Question about Canon PIXMA MP130 All-In-One InkJet Printer
Printing i have just refilled the ink on my printer but the light is still flashing to say that its empty. does any one know how to flush the ink through, or what to do?
  • cameo2006 Oct 13, 2008
    Message : Check ink tank. The Menu button doesn't work; only the on/off works.
    cameo2006@msn.com
    Problem Solver:
  • 6 Answers
Try this:
a) Click on the "menu" button, until you reach the 7. User Data
b) It will also say "1. Ink Volume" as it is the first option
c) Press Ok
d) Afterwards, press the + button until you reach to an option saying "Inkcount reset" and press Ok
e) I think it'll reset and tell you if you've changed or need to reset your ink volume data, click yes.
f) Im guessing it'll restart ad you won't have this problem anymore
If that doesn't work, try this
Turn your printer off then turn it back on after 2-5mins. It worked on my 3rd try, hoped it helped.
Posted on Feb 05, 2008
Empty cartridge light keeps flashing
These cartridges don't have anything internally to check for new ink. They simply work on a basis of counting pages and page coverage to estimate ink levels. As such it is perfectly normal for your printer to warn of low ink once the cartridge has been refilled.
A low ink warning in itself should not stop your printer from printing though. If it does it is likely that the light is actually indicating a problem recognising the cartridge after refilling. I would recommend cleaning the copper contacts on the front of the cartridge and checking for any messages on the connected PC or laptop for more information.
Oct 16, 2012 | HP DeskJet F380 All-In-One Printer
Lights on printer flashing -printer will not print
Flashing light signals you that your cartridge ink is empty. Sorry to know you're in trouble with your printer. Here are my suggestions: You have to buy a new genuine cartridge or you can refill ink. Be warned! Refilling ink or using a refilled ink cartridges will not work until the ink cartridge chip or ink monitor is disabled. For instructions on how to disable an ink cartridge chip, please visit [http://www.ehow.com/how_6201242_disable-ink-cartridge-chip.html] Now you can CURSE the manufacturer of your printer for making your life sucks by making it complicated the things that should be made SIMPLE and EASY. Printer or Cartridge, more or less, cost you the same. Don't you think the printer cartridges should be made simply refillable/usable unless they are broken, and we should be buying only the ink for the cartridges. It is SO ANNOYING, dude! Good luck.
May 06, 2011 | Office Equipment & Supplies
Hp deskjet 940c does not print, blank paper goes thrugh. Computer conction is right, ink ok ( not flushing lights) and clean.
Hi you need a new black ink. it may be empty or faulty.
The machine dos not measure the amount of ink in the tank it only counts the amount of squirts you have used normally its only a problem with refiled inks
if this is useful please rate me thanks Ian
Mar 08, 2011 | HP DeskJet 940c InkJet Printer
Reset. Orange light blinks several times. Then Green. Then orange several times, then... on and on. Cannot reset. All ink cartridges have ink.
count the number of orange flashes in between the green light. two flashes = out of paper, 3=paper jam, 4=empty ink tank, 6=print head not installed, 7=print head defective, 8=waste ink tank is almost full
Jun 08, 2010 | Canon i850 InkJet Photo Printer
Just changed cartridges to refills and clour and black lights flashinghowever we can still print ok. Why are the lights flashing?
The lights are flashing because you are using refilled cartridges. The printer "sees" those cartridges as empty, since it can not know that someone has refilled them. When you put in new cartridges, the lights will stop flashing.
Just ignore the lights and print!
Hope that helps!
May 19, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Unable o clean
HTML clipboardHi If your brother printer has been left unused for some time it is probably clogged? And the inbuilt cleaning facility does not help then you will probably need to buy a Magic Inkjet Flush Print Head Cleaning Kit.
Which you can find on Ebay.
http://tinyurl.com/yfx2y5k
Although it is possible to take the Brother printers apart, it is too difficult for most people.
To view what´s inside a Brother Printer click on next line...
Click again to enlarge photo.
http://magicinkjetflush.com/images/Unclog_Refill_Brother_Printers.jpg
Therefore, what we suggest is to make cleaning cartridges using the Dr.EpSUN Refill Tool...
