Refrigerator compresser get hot and is silent and both fridge and freezer do not work
Hi, compressor will switch off when it get to hot, by over load relay, by why, if your days are hot, or room temp. high, it would do that, unplug let it cool down, then replug it, see if it would start, if it does same thing, after cooling down,locate and check ,or replace capacitor for compressor, usually located near compressor, or your compressor has faulty internal windings, you should replace compressor, or you got low voltage, very commom in summer, use digital volt meter and check ref. receptacle, for precise voltage, a drop in line voltage, could damage or prevent compressor from starting, unplug ref. for 30-40mins, let compresor cool down, and make sure there's good ventilation around ref. then retry, compressor should start, if it didn't, then you shoud replace capacitor or motor overlay relay, located on compressor terminal box, remove cover, and you will see it, i know you're smart, just replace it, remove one wire from compressor terminal and next wire from wire harness, and relace, you can also check compressor winding by using ohm meter, remove wire from compressor terminal put one lead on copper tubing, and one by one, on compressor terminal, if you get a beep (continuity) compressor has a short circuit, you will have to replace, but first let it cool down,could be just another hot, low voltage day, let him cooldown first,and retry him, before you attempt any repairs. good luck.
