Question about Zebra S4M Thermal Label Printer
S4m is not printing
There is a message on stripe screen : printer ready data ...
And she is not printing anything !!! Please if somebody saw some like that ....help me ok ?
  • rwarner664 Apr 24, 2009
    Data on the screen and no label comes out
Zebra s4m barcode printer ,suppose if i print 10 Labels only 2 Label come out balance 8 in memory .then printer comes pause, disply showing paper out /ribbon in/please help me....
Posted on Mar 13, 2011
    President:
  • 8,637 Answers
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 29, 2009
Is it possible to import data from excel into the labelprinter Zebra S4M?
You can print a text from XL, but you owuld have to use a page set up that is the same as the label size, through a Zebra or Seagull driver.
Feb 10, 2011 | Zebra S4M Thermal Label Printer
Loaded ribbon correctly according to Zebra S4M Quick Reference guide....but won't print anything on labels.
The ribbon has wax just on one side. So, if nothing prints on the label, first thing I'd check if the ribbon loaded with waxed side facing label.
Jan 11, 2011 | Zebra S4M Thermal Label Printer
Zebra S4M printer Alert Message: Ribbon out I'm using a thermal paper. There is no print method mode.
In the software printer driver- set it to direct thermal or no ribbon. It will override the printer setting.
Dec 09, 2010 | Zebra S4M Thermal Label Printer
How do I load/install the roller ribbon for the zebra stripe S4m printer?
If you GOOGLE "zebra s4m manual" you find a number of manuals you can download as a PDF and the instructions for loading the paper is in that manual.
Jul 12, 2010 | Zebra Stripe S400 Label Printer
I have a Z4M plus and it only prints half of the label. One half is well printed and the other half is blank. please help
Clean the print head. If half has got gummy from labels, it will not be able to print. You will need to use a solvent for the gummy adhesive... possibly Toluol... HOWEVER be very careful to keep that off ANY plastic parts.
Nov 26, 2009 | Zebra Z4Mplus Label Printer
Both green and orange lights blinking. Printer
Try deleting all ready to print documents, restarting the printer and then re-booting the computer. Somebody in there is confused.
If that doesn't work, check your documentation on how to print a test page, if it will print then the problem is which the application otherwise re-install the printer.
Oct 09, 2009 | Castelle LANpress Jr. MP (66298601-040)...
Printing on a continous teffeta label using zebra S4M zpl printer
Con un windows driver, sí imprime? Intenta reiniciar la impresora con los parametros de fabrica. La impresora tiene zpl o epl firmware?
Roberto Martinez
Jun 30, 2009 | Zebra S4M Thermal Label Printer
Zebra S4M - Print quality problems - not keeping Thermal Transfer
If you are using a windows printer driver then perhaps you have "Direct Thermal" selected in the printer preferences. The driver setting will override anything you have set in the printer. So every time you send a new print job the settings get changed to what they are in the driver.
Jun 18, 2009 | Zebra S4M Thermal Label Printer
Zebra S4M Printer doesn't print
The fact that the Data message is displayed, means it is 'seeing' something. You may be losing the command character at the beginning that would cause the machine to ignore the rest of your code. If this is the first time you have attempted to use the serial port, you may have a setting incorrectly set. You need to match your Host exactly or the data may be framed incorrectly. The old standard was to send your data 8 bits, 1 stop-bit and no parity. Try Xon-Xoff with hardware handshaking too. I hope this helps.
Apr 04, 2009 | Zebra S4M Thermal Label Printer
S4M doesn´t print
The S4M comes with either EPL or ZPL programming language installed. (installed at factory) The S600 is a ZPL only printer. Check that you have correctly specified the S4M as a ZPL printer. Print a config label to check. If it is set as an EPL printer contact your supplier and ask him to download the correct programming language. It should only take a competent engineer about ten minutes (If he knows what he is doing)
Jan 20, 2009 | Zebra S4M Thermal Label Printer
Zebra S4M Thermal Label Printer Logo
1,233 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
