Question about Alpine CDA-9851 CD Player
Broken front release fascia button. How do I fix it?
The release button on the front fascia no longer works and it will not clip into the car unit? Is it fixable? How do I fix it?
  • 56 Answers
Only thing i can think of is contact alpine and get a replacement part of find the broken clip and try to glue it stereo parts are hard to fix because the componenent are plastic usaully .
Posted on Dec 30, 2008
Remove back bumper from 2004 jeep grand cherokee
  • Raise and support vehicle.
  • Remove wheels.
  • Remove plastic push pins attaching fascia to fuel tank skid plate.
  • Remove plastic rivets attaching fascia to wheel liner.
  • Remove nuts attaching upper edge of fascia to quarter panel and wheel liner
  • Remove plastic push pins attaching fascia to liftgate opening
  • Remove screws attaching fascia to liftgate opening.
  • Remove D pillar trim and scuff plate outboard screws.
  • Remove the rearward tie down screws and the aperture trim panel.
  • Carefully peel back the rubber body sealer patch to access the retainer clips.
  • Release the forward and rearward retainer clips on both sides of the fascia.
  • Grasp forward edges of fascia and pull outward to disengage retainers attaching fascia to quarter panel
  • Separate fascia from vehicle
  • Jul 06, 2017 | Jeep Cars & Trucks
    Need to reach clock on dashboard
    IF the clock is blank, check if its getting power, try pressing both of the buttons on the clock or if it has one, should react somehow. I think you need to open up the dashboard to get to the clock.
    Oct 03, 2008 | 1992 Daihatsu Charade
    How do I replace my rear bumper on my 04 pacifica
    1. Open liftgate.
    133387935 Fig. 12
    1. Remove two push pin fasteners per side at the liftgate tower area (Fig. 12).
    2. Hoist and support vehicle with safety stands, as necessary.
    133387936 Fig. 13
    1. Disconnect the park assist wire connector under the vehicle and the push pin fasteners attaching wire harness under the vehicle (Fig. 13)
    2. Remove the four push pin fasteners attaching rear fascia to reinforcement bumper.
    3. Remove two screws (each side) attaching fascia to rear fascia bracket in the wheelhouse.
    4. Remove the screw on each side attaching the upper fascia in the tail lamp bucket area.
    5. Remove rear fascia from vehicle by lifting sides of fascia up and outboard to release from rear fascia brackets.
    6. Place fascia on a clean surface.
    133387937 Fig. 14
    1. Remove park assist sensors, if necessary (Fig. 14).
    133387938 Fig. 15
    1. Remove spring clips attaching upper and lower fascia together (Fig. 15).
    2. Using a trim stick release locking tabs and separate the upper and lower fascia.
    133387939 Fig. 16
    133387940 Fig. 17
    1. Remove move the bright chrome molding from the upper fascia (Fig. 16). Using a trim stick, starting at the out edge of the fascia release the locking tabs (Fig. 17). Grip the molding and pull outward from the fascia while releasing the locking tabs.
    2. Remove molding from fascia.
    INSTALLATION
    1. Place bright chrome molding in position on the upper fascia.
    Jan 06, 2012 | 2004 Chrysler Pacifica
    2011 Dodge Caravan. Ran into a metal wheelchair ramp rain. Drove back - dislodged - the black trim insert near the bottom of the plastic bumper cover. That black plastic thing has to be just put back on...
    Hello Bruce...here are the steps to follow per All Data.
    Release hood latch and open hood.
    Remove the headlamp assemblies.
    Hoist vehicle and support with safety stands.
    Remove the five push pin fasteners attaching bottom of fascia/air dam to radiator closure panel.
    Remove front wheels.
    Remove front wheelhouse splash shields fasteners as necessary to gain access to bolts attaching front fascia to fender.
    Remove the two bolts and two nuts attaching fascia to the front fenders (Fig. 1) and (Fig. 2).
    Disconnect fog lamp wire connectors, if necessary.
    Lower vehicle.
    Remove two bolts attaching the upper grille support to the headlamp mounting panel at each side of the grille.
    Remove bumper fascia from vehicle.
    INSTALLATION
    Position front bumper fascia on vehicle (Fig. 1) and (Fig. 2).
    Install the two bolts attaching fascia to headlamp mounting panel at each side of grille.
    Install the two bolts and two nuts attaching fascia to the front fenders. The fascia should be flush to fender.
    Install front wheelhouse splash shields fasteners.
    Install front wheels.
    Connect fog lamp wire connectors, if necessary.
    Install the five push pin fasteners attaching bottom of fascia to radiator closure panel.
    Lower the vehicle.
    Install the headlamp assemblies.
    The "push pin fasteners" are the pain you are having i believe. They push in, but to get them out you need squeeze them on the back & pull at the same time. If you happen to break a few, you can buy them in various sizes at the auto parts store. I hope this information is helpful, an owners manual will not have any info like this in it.
    Dec 02, 2011 | Cars & Trucks
    How do I remove and replace the entire head lamp?
    its pretty easy you take out the two bolts on the top i think they are 10mm heads on them, remove the push in clips across the front plastic fascia, if u break one they have them at parts house, and remove fascia. Gently but in a solid manner pull upward on lamp assembly. Almost like a little **** but be careful ur releasing a plastic retainer that goes into the fender , pull back light and unplug electrical harness. reverse procedure to install. may require a firm slap to front of assembly to reseat plastic retainer in fender
    Dec 01, 2011 | 2006 Pontiac G6
    My hazard light does not work on my 2002 honda accord and turn signals are not working either when i press the button in to turn the hazard light on it does not move its like it is stuck what do i do
    If the hazard button is stuck, turn signals wont work. If you havent done it, try wiggling the button, press it hard and release it to see if it springs back to position. If that doesnt work, try forcing it back with a precision flat screwdriver, taking care not to mar the fascia. If this doesnt work, you will ,unfortunately, have to take down the radio/ head unit fascia, where the button is installed. Look elsewhere on Fixya for instructions to disassemble an Accord dashboard fascia, it isn't easy.
