?HL-DT-ST DVDRAM GSA-T20N ATA device has disappeared from my laptop error code 19.I use an HP Pavilion dv6700 laptop with a 64bit OS
  • 48 Answers
Manually delete the registry entries
Important This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base:
322756 (http://support.microsoft.com/kb/322756/) How to back up and restore the registry in Windows
Log on to Windows by using an account that has administrator rights and permissions. Then, follow these steps.
Step 1: Start Registry Editor
Click Start, click Run, type regedit, and then click OK. Registry Editor starts.
Step 2: Delete the UpperFilters registry entry
1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE.
2. Expand SYSTEM, and then expand CurrentControlSet.
3. Expand Control, and then expand Class.
4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}.
5. In the right pane (topic area), click UpperFilters.
Note An UpperFilters.bak registry entry may also appear. To delete the UpperFilters registry entry, you must click UpperFilters and not UpperFilters.bak.
6. On the Edit menu, click Delete.
7. When you receive the following message, click Yes to confirm the deletion of the UpperFilters registry entry:
Are you sure you want to delete this value?
The UpperFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
Note Do not exit Registry Editor. You must have this program for the next step.
Step 3: Delete the LowerFilters registry entry
5. In the right pane (topic area), click LowerFilters.
Note An LowerFilters.bak registry entry may also appear. To delete the LowerFilters registry entry, you must click LowerFilters and not LowerFilters.bak.
7. When you receive the following message, click Yes to confirm the deletion of the LowerFilters registry entry:
The LowerFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
8. Exit Registry Editor.
Step 4: Restart the computer
If a CD recording program no longer works after you restart the computer, you must reinstall the CD recording program.
Please post back if you have any more problems or questions.
If this information is useful, please mark as helpful. Thanks.
Posted on Dec 31, 2008
HL-DT-ST DVDRAM GSA-T20L ATA Device Code 19 My
sure ...just look for the driver on your laptop site ..and reinstall it ...this should fix the problem ..if not ...restoring the OS or reinstalling it will fix it too
Sep 13, 2009 | NEC LaVie RX Notebook
Dvd driver noy found
There is a Microsoft KB article on this subject. Here is the link :
http://support.microsoft.com/kb/314060
Just follow the instructions and it may solve your problem
Jun 09, 2009 | Computers & Internet
My HL-DT-ST DVDRAM GSA ATA DEVICE CANNOT SEE IN MY
This error code is generally caused by a corrupted entry in the registry relating to your drive. Please click the link below, scroll down till you see the little repair guy and click on him. This should fix your problem, if it does don't forget to come back and rate this solution, if it doesn't, check to see if the error has changed and add a comment back here so we can look a little closer.
Hope this Helps FixYa,
Chris
May 14, 2009 | Computers & Internet
HL-DT-ST DVDRAM GSA-T20N ATA Device will not read any discs and has a error code 39. HL-DT-ST DVDRAM GSA-T20N ATA Device (code 39) will not work, any help pease? I have the same problem,,my notebook is a...
I read over the solution to the problem by deleting the lower keys in the registry,,restarted and it works fine again,,thank you.
The 1st time I tried it, there was now upper or lower keys because i had uninstalled the driver 1st.
Jan 04, 2009 | Intel Durabook V38263 Notebook
Computers & Internet Logo
168 people viewed this question
David Payne
David Payne
