Question about SanDisk Sansa e250 MP3 Player
Sansa e250's battery won't hold charge
CR, you recommended upgrading the firmware to solve this problem. Is this something I can do on line, or do I have to have it done at a shop for more money than I paid for it or would pay for another?
  • 8,596 Answers
The firmware upgrade is available for free from sandisk's website - go to Support - downloads - e200 series.
Posted on Jan 01, 2009
Battery won't hold charge very long
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + (REC button for Sansa e200 series) button, and reconnect the player to the computer while holding the volume + (REC button for Sansa e200 series) button in. Keep holding the volume + (REC button for Sansa e200 series) button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Dec 20, 2008 | SanDisk Sansa e250 MP3 Player
Se queda system shutdown
I would recommend that you upgrade the firmware on the device..Once the firmware is update you shouldnt have any problems..To update the firmware follow the link below
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
Please rate accordingly
Thank you
Computerrep
Apr 21, 2008 | SanDisk Sansa e250 MP3 Player
Will not hold a charge
What I would recommend you to do is to change the battery on your device and if that doesnt work go to the sandisk website to get the latest firmware upgrafe for your device..the link for the firmware upgrade is below..I hope that helps...if you have any more problems please contact me....
Thank You
Computerrep
Apr 20, 2008 | SanDisk Sansa e250 MP3 Player
Charging SanDisk Sansa
Go ahead and do this, in case the DB is corrupted:
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
Mar 28, 2008 | SanDisk Sansa e250 MP3 Player
White sreen and wouln't charge
I would recommend you to try to reset the player and then get a firmware upgrade...to reset the player you need to hold down the power buttom for 15 to 25 secs...
to get to the firmware upgrade go to
http://www.sandisk.com/Retail/Default.aspx?CatID=1532
If for some reason after you have reset the device and get the firmware upgrade your device is not working you can try to use the recovery tools...
I hope this help...
Thank you
Computerrep
**Please rate accordingly**
Jan 28, 2008 | SanDisk Sansa e250 MP3 Player
Dissapearing videos
If you were able to transfer the videos to your device and they are no tthere...I would recommend you to get the firmware upgrade..that should solve the problem you are having..
Jan 27, 2008 | SanDisk Sansa e250 MP3 Player
It keeps freezing
I would recommend you to upgrade your device firmware...that should solve the problems you are having...
Jan 03, 2008 | SanDisk Sansa e250 MP3 Player
Problem with charging
try performing recovery mode on the player then after performing recovery mode update the firmware of your player. Recovery mode is > Enable Hold Switch + Press Record Button + Menu Button
Oct 08, 2007 | SanDisk Sansa e250 MP3 Player
MY SANSA E250 JUST DOESNT START.......
try holding the menu button until it turns off then leave it off for around 30 minutes then try to power it back up. If it still wont turn on perform recovery mode and upgrade the firmwar eof the player if havent done so.
Aug 27, 2007 | SanDisk Sansa e250 MP3 Player
Sansa won't charge or load.
Plug it into the computer (the cord you would use to charge it and transfer files), and hold down the power button for at least 15 seconds. The Sansa should then begin to turn on and start charging. :)
Aug 07, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
41 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Sanath Kumar V
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
