Question about Toshiba MD13Q41 13 in. TV/DVD Combo
Does Toshiba #MD13Q41 (Man. Date Jan. 05) have Digital Tuner
Do I need to get a converter box for this tv?
4 Suggested Answers
SOURCE: dtv for 2009
The key is that you are on Directv. So the answer is no. You can't even use the converter boxes with Directv. They are only for watching programs using regular TV antennas.
FYI, based on the online manual, this model TV does NOT have an ATSC tuner built in, even though it has digital audio out. It's only NTSC.
Posted on Mar 03, 2008
  • 57 Answers
SOURCE: Does my toshiba model have a digital tuner?
Negative. Here are the specs for your TV/DVD combo: I hope this solution is helpful. Please take a moment to rate this solution.
Toshiba MD13M1 Dvd Type: DVD player - built-in
Media Type: DVD, CD, Video CD
DVD Repeat Modes: A-B repeat, title, chapter
CD Playback Modes: Program play, random play / shuffle, all tracks repeat, one track repeat
Tv tuner Analog TV Tuner: NTSC
Reception System: NTSC-M
Analog Channel Qty: 181 channel(s)
Channel Coverage: VHF:2-13, UHF:14-69, Cable:1-125
MTS Stereo: Yes
Secondary Audio Program (SAP): Yes
Video features Closed Caption Capability: Yes
Closed Captioning on Mute: Yes
Remote control Type: Remote control - infrared
Features: Back-lit buttons
Connections Connector Type:
  • 1 x headphones ( mini-phone stereo 3.5 mm ) - front
  • 1 x composite video/audio input ( RCA phono x 3 ) - front
  • 1 x SPDIF output ( RCA phono ) - rear
  • Composite video/audio input ( RCA phono x 3 ) - rear
  • 1 x antenna ( F connector ) - rear
Posted on Feb 11, 2009
  • 121 Answers
SOURCE: digital converter box won't work on toshiba md13p3 model
You can go online to the digital tv website and check your area for signal strength. All you do is punch in your area code and it will tell you if your able to get any channels. In your set up screen you can run a channel scan. Most of the time you need a good digital antennea which is something they don't tell you. I purchased one for about fifty dollars and it still don't work all that great I got a very weak signal.........So Good Luck and I hope this information was helpful to you Thank You For Using Fixya.Com! Have A Great Day! : )
Posted on Jun 17, 2009
Would like to know if my toshiba model 20AF46 will need a converter box fo receive digital signal?
Yes you will need a converter box. This television does not have a digital tuner. It does not have an atsc tuner. It does not have a qam tuner.
Sep 14, 2011 | Toshiba MD13M1 13 in. TV/DVD Combo
I bought a toshiba 36HF12 36" tv
The TV does need a converter box to receive digital off-the-air broadcasts. It's an HD set, but that doesn't mean digital; no digital tuner was built in. You can find the manual here at Toshiba. Hope this helps, and thanks for using Fixya!
Feb 18, 2010 | Toshiba 36HF12 TV
Vcr/dvd combo recording problems
You can use a normal set top box, plugged into the AV inputs on the combo, you could even use a seperate VCR for this, as long as it's recieving the signal you want to record.
Apr 21, 2009 | Toshiba SD-V295
Does this tv have a digital tuner?
no , sorry this tv is not digital ready :(
you will need a converter box or sat./cable provider
Apr 01, 2009 | Toshiba CF32F40 32" TV
Toshiba Color TV CF306 - Can it receive digital, with converter
The short answer is yes. The method is to set the TV to receive either channel 3 or 4. The converter will receive the digital broadcasts and "re-broadcast" them on either 3 or 4 analog for the TV to receive.
Let me know if you need anything else.
Mar 14, 2009 | Toshiba Televison & Video
Will I need a convertor box for Model TVM1916F
I'm sorry, but the TVM1916F is not digital. You will need a converter box if you have an antenna for your signals.
Feb 01, 2009 | Sansui TVM1916 19" TV
Is my Toshiba TV digital or analog?
if there is a label on the tv stating any of these words “Integrated Digital Tuner,” “Digital Tuner Built-In,” “Digital Receiver,” or “Digital Tuner,” “DTV,” “ATSC,” or “HDTV” then yes
if they say “Digital Monitor” or “HDTV Monitor,” or as “Digital Ready” or “HDTV Ready" then no
Jan 08, 2009 | Toshiba 24AF42 24" TV
Is converted box necessary for Toshiba 27D46 tv
The Toshiba 27D46 has a digital tuner, so you should be good to go when the switch to digital occurs.
Dec 18, 2008 | Toshiba 27D46 27" TV
DVD recorder with NTSC tuner
Hey Whormd,
If neither your DVD recorder nor your TV has a digital (ATSC) tuner, they will not be able to directly receive over-the-air broadcasts after the DTV conversion is completed without the assistance of a set-top converter box. Please keep in mind that the official analog broadcasting cut-off date does vary by country. In the U.S. this date is February 17th, 2009, and that Canadian TV stations have until August 31st 2011 to make the transition.
Please also note that you will need one converter box for each device with an analog tuner, in order to watch one program while recording another. One converter box would need to be connected to the DVR, while the second converter box would need to be connected to the TV itself.
For more information, I would strongly suggest checking out the FAQ sections of the official DTV websites established by the Federal Communications Commission (FCC) and the Canadian Radio/Television Telecommunications Commission (CRTC): (FCC) (CRTC)
Hope this helps you out.
Go Ahead. Use Us.
Jun 10, 2008 | Pioneer DVR225 DVD Recorder
Dtv for 2009
Feb 18, 2008 | Toshiba MW20F51 20 in. TV/VCR/DVD Combo
Toshiba MD13Q41 13 in. TV/DVD Combo Logo
43 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
