Computer is at least 5 years old- good condition
I think instead of calling to hardware support for this problem better you look for software support for password recovery. You need to switch the administrator to another user also you can use good and accountable password recovery software such as Stellar Phoenix windows password recovery software to reset administrator password.
That would be the best solution. As long as you can login and the account has administrator rights.
Lost Windows password:
SOURCE: Factory Reset
1 Turn on the computer.
2 When the Dell splash screen appears during the computer startup process, press and hold <Ctrl> and then press <F11>. Then, release both keys at the same time.
3 In the Dell PC Restore by Symantec window, click Restore. Alternatively, press <Tab> to highlight Restore, and then press <Enter>.
4 When a warning message appears stating that all data will be lost, click Confirm, or press <Tab> to highlight Confirm and then press <Enter>.
The Progress window will appear. Once the restore process starts, Dell PC Restore by Symantec usually takes about 8 to 10 minutes to finish.
When the restore process is complete, the following message will appear:
The system recovery process was successful.
5 Click Finish or press <Tab> to highlight Finish and then press <Enter> to restart the computer.
The software is now installed as it was when the computer was first received
SOURCE: dell dimension 4300 forgot main password
Get a motherboard manual from Dell.com.
Look for jumper 1.
remove jumper 1.
Power on.
Wait till PC powered on then power off.
Replace jumper.
this will reset ALL BIOS setting including password.
Please let me know if this helps.
SOURCE: Dell Dimension 3000 will not run OS. Cannot get into BIOS
the manufacturer defualt password is 'dell' so you can try that. Otherwise reset the cmos chip by following the instructions in your motherboard manual. The reason it will not load is that when most os's install,. they install the neccesary drivers and software for the hardware present. Moving the harrdrive will not generally work. Your best bet is to back up all the data on your old machine to dvd etc and then format the drive and complete a re-install.
SOURCE: forgot my password to my dell dimension 3000, how can I reset?
It's a large file, but you can download and burn a copy of:
http://www.ubcd4win.com/
It's a bootable cd that has a password recovery tool plus a lot of other stuff.
SOURCE: I have a dell dimension e310 and I have locked the
Dell describes an easy way how to clear the CMOS settings in their manual for the E310. You can download it here. Look at page 110 (page 112 in the pdf-file) and follow the instructions.
!!! Turn off the power and unplug it from the wall. Wait a minute or two before you open the cover (page 63, pdf page 64), so all transistors and capacitors have the time to get rid of any electricity.
If the jumper method does not work, remove the CMOS battery for 5 minutes and put it back in (page 95/96, pdf page 96/97). That will clear the settings as well.
...and remember: ESD (Electrostatic discharge) is your enemy No.1 here! Make sure not to touch any parts of the motherboard or wear an antistatic wrist strap.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
