Question about JVC FS-A52 CD Shelf System
Cd player I wake up with a CD and the 2 alarms. the other day, the first alarm when on bip instead of CD and since then, the second alarm plays the CD with ups and downs, few seconds without any music and back. I changed the CD but it stays the same. I love this machine and want to keep it functionning properly. thanks for advice
5 Suggested Answers
techman
  • 3130 Answers
SOURCE: CD won't spin
Im afraid the laser is worn out, or there is a power supply problem, or the spindle motoer servo curcuit is defective. If you know how to service solid state curcuits, maybe it will be worth fixing. Im sorry to say, if you do not, then most likly the repair will exceed the cost of a new unit or come close to it. Good Luck PS please do not forget to rate this thread.
Posted on Oct 17, 2006
SOURCE: cd player opens when turned on and will not function
JVC recommends leaving the unit unplugged for 30 minutes to reseet the system - I'm trying that now, and will keep you posted!
Posted on Apr 17, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: cd player does not work
The CD spins while the laser tries to focus on the disc, and that's how it knows a CD is in. It's not detecting the disc and so the CD stops. This could be simply dirt on the laser lens, and you could try using a cotton swab to gently wipe it off. If that doesn't take care of it, the laser assembly needs to be replaced. This unit cost about $200 or more if I recall, so it might be worth getting a repair estimate. If this were a typical cheap boombox it would be better to replace it.
Posted on Dec 09, 2008
SOURCE: CD player ate a CD!!
I fixed the same issue by forcibly pulling individual trays to their open position.  I removed the casing to gain better access (tons of screws) but you can probably gain clear access to the shelfs without removing the casing if you have good needlenose plyers.  I found a stuck CD within one of shelfs, wedged WITHIN the moving components of the shelf.  It works perfectly now.
Posted on Mar 07, 2009
Ok the manual didn't tell me much I just need to find out how to work the CD player on a sylvania scr4986. Can someone help me. I'd really appreciate it.
Basic CD Operation:
1. Power the unit ON if STANDBY mode by pressing the STANDBY ON/OFF(#3).The default
mode is RADIO,so press the FUNCTION button(#8) to switch to the CD mode.
2. Open the CD door by pressing the OPEN/CLOSE door release button(#9).Inset a CD with the
label facing upwards and close the door.
3. The unit will read the disc and display the total number of tracks found on the disc on the
display
4. To begin playback press the PLAY/PAUSE/BAND button(#1).The first brack on the disc will
play.
5. To pause playback press the PLAY/PAUSE/BAND button(#1) once more.Pressing again resumes playback.
6. Press the STOP button(#2) to stop playback.
7. Use the AL 1/VOL- or AL 2/VOL+ buttons(13,14) to adjust the volume level.
Advanced CD operation
1. Press the FWD/TUN+ button to skip to the next track.Press and hold to fast forward the
current track.Release the button to resume normal playback.
2. Press the REV/TUN- button to skip to the previous track.Press and hold to fast rewind the
Random playback
1. Press and hold the SLEEP/RDM button(#15) either during playback or in STOP mode for 2
seconds and then release.You will see the letters RDM appear on the display to indicate the
RANDOM mode in active.
2. If you enable the RANDOM function in STOP mode,press the PLAY/PAUSE/BAND button
to begin playback.If you enable the function during playback the next track will begin the
random order
3. To cancel the RANDOM playback mode,press and hold the SLEEP/RDM button(#15) for 2
seconds and release again.The letters RDM will disappear from the display to indicate the
function has been cancelled.
Repeat function
1. Before or during playback press the REPEAT/PROG button(#6) to repeat a single track
indefinitely.You will see REP appear on the display when active.
2. To repeat all tracks on the disc,press the REPEAT/PROG button(#6) twice(or once more if
you have already activated the repeat once function).You will see REP on the display blinking
to indicate the repeat ALL function is active
3. To cancel any repeat modes,press the REPEAT/PROG button(#6) once more(if in repeat all
mode or twice if in repeat once mode).The letters REP will disappear from the display.
