Question about Intel Motherboard
No display on GA 81G1000 mk motherboard
When i switch my pc on fans run no beep and display
    Novelist:
    Scholar:
  • 72 Answers
Some history would be appreciated.
Has this computer ever worked?
Have you recently added new hardware or software?
Has anything happened recently that may have caused this (lightning storm, etc.)?
If the computer was working fine and for no apparent reason now won't POST, first remove everything from the outside (keyboard, mouse, etc.) except monitor. If that works, one of the items you removed is causing a problem.
If not, unplug power, open case, remove all expansion cards except for video, then try again. If you have never worked inside a computer, some help from a knowledgeable friend would be advised. Be sure to touch the metal case before touching any circuit board inside the computer.
Also disconnect the cabling from all of the drives and then retry boot.
Let me know if this helps. If not, we can do more providing you are comfortable working inside the computer at my direction.
Honest1abe
Posted on Dec 31, 2008
I have a gigabyte p4 pc, when i power it on the fan runs but it gives out a continuous beep. checked ram, processor on another motherboard, cleaned the motherboard, checked for loose cards and cables
The continous beep usually means a memory failure (RAM) or video memory if a plugin card is used.
Check to be sure the unit sees all of the memory, a weak power source( without AC adapter) could cause a partial failure of one memory card.
Another fault would be that the battery is very low on charge and won't accept any charge.
BAD Battery.
hope it helps
May 31, 2012 | Gigabyte GA-8LD533 Motherboard
My computer has no display or beeps whatsoever after i push the power button. the CPU fan is running as well as the LED indicator.what possibly is wrong with my motherboard or cpu
you need to do many task for this simple prob:-)
>> take out the RAM and switch on the system even thought if you don't get beep then
>>>> take out the Bios battery and switch on , if here also you don't get
>>>> check the SMPS
>>>check the processor with some other board where your processor support
>>>> check your m/board with some other processor which your board support
Feb 23, 2010 | Gigabyte GA-G31M-ES2L Motherboard
Packard Bell IMedia 5055: GA-8SIML will not post or boot. Removed all PCI cards,RAM,Hard drive, optical drives etc. Only CPU and mobo but no post/BIOS screen. CPU fan runs and front panel LEDs work. Do get...
Put just the ram back into the motherboard, the pc will not boot without processor, ram and graphics pluged into the board, check this, if it will still not boot and you still get 3 beeps its a memory(ram) problem, and you will need to replace the memory stick.
Feb 04, 2010 | Gigabyte GA-8SIML Motherboard
Motherboard power on but no display.
Greetings!
Check first if all the cable, wire are connected properly.
See also at the back of your power supply if the switch is on, cause some power supply have switch aside from your system unit.
Usually once you open your computer you can hear a beep sound if their is no beep sound means something wrong with your computer.
As you turn on the computer see the fan of your power supply at the back of your unit if it revolves if not something wrong with your power supply, if the fun of your power supply re volves it's your motherboard have something wrong.
Thanks
Nov 11, 2008 | Intel D845GVSR Motherboard
No Beep No Display
Immediately change your motherboard.
Jul 03, 2008 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
Motherboard problem
If your cpu fan is faster,it may be due to a higher frequency setting.
The frequency that it runs best at is 60 hz, but it can be running at 70 hz or higher.
Jun 14, 2008 | ASUS P4P800-X Pentium Motherboard
Problem with GA 8LD533
There are a few easy fixes for this, first,
Clear the CMOS (Unplug the power cord, remove the battery, and (if it's an option) move the jumper J1 (it has three pins, the jumper covers two, move it to cover the other one), unplug everything external from the motherboard apart from the PSU and power switch and speaker, replace battery, powercord, and jp1, power up - what happens?
Nov 19, 2007 | Gigabyte GA-8LD533(-P) microATX...
Intel Motherboard Logo
306 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
