You can find ALL of the manuals for the 767gx here at Mods - DK http://www.mods.dk/manual.php?brand=yaesu
Hope this helps!
Mar 21, 2009 | Radio Communications
Computers & Internet Logo
158 people viewed this question
David Payne
David Payne