CD program playback.
NOTE:You can only program a playback sequence while the disc is in STOP mode.
1. Press and hold the REPEAT/PROG button(#6).You will see P01 appear on the display to
indicate the program function has been initiated.
2. Use the FWD/TUN+&REV/TUN- buttons to select the track you want to play in slot No 1.
3. Press the REPEAT/PROG(#6) to store the selected track in slot 1.The display will now
display P02 to indicate your selecting the track for slot 2.
4. Repeat steps 2 to 3 for every track you wish to program up to a maximum of 20 tracks. If you
try to program more than 20 tracks the display will revert back to P01 and will overwrite the
first slot again.
5. Press the PLAY/PAUSE/BAND button(#1) to begin the programmed sequence playback.
6. Should you wish to cancel the programming you can press the STOP button to resume normal
function.
Oct 08, 2018 | Sylvania Audio Players & Recorders
How do I turn off the alarm on the model #7-4837D
To silence the alarm momentarily
Press SNOOZE. The alarm will sound again when the snooze period is over.
To stop the alarm
Press ON/OFF. Then, the alarm will be on the following day at the same time.
To disable the alarm permanently
1. Press CANCEL button
2. The WAKE indicator will be flashing.
3. Press WAKE MODE button within 3 seconds
to deactivate the alarm function permanently.
http://manualzz.com/doc/2137875/ge-7-4837-clock-radio
Feb 07, 2018 | The Audio Players & Recorders
I purchased an RCA Radio/CD player, with the manual showing the numbers RP5605 and RP5605R on it. However, I cannot set the clock, alarm, etc. because everything in the manual's instructions is NOT in
To use the worry-free backup battery, get a 9V battery. Then look for the battery compartment on the bottom of the unit. Press the tab with your thumb and then lift the cover out and away. Plug in the battery and then replace the cover.
Press Wake Time once and use the forward/reverse buttons to set the alarm time. Then press Wake Mode repeatedly to toggle between the options of wake to radio, wake to CD, or wake to alarm. (Note the radio must be tuned to your desired station and a CD needs to be in the player for these to work).
The Smart Snooze means that pressing Snooze, forward, reverse, play or stop will turn off the alarm temporarily. (Pressing Off will prevent the alarm from sounding again today.)
The English version of the manual for the RP5605 clock radio is available here: http://www.voxxsupport.com/images/User%20Manuals%20-%20FAQ%27s/RP5605.pdf .
I hope this helps.
Dec 17, 2011 | RCA Audio Players & Recorders
I have the emerson smartset clock radio. model cks1702. i need the mannuel so i can set it to go off through the week
There are several SmartSet clock Radios by Emerson. Which model do you have?
It's possible that you have alarm 1 and alarm 2 both set for weekends (if a two-alarm version). For the SmartSet radio, CKD5811, that I am used to, you can change the alarm mode between Everyday, Weekdays and Weekends. Press and hold the Alarm 1 (or Alarm 2) button then press the Alarm Mode button to toggle between the modes. Then release both buttons. If you press the Alarm 1 button, you will see the current alarm mode indicated by the indicators by the day that are lit. The Alarm Mode button is between the On/Off button and the Alarm 1 and 2 buttons on the CKD5811. Make sure that you have the Wake to Radio, Wake to Buzzer or Wake to CD slide set for the alarm in question. For Wake to Radio, set your station. For Wake to CD, make sure that the CD in the unit is one that actually plays in the unit (scratches, etc). Also check the volume (although that seems like less of a concern since it does wake you on weekends).
The manual for the CKD5811 is here:
http://www.emersonradio.com/resources/owner_manuals/manual_1312917117.pdf . Additional manuals are here: http://www.emersonradio.com/owner_manuals.php . Scroll down in the drop down menu for the SmartSet manuals (clock radios all start CKD). The manuals are in alphabetical order.
I hope this helps.
Oct 29, 2011 | Emerson Smartset Clock Radio
I cant get my second alarm to be set on the alarm sound how do i get my second alarm off of radio of cd mode
products.bose.com/pdf/customer_service/owners/og_wrcd.pdf
copy and paste the above link in your internet address bar under a new tab. It is your entire manual.
