Question about Ovens
See through oven glass window stained
The see-through glass window is badly stained. The staining is between the outer glass and inner glass so cleaning both sides of the glass has not solved the problem. What can be done to solve this problem?
Frigidaire 24" self cleaning wall oven
  • 56 Answers
This is common its called vapor lock look for screws holding in the glass if none are found there is a rope looking seal around it take a hook or pliers and remove it the glass will come out you can clean in between it and put it back fairly easily.
Posted on Dec 30, 2008
Please tell me if Electrolux EKG5547XN Cooker Main Oven Glass Door would fit my EOB6632U
Glass oven door is not compatible.
First of all, the oven door EKG5547XN has only two glasses, inner and outer, while the oven door EOB6632U has three glasses; inner, middle and outer.
EKG5547XN
Inner glass oven door, part number: 349 00 30-01/6, silkscreened; dimension: 456 x 323 mm, tempered glass.
Front glass oven door, part number: 349 10 45-14 / 6, stainless.
EOB6632U
Inner glass oven door, part number: 899661 92 68-78 / 3,
silkscreened; dimension: 479 x 391 mm, tempered glass.
Middle glass oven door: dimension: 447 x 380 mm.
Front glass oven door: dimension: 589,5 x 466 mm.
Dado
Mar 28, 2015 | Electrolux Ovens
How to clean inside glass oven door
Taking the door off the oven and lay door on a soft surface so as to prevent scratching ,taking the door apart ( Carefully ), allow for a large work space, lay out your screws, the glass you are trying to reach is an inner glass, so obviously self clean is not going to help. Good luck!
Oct 02, 2014 | GE Profile JTP56 Electric Double Oven
Replace outer glass on oven gr440lxmc
You have to take the inner glass off first to get to the fixings for the outer glass. its normally 4-6 screws holding the frame for inner glass in place good idea to keep the parts in order for refix.
Sep 18, 2014 | Whirlpool 30" Self-Cleaning Freestanding...
How do I clean beko oven door inside panel?
Oven door glass is a "sealed" unit that accumulates stains over a period of use. It is not intended to be removed, unsealed, cleaned, resealed, and reinstalled.
Dec 28, 2013 | Ovens
White heat stains in a Broaster oven
Debruce polish works perfectly on these types of "stains". Also use on all glass surfaces: fire place glass, oven windows etc... you will be amazed. Yet not available at the retail level you will find this wonderful "green product" at debrucepolish.com
Aug 24, 2013 | Ovens
Window
The inner window should be part of the outer window. The 2 are one piece. If the inner window on the inside is dirty, then the seal has been broken or the glass is cracked. You will have to replace the entire glass or just live with it being dirty.
Feb 15, 2009 | Maytag CWE4800A Electric Single Oven
Oven window
in your manual the is a section about how to remove the oven door. after removing the outer panel is removed by a few phillips screws around perimeter, of panel perhaps 2 for handle need to be removed depending on model. not a terribly difficult task, but take time and youll be fine
Nov 06, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Burn mark
Most likely the brown stain will NOT come off, if the stain comes off the paint will come with it. Replacing the control panel is the option for making it look good again. Sorry to bring bad news.
Mar 02, 2008 | Whirlpool RBS275PD Electric Single Oven
Stain inside double glass microwave door
most microwaves have screws on the top and bottom outer lip edges. or under the rubber grommet if it has this .
but this unit should have a 10 year warranty and they may cover this issue call them
http://products.construction.com/portal/server.pt/gateway/PTARGS_0_2_493_204_249_43/http%3B/205.142.52.224/swts_content_files/15315/211253.pdf
Feb 29, 2008 | KitchenAid KEHC379 Electric Double Oven
Ovens Logo
262 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
