Question about Lexmark X5470 All-In-One InkJet Printer
Lexmark 4530 right cartridge incorrect message. unplugged unit, cleaned cartridge nothing works.
  • 1 more comment
  • Anonymous Jan 04, 2009
    I put a new catridge (24) in my 3430 and got the same message today
  • Anonymous May 13, 2009
    New lexmark 4530 24 color cartridge displays right cartidge incorrect....
  • Anonymous May 20, 2009
    I put in a new cartridge 24 today (same as before) in my X3430 Lexmark, and I;m getting a message "catridge incorrect"
  • 4 Answers
The compatible cartridges for the X4530 Lexmark printer are the # 23,23A,24,24A,31,34,35. If you have the correct cartridge number and still says cartridge incorrect, try this steps.
1. Get a damp and a dry paper towel.
2. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds. ( try this for around 5 times )
3. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean. ( try this around 5 times )
4. Next dab the cartridge on the towel to make sure that the ink is flowing.
5. Remove the power adaprtor behind the printer.
6. Using the dry paper towel, clean the metal contacts on the cartridge carrier inside the printer. ( try this 5 times )
7. Place the Cartridge back to the printer, connect the power adaptor.
8. Check if there is any error message. If same problem persist, try to contact Lexmark Technical Support.
Posted on May 29, 2009
Lexmark X5470 Right Cartridge Incorrect messagem
This article in the Lexmark website will help you identify and resolve the "right cartridge incorrect" error message: Cartridge Errors on the Lexmark X5400 Series Printers
Apr 14, 2011 | Lexmark X5470 All-In-One InkJet Printer
MESSAGE SAYS RIGHT CARTRIDGE INCORRECT
Hello there:
what this is refering to is that the cartridge is either not the right one for the printer or the device is having a problem with that cartridge i would remove the cartridge and verify that it is the right one that goes in their and also since youare having the cartridge out i would clean out the contact area to get rid of the old ink that may be sitting on the contact areas ok
best regards Michael
Nov 23, 2009 | Lexmark X5470 All-In-One InkJet Printer
Replaced black cartridge in my lexmark 3500-4500 printer. message reads "left cartridge incorrect". Have taken cartridge out and put back in numerous times still get this message.
You may have bent or broken a sensor wire. Check how the other (color) side looks by removing cartridge and confirm that nothing is awry. Otherwise, clean the metal contacts on both printer (power off and unplug) and cartridge with rubbing alchohol and a cotton swab, then try again.
Aug 18, 2009 | Office Equipment & Supplies
Right cartridge incorrect
check which cartridge is on the right side remove the cartridge and try to clean the contacts and reinsert if still shows the same message .you have to replace that particular right side cartridge.and then your printer will work properly.
Oct 04, 2008 | Lexmark Office Equipment & Supplies
Lexmark X125 keeps saying cover open change cartridge
try to make sure that the clear "ribbon" is situated correctly inside the unit, otherwise it will not communicate correctly with the moving electronics in the cartridge tray
Jan 23, 2008 | Lexmark X125 All-In-One InkJet Printer
Lexmark x5470
A Right Cartridge Incorrect message generally indicates a communication error between the All-In-One and the cartridge. This can be caused by a faulty cartridge; however, it may be due to a simple interruption in the communication between the cartridge and the All-In-One.
The procedures below will help you to identify the cause of the error and resolve the issue.
Rebricking the All-In-One and Resetting the NVRAM
NOTE: The embedded links in the table lead to specific troubleshooting documents.
Step Action 1 Power off the All-In-One and remove the power brick from the back of the unit. Wait 20 seconds. Then reinsert the brick and power the unit back on.
Did the error message return?
Yes: Continue to step 2.
No: Print a test page. If the test page prints, the error is resolved.
2 Reset the NVRAM of the All-In-One
Yes: Continue to Checking the Cartridges.
Step Action 1 Open the top cover of the All-In-One. Remove both cartridges. Close the top cover. 2 Power off the All-In-One and remove the power supply brick from the back of the unit. 3 Reinsert the power supply brick into the back of the All-In-One and power the unit back on.
Does the error message reappear?
Yes: Skip to Contacting Lexmark. There is a hardware issue with your printer and you need to contact our technical support center.
No: Continue to step 4.
4 Clean the cartridge contacts (click here for instructions) and the AIO carrier contacts (click here for instructions). Continue to step 5.
5 Power the AIO on, reinsert the black/photo cartridge, and close the top cover. Power the All-In-One off and then back on.
Yes: Power the unit off and try step 5 with another black/photo cartridge. If the error persists with the new cartridge, proceed to Contacting Lexmark.
No: Continue to step 6.
6 Power the AIO on, reinsert the color cartridge, and close the top cover. Power the All-In-One off and then back on.
Yes: Power the unit off and try step 6 with another color cartridge. If the error persists with the new cartridge, proceed to Contacting Lexmark.
No: Try printing a test page. If the test page prints, the error is resolved
Nov 11, 2007 | Lexmark X5470 All-In-One InkJet Printer
"cartridge incorrect" message
Never throw out any receipts!!! A lesson my dear mum taught me a long time ago. You need to pay attention to what the printer is telling you. Incorrect cartridge error message could mean a clogged printhead, most people think they have cleaned properly but did you do it with proper cleaning solution. Was it a refilled cartridge or new one? Are you certain you did not accidentally touch the gold areas (printer points) as this can put oils and dirt or residue on the cartidge. Gently wipe both heads on cartridge very softly with a non perfumed baby wipe! Yes a baby wipe (people laugh at me until they see their printer go again!!!) Now try printing again. You can get rid of error message only when you fix the problem. If nothing helps, try uninstalling the printer and reinstalling with original operating disc. And yes, the printer cartridges can be faulty. Never dispose of your old receipts until you are virtually replacing the next cartridge. I keep all receipts for all costly items in a clear slip folder, or staple to original barcodes of box they came in. Did you try disconnecting usb cables to printer and reconnecting to reset it.
Aug 11, 2007 | Lexmark MFP-X3470 All-In-One InkJet...
This solution (RESET the BRICK - solution 1 above) worked for me!
I had a brand new out of the box Lexmark X4580 and after one or two prints I was suddenly getting a "Left Cartridge Incorrect" error showing on the Printer Control Panel and the printer would now all me to print anything.
After about an hour of trying this and that (cartridges in, out and shalen all about!) ; no avail, I tried this and hey presto, it worked.
When I removed the "Brick" power supply I left it until the Green LED had faded right out though, I dont know if that was significant or not. Fingers crossed all is sorted now!
Mar 14, 2007 | Lexmark X7170 All-In-One InkJet Printer
Lexmark X5470 All-In-One InkJet Printer Logo
547 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