Then use them to flush the print head (usually at the end of long tubes near to the back of the Brother printer)
*NEVER TOUCH THE WHITE star shaped PIN... under ink cartridges... because once pessed in... it cannot be used !
Also in most cases a single cleaning cartridge for black and 1 for colour is all you will need.
If you only have FULL INKS and need to make a cleaning cartridge use Dr.EpSUN Refill Tool to empty ink cart...
Save the ink in a clean glass jar or similar make cleaning cartridge then once unclogged simply use Dr.EpSUN Refill Tool
to refill with your saved ink.
How to make Brother Cleaning Cartridges
If you wish to see photos? You can also follow the procedure for Epson C80 in the Magic Inkjet Flush Manual.
Using FREE Dr.EpSUN Refill Tool.
To refill Brother inks... or if printer has been left unused and you need to unclog print head? (To make a cleaning cartridges *Fill empties with Magic Inkjet Flush instead of Ink / Then print rectangles using Magic Inkjet to FLUSH print heads once prints appear without white lines simply replace with inks and continue printing rectangles untill all Magic has been flushed out of print head.)
How to refill Empties...
1. Secure empty Brother ink cartridge UPSIDE DOWN in a vice or similar.
2. ONLY HALF fill Dr.EpSUN Refill Tool with warm Magic Inkjet Flush (or correct color Ink if refilling with ink)
3. Then Holding Dr.EpSUN Refill Tool upright... cover metal tip with a tissue and expell any trapped air until ink appears.
4. Insert metal tip into circular ink outlet hole of upturned cartridge... until black rubber makes a GOOD seal.
Holding both securely...
5. Do NOT TRY TO FILL Instead. PULL UP on the plunger of Dr.EpSUN REFILL TOOL.
6. Air will bubble up through the Magic/ink whilst escaping from cartridge creating a vacum.
7. Now... Simply allow plunger to retract and the Magic/ink will automatically refill the cartridge for you.
8. STOP filling before the Dr.EpSUN Refill Tool is empty otherwise air will entering.
9. Repeat until ink cartridge is full.
How to FLUSH a BROTHER print head.
10. Place filled cartridge into printer and you are ready to print.
Use print head cleaning to prime which will also fill the ink tubes... then....
11. Print rectangles of the problem colour(s) using test sheets (see below) to prime ink.
As found in the manual, here are the print test sheets for printing rectangles depending on colour(s) with problem.
Just choose... Yellow, Magenta, Grey Tones etc...
PRINT TEST SHEETS FOR USE WITH MAGIC INKJET FLUSH
http://magicinkjetflush.com/Ebay/Print_Test_Black.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Color.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Cyan.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Yellow.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Magenta.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Grey_Tones.jpg
Once prints appear to be normal simply replace the Magic Inkjet Flush with ink cartridges and continue printing rectangles untill flushed.
Hope it helps. If you need any further help Click Here then choose "Ask a Question"
Thanks
John P Bradley Tinteiros (Ebay)
Nov 23, 2009 | Brother DCP 115C All-In-One InkJet Printer
Printer won't print.
Hi NO it will not stop.
If you are out of ink just replace them. The printer will try to print even when empty.
You can easily refill those if you wish.
Cheers for now!
Tinteiros (Ebay)
Please come back and let me know if it fixed the problem.
PS
If your inkjet printer has been off for some time? you may need to unclog or replace the inks if clogged? But if you still have ink you can easily revive them with a Magic Inkjet Flush print head cleaning kit
May 25, 2008 | Lexmark X1150 All-In-One InkJet Printer
Flashing ink refill light
Sometimes refilling them over and over doesn't work well. Once ok...but i suggest that you buy a new cartridge. I know that they are expensive but it will help. Also take some Rubbing alchohol and a q-tip...clean inside where the cartridge sits..that will help...this is for sure a bad ink cartridge
Feb 28, 2007 | HP DeskJet 810c InkJet Printer
Canon PIXMA MP130 All-In-One InkJet Printer Logo
883 people viewed this question
old marine
old marine