Hold down ALARM SET and press ALARM MODE. The Alarm 2 indicator flashes. You now have 10 seconds to begin setting Alarm 2. Note: The Alarm 2 indicator must be flashing while setting Alarm 2 wake up time or sound. To set Alarm 2 wake up time, hold down ALARM SET and press either TUNING button
For manual copy and paste this link in your internet address bar under a new tab:
Oct 14, 2009 | Bose Wave Radio
How do you set the time and alarm on the RP5600A
Setting Clock
1. Press SET repeatedly until a clock icon
shows on the display.
2. Press REV or FWD to set the clock
time. The time decrements or
increments will follow by a faster rate
when you press and hold the buttons.
AM or PM icon will also show beside
the time.
3. Press SET when finished.
Setting Wake Time
This unit allows two wake times to be set.
1. Press SET repeatedly on the top of the
unit until you see WAKE 1 or WAKE 2
flashes on the display.
2. Press REV or FWD to set the respective
wake time. The time decrements or
3. Press SET repeatedly until you see no
WAKE 1, WAKE 2 or icon the
display.
Selecting Wake Source
You may be woken up by radio, CD or alarm.
1. If your desired wake source is radio or
CD:
• Wake by radio - select an AM or FM
station (see directions on “Radio”).
• Wake by CD - insert a CD in the CD
compartment. If you want to be
woken up by a specific track on the
CD, press and hold wake up - cd
track
on the top of the unit and at the
same time press REV or FWD to select
a desired track.
2. Set a wake time (see above direction).
3. Press WK-1 or WK-2 repeatedly at the
front of the unit to select a waking
mode. Corresponding icon lights on
the front of the unit.
- Wake 1 by alarm
- Wake 1 by radio
- Wake 1 by CD
In case of Wake 2, “2” shows at the
centre of the icons.
Sep 30, 2009 | RCA Alarm Clock w/CD Player, AM/FM Stereo...
RCA Clock Radio with CD player RP5620 How do i turn the alarm off so it will not sound at the same time every 24 hours?
1. Rotate the SELECTION KNOB to the WAKE MODE 1 or WAKE MODE 2 position.
2. Press the right or left arrow button to cycle through the wake modes until the alarm indicator on the display completely disappears.
Jan 14, 2009 | RCA Alarm Clock w/CD Player, AM/FM Stereo...
Can't set alarm
Push the center botton on the back until you see WAKE I and then by holding it dwon push the bottons on either the right ir left of that button to set the alarm.... same process for WAKE 2...just have to push the center botton again
Jan 05, 2009 | RCA Alarm Clock w/CD Player, AM/FM Stereo...
Ge 7-4901a
Push the SET WAKE/TIME button on the far right of all the buttons - it's the button closest to the CD player. Push it until the 1 or 2 show up on the display - whichever one you want to use. The push the CD player's forward button - the one with the two right-facing arrows - until the time you want to wake up shows up in the display. That's it. To turn the alarm off, push the WAKE CANCEL button, below the set wake/time button, the push the 1 or 2 button, depending on which alarm you want to turn off. The display will show OFF in the alarm you chose.
Jul 24, 2008 | GE 74801 Clock Radio
Changing between the buzz and cd setting for alarm clock
From the manual (miraculously, I still have it)...
To switch the alarm sound between buzzer, church bells, radio or CD, press MODE one time, and then press REPORT.
If CD is selected, press TUNING up (>>+) or down (-<<) to select desired wake-up track.
When alarm sounds, press ALM ON/OFF to silence alarm and reset it for the next day.
SNOOZE-BOOST
To postpone the alarm once it sounds, press SNOOZE/LIGHT. Each press of this button will add 10 minutes to the postponement time. (Pressing three times will give you a 30-minute delay).
Sep 14, 2007 | Sharper Image SI686 Clock Radio
JVC FS-A52 CD Shelf System Logo
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
shaun taylor
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