    Jun 06, 2011 | 2002 Honda Accord
    Replacing headlight bulb on 2006 maxima
    Replacing Your headlight bulb seem to be easy when You look at it, but quite technical. But If You get the proper guide, I think fixing this will not be difficult for You. You will be needing these instruments to fix this(Flathead screwdriver, Phillips head screwdriver, 3/8 inch drive ratchet, 3/8 inch drive 10 mm socket, Replacement bulb(s), Shop rags or towel), then You carefully follow the steps below to fix this:
    1. Turn the steering wheel all the way in toward the engine on the side you are changing the light bulb in. For the driver's side bulb replacement, turn the steering wheel all the way to the right. For the passenger side bulb replacement, turn the steering wheel all the way to the left.
    2. Turn the ignition switch to the off position and remove the keys. Make sure the light switch is in the off position.
    3. Remove the retaining clips and screws from the front of the wheel well area, including the bottom splash shield valance underneath the front of the Maxima. The valance is attached to the wheel well and can be left intact. Use the Phillips head screwdriver for the screws and the flathead screwdriver to pop up the center post of the clips and then pry the clips out. Remove enough of the clips to gain access into the front fender cavity.
    4. Locate and turn the outer low-beam headlight cover counterclockwise to remove it. This will reveal the bulb and socket.
    5. Turn the bulb counterclockwise to remove it from the headlight assembly.
    6. Release the retaining pin (if applicable for theft deterrent package).
    7. Remove the wire harness plug from the bulb socket and then remove the bulb.
    8. Insert the new bulb into the socket without touching the glass of the bulb. Reverse the procedure to reinstall.
    But if it is the high beams bulb You want to replace, then please follow the steps below, It is the same instruments as before You will be needing to do this job.
    1. Release the hood latch if you're replacing the high beam bulb only. Then lift the hood. Locate the two 10 millimeter bolts at the top of the headlight assembly and remove them with the ratchet and the socket.
    2. Locate the four fascia retaining pins and remove them using the flathead screwdriver. This will allow flexible movement of the fascia to remove the headlight assembly.
    3. Place a shop rag or towel between the tight gap of the fascia and the bottom of the headlight assembly to prevent scratching the fascia.
    4. Maneuver the headlight assembly forward away from the front of the Maxima. There is a guide pin still retaining the assembly in place so apply equal parts of determination and gentleness to remove the assembly without scratching the lens or the fascia.
    5. Remove the headlight assembly far enough to get your hand behind it and remove the seal from the back of the high-beam headlight. Turn the seal counterclockwise to remove.
    6. Turn the bulb counterclockwise to remove from the assembly.
    7. Release the retaining pin (if applicable).
    8. Unplug the wire harness from the light bulb and remove the light bulb.
    9. Plug the new replacement bulb into the wire harness without touching the glass of the bulb.
    10. Reinstall by reversing the procedure.
    Hope this information helped. Thank You for using FixYa!!!
    Jan 15, 2011 | 2006 Nissan Maxima
    Need to replace the headlight assembly on front passenger side do i have to take off the bumper? for ponitac vibe 2003 also have dent on the area
    Yes you do. This is the steps to do that to replace the entire headlight assembly:
    Remove the front fascia.
    • Remove the front fascia extensions, if equipped.
    • Remove the front fender liners.
    • Remove the fog lamps.
    • Remove the bolts (4) from the front bumper fascia (3) at the fender.
    Remove the bolts from the front bumper fascia at the fender
  • Remove the push-in retainers (2) from the bumper fascia using J38778.
  • Remove the fascia bolts (1) from the fascia.
  • Remove the fascia from the vehicle.
  • Remove the 3 bolts which secure the composite headlamp.
    1. Remove the sidemarker bulb electrical connector.
    2. Remove the sidemarker bulb, if necessary.
    3. Remove the composite headlamp assembly from vehicle.
    To install:
    1. Install the sidemarker bulb to the composite headlamp, if removed.
    2. Connect the sidemarker bulb electrical connector.
    3. Secure the composite headlamp to the vehicle with the 3 bolts. Tighten the headlamp mounting bolts to 89 inch lbs. (10 Nm).
    4. Install the front fascia.
    5. Install the headlamp bulb to the composite headlamp, if removed.
    6. Fasten the headlamp bulb retainer clip.
    7. Install the socket to the headlamp bulb.
    8. Install the rubber cover to the composite headlamp.
    9. Aim the headlamps.
    10. Close the hood.
    Oct 12, 2010 | 2003 Pontiac Vibe
    Kenwood KDC-C717 - E-99 error
    Reset the unit ithe reset button is on the cd changer
    Dec 01, 2008 | Kenwood KDC-MP205 CD Player
    Alpine CDA-9851 CD Player Logo
    91 people viewed this question
    Top Alpine Car Audio & Video Experts
    xxxxxx xxx
    hoyzee1
    Tygh Duval
    Tygh Duval
    Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
