Question about Maxtor DiamondMax Plus 40 (52049H4) 20.5 GB Hard Drive
Opened Maxtor drive
After trying many option like hitting, changing the circuit board and freezing my Maxtor 40GB drive, it simply does not want to enable within the pc BIOS. Desperately trying to copy my data from it, I opened the drive and took out the actual disk and replacing it in another opened drive, now it does not want to cycle up. Any clues or was this the last straw?
    Novelist:
    Scholar:
  • 104 Answers
Thats was dangerous move, data wise! First off you can't really expose those disk to dust or the air for a matter of fact! Disks need to be opened in a clean room!(No Dust whatsoever) Remember that the disks and the thing that reads the disk are as far apart as less than the diameter of a human hair! Secondly, did you put the disks in in the another drive of the exact model? Cause if you didn't then it not gonna work. If your data is that important, then you should take the drive to a data recovery professional but be prepared to sell a kidney to pay for it! lol! Other than that, being that you already took out the disks you can still find the EXACT model and try it in that! regards, babb
Posted on May 01, 2007
Can I put in my PC Compaq Presario SR 1610NX a Hard drive Maxtor 40GB, 3.5 ? Thanks
Desktop Specs Link Motherboard Specs Link
A. From the first link above, you already have a 80GB 7200rpm hard drive and a combo drive with no further details. you can only use two additional devices one 3.5 inch external and 5.25 inch external bays.
B. Assuming that two devices are already IDE devices, that will leave you two additional IDE and two SATA device.
1. Turn off your computer before plugging any additional device and proceed with cautuion.
2. Add the additional 40GB Maxtor IDE hard drive, you will have to mount the drive into the casing and put some screw to lock or use tool lesslock if its present. (Check the jumper if its a master or slave) if you have configured the 40GB drive as master and you're going to add additional IDE drive you have to put the jumper in slave header.
3. Now put the IDE cable to the hard drive and to the IDE2 of the mother board mount firmly. (you cannot mount the IDE cable if it is in the wrong position)
4. Next the four pin power from the power supply to the hard drive. (you cannot mount the power cable if it is in the wrong position)
5. Power On your computer and press Delete or F2 to access bios, proceed to the option boot priority select your Combo drive as first boot, next your 80GB Hard driver, press F10 save.
6. Power On your computer and check your 40GB hard drive through device manager.
7. Time to add your new hard drive through disk management, so you will be able to see your new drive from your computer. I forgot how WIN XP recognize new hard drives especially the fresh one.
Hopefully this information helps.
Feel free to ask, so I can clarify things.
Thank you for using FixYa.
Sep 05, 2011 | HP/Maxtor 40GB 3.5 IDE/ATA Hard Drive...
Board is not recognizing my 80G Maxtor drive. I
with AmiBios you may be able to get it to rediscover your drive... If that doesn't work, open the case and check your IDE and SATA connections. Sounds like you have a RAID configuration with your Promise board.
Not sure I've helped, but you have some clues to check on. Probably visiting Promise's website and looking for troubleshooting may help.
If your Maxtor drive is a SMART drive, you might be able to check to see if it indeed has failed.
Feb 08, 2010 | MSI K8T Neo-FSR Motherboard
Dead Maxtor drive
the soec of the drive will have to match up in order to get the no pcb to wrok so the heads ,sectors,cylndrs and so forth
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 23, 2009 | Maxtor DiamondMax Plus 8 40GB 7200rpm...
Open up the case
Well, since you are discarding the case, use a small flat head screw driver or something to pry the case open. Once inside, the HD will be plugged in to a circuit board and screwed in place. Unscrew it and carefuly unplug the HD from the circuit board. Then you can transfer it to another external HD housing.
Jun 19, 2008 | Maxtor OneTouch III Mini Edition (R01E100)...
Maxtor Personal Storage 3200 problems
change the driver letter. Duplication of drive letter will only show 1 of the drive.
May 15, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
5-yr old Maxtor 160GB fw/usb down
drives dead. Head crash problem.
The read head, has clattered the disk(s)
the only other option is to swap the logic boards over ( if they,re identical ) ** circuit boards on the drives**
Mike @ Compurepair.
Feb 22, 2008 | Maxtor Hard Drive
Maxtor One Touch Mini Issue
Somehow find another XP system to test your MAXTOR. I would suspect a connection problem with the docking station and/or a USB PCI card compatibility issue. PCI USB expansion cards are notorious for chipset/driver related problems.
Nov 29, 2007 | Maxtor OneTouch III Mini Edition 120GB...
Maxtor 40gb hard drive
i think it's a conflict with the two hard drives maxtor (ata) and westen dig(eide) ,.....could be wrong....maxtor 40gb....west,260gb let me know
Sep 16, 2007 | Computers & Internet
Maxtor DiamondMax Plus 40 (52049H4) 20.5 GB Hard Drive Logo
47 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Phillip Whisenant
Phillip Whisenant
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
