I bought a 2 GB Lexar SD microcard and my phone will not recognize it when it is in the phone .I bought a 2 GB Lexar SD microcard and my phone will not recognize it when it is in the phone .
You can't post conmments that contain an email address.
Remove it plug it correctly ,chek the card is working or not,chek the memorycard slot in pins broken, contacts de solderd, replace mmc ic,reset the phone settings,if not flashing may solve the problem.
It may have been damaged. If your card had a warranty try to get a new one. But if you put it into another device and it works, the card may have been a little dirty.
ok,
so its w580i.
have u checked the memory card seperatly. if not then check it in card reader or in other compatible mobile set. regarding camera, select phone memory for saving ur images. its a possibility of mem. card not allowing it to work properly.
regards,
Try blowing out the slot where the memory card goes. Since the cover has a tiny opening, it is quite possible that lint or dust has gotten into the slot where it goes! Good luck!
