Copiers Minolta ai3010 and Konica 7022 Good Morning: as stated I have a Minolta copier/printer ai3010. Thecoverage area now on both sides about 1.5 inches is very faded. Canthis just be cleaned? Is it probably the drum or another problem. TheKonica copies well, but I believe I have a printer and can not seem toactivate it. there are 3 led lights in the back unit 2 are continuouslylit and 1 blinks. LED 501 Thanks Joe in Tampa jpfarrell@ij.net
  • Joe Farrell
    Joe Farrell Jan 07, 2009
    Yes it is a Mita/Kyocera ai3010. It has about 230,000 copies
    Joe
  • dcannon898 May 11, 2010
    Can you tell me how many copies are on the ai3010? Also, are you certain this is a Minolta, and not a Mita/Kyocera?
  • 40 Answers
The Ai3010 - fading image at 200,000 copies = needs a new Optical Drum + Cleaning Blade + Main Charger Wire + Developer + Transfer Assembly.
Posted on Jan 10, 2009
Konica 7022 error F35-1
F 35-1 pertains to Abnormal Low fixing temp TH1. Try to clean the thermistor and reset the code by entering mode 25, software switch 3-1, make it zero. If the problem occur again, try to replace thermistor. Make sure that AC supply from mains is okay.
Aug 27, 2014 | Konica Minolta 7020 7022 7025 Copier Drum...
Konica 7022 26-3
Yes I stated what I recommended to do in your last post!
Jul 12, 2014 | Konica Minolta 7020 7022 7025 Copier Drum...
Error code c3905 in konica minolta bizhub 950
When C-35**,C-38** or C-39**(fusing temperature related
abnormality) occurs, be sure to repair defective parts before
setting DIPSW3-1 to 0. Setting DIPSW3-1 to 0 with defective
parts not repaired results in a fire.
Dec 21, 2013 | Konica Minolta Konica 7020 7022 7025 7030...
Konica 7040 trouble code 51-4
This 51-4 code is directly related to the write unit. It can either be a bad lazer index control board mounted externally to the side of the write unit or a bad M5 polygon motor. It is better to replace the whole write unit. Konica P# 26WA-6500.
On a side note, the 7020 write unit can be used in place of the 7022 write unit & is far less prone to failure then the 7022 write unit! 7020 write unit Konica P# 26NA-6500.
Nov 07, 2012 | Konica Minolta Copier Toner 7033/7040...
I have a Konica Minolta 7022 printer, scanner, fax, and copier machine. How do I get it to scan?
Please see this website complete manual for Konica MInolta 7022 printer I think i can help your problem
http://help.nceas.ucsb.edu/images/2/2a/Konica.pdf
Thanks
May 10, 2011 | Konica Minolta Office Equipment & Supplies
Replaced Konica 7022 toner and add toner light stays on
Remove the toner bottle carefully, pwr off and unplug the machine , then plug it in and turn it on do not put toner bottle into machine until asked for.
Jun 30, 2009 | Konica Minolta Office Equipment & Supplies
Mita/Kyocera ai3010 and Konica 7022 Tarpon SPrings, fl
Kyocera Mita Ai 3010 works well only with OEM toner. Print System has no decent drivers for XP and forget about Vista. Doc feeder needs separation rollers every 15,000 feeds. I will replaced it if needs more than $250 in parts.
Feb 14, 2009 | Konica Minolta Office Equipment & Supplies
Copier proble,s
Hi Joe in Tampa, What part of Tampa are you in? I use to live in Tampa. Are you asking about a Di-3010 or ai. If it is a Di you can most likely just clean the primary charge unit that charges the drum. I would clean & check the primary grid. If you clean it you have to remove the grid from the unit ( it has a push botton to release the tension of the grid) I would use Windex to clean it. The try to reinstall the drum unit and see how it works. It may be that the drum is worn out, but I don't know how many copies are on it. If it is a smaller desk top version you may need to change the drum cartridge. I'm not to sure what a ai-3010 is. Good Luck
Jan 01, 2009 | Office Equipment & Supplies
Konica 7030 F-34-1 code
try to change the thermistor, if u confirm both the heater lamps is working.
the fuser unit from 7022 is not compatible with the 7020 machine.
May 29, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
95 people viewed this question
jasbo
jasbo
