Question about Dell PowerEdge 4400 Server
I need to get to the configuration utility
Usually when I configure the nic/ip address on other dell servers at my company I usually get a startup screen with various control prompts. It's either a contrl/E or cntrl/D but in this case I only get a cntrl/a scsi config or cntrl/m - which gives me the config utility for rebuilding the disks. i don't get a cntrl/e or cntrl/d - why ?
  • paulo2 May 11, 2010
    Normally control/e control/d is working?
    Have you tried with another keyboard?
    All disks are working fine in the server, no one needs to be replaced?
  • 59 Answers
These menus are for SCSI/SAS controllers. If your server doesnt have a SCSI/SAS controller installed, or if it is disabled then you would not receive these prompts.
Posted on Jan 03, 2010
My server has 2 NIC one of them connected to the router (ISP) and one of them is connected to the LAN.But DHCP and DNS working but there is no internet to the Host and also the server itself.when i...
This is more a configuration error. Depending on how you have your DHCP setup, you may need to adjust it's setting. No mention of what os you are using but if you set your DHCP to give IP addresses only to the LAN, set the ISP NIC address to receive its ip from the ISP provider, you should be able to get Internet access to your server and the LAN.
If you have done so, use the server os to setup your Internet connection. Answer a few questions about how you connect to the Net and the os will do most of the configuration for you.
Good Luck
C2Solutions
Jan 24, 2011 | Dell PowerEdge 1800 Server
Tip
DHCP Server configuration in Linux
Linux is a UNIX based operating system. It is a server operating system. REDHAT Linux is Enterprise version of Linux. Now a day's Most of corporate sectors use red hat Linux as server in their company because it is secure very much.
Full form of DHCP "Dynamic Host Configuration Protocol. DHCP server assigns IP addresses and other network configuration information like subnet mask, broadcast address, etc to computers on a network. The DHCP assignments are the following.
Lease Request: Client broadcasts their request to DHCP server with a source address of 0.0.0.0 and a destination address of 255.255.255.255.
IP lease offer: DHCP server replies with an IP address, subnet mask, network gateway, name of the domain, name servers, duration of the lease and the IP address of the DHCP server.
Lease Selection: Client receives offer and broadcasts to al DHCP servers that will accept given offer so that other DHCP server need not make an offer.
The DHCP server then sends an ack to the client. The client is configured to use TCP/IP. Lease Renewal: When half of the lease time has expired, the client will issue a new request to the DHCP server.
Installation of DHCP server: First of all while install the RedHat Linux enterprise version server be careful about the ports and the services must be turned on. To create DHCP server in Linux first download DHCP RPM package and install with "rpm-ivh" command. Where I have done it there I have create YUM server, so easily I have download and install it by YUM (yum install dhcp version). DHCP package will locate in /usr/share/doc/at Linux file system. I copied the DHCP's files from /usr/share/doc/ to /etc/dhcpd.conf.. Then I started to configure the dhcpd.conf file to route the DHCP server in there local network. I have open the configuration file with "vi" command. Then commented out the lines from "default gateway to option netbios" because system don't read the commented lines. After that I set the range of IP address in dynamic- bootp of their local assumption of system. I have change the "next-server" with the dhcp server name and have also change the fixed address with the dhcp server IP address (end range of dynamic IP). It is very easy job to configure DHCP server. After configure the .conf file of dhcp just turn on the service with "chkconfig" command and restart the dhcp service. After that entire job I reboot the system. And after rebooting of server I turned on the other client system. While startup the client system without static IP address all of those picked up IP from dhcp server and going on successfully. I have prefer the command line mode to do the total job.
The DHCP server configure file is following:
ddns-update-style interim
ignore client-updates
subnet 192.168.1.0 netmask 255.255.255.0 {
# The range of IP addresses the server
# will issue to DHCP enabled PC clients
# booting up on the network
range 192.168.1.201 192.168.1.220;
# Set the amount of time in seconds that
# a client may keep the IP address
default-lease-time 86400;
max-lease-time 86400;
# Set the default gateway to be used by
# the PC clients
option routers 192.168.1.1;
# Don't forward DHCP requests from this
# NIC interface to any other NIC
# interfaces
option ip-forwarding off;
# Set the broadcast address and subnet mask
# to be used by the DHCP clients
option broadcast-address 192.168.1.255;
option subnet-mask 255.255.255.0;
# Set the NTP server to be used by the
# DHCP clients
option ntp-servers 192.168.1.100;
# Set the DNS server to be used by the
# DHCP clients
option domain-name-servers 192.168.1.100;
# If you specify a WINS server for your Windows clients,
# you need to include the following option in the dhcpd.conf file:
option netbios-name-servers 192.168.1.100;
# You can also assign specific IP addresses based on the clients'
# ethernet MAC address as follows (Host's name is "laser-printer":
host laser-printer {
hardware ethernet 08:00:2b:4c:59:23;
fixed-address 192.168.1.222;
# List an unused interface here
subnet 192.168.2.0 netmask 255.255.255.0 {
on Mar 17, 2011 | Computers & Internet
Tip
How to Check TCP/IP Configuraitons
The first step in the troubleshooting process is to check the TCP/IP settings. You can check it by using the IPCONFIG/All command on the command prompt. You will see the configuration results. If you see a blank configuration for a card this means then the card is not assigned any IP address. You can assign the IP address manually or via DHCP server. If you are using the DHCP server for assigning the IP addresses then you can use the following commands to get and release the IP address.
IPConfig/Release
IPConfig/Renew
IPConfig/All
If the computer is still unable to obtain an IP address, then there are several things that can causing this problem such as bad network cable or NIC card, DHCP server might have assigned all the IP addresses from its pool, mis-configured TCP/IP settings, incorrect user name and password. You can try to add a new well configured machine to the replace the malfunctioning machine to see if the new machine is working with its settings. Also see if the driver of the NIC is properly installed or not. In case of driver's problem go to the vendor's website and install a new exact driver for the NIC.
on Mar 25, 2010 | Computers & Internet
How i know the IP address assgined to the print server? once this how can I change it?
According to this site http://www.argecy.com/xtnd100s.html it it supports the use of HP's JetAdmin/Web JetAdmin utility which will allow you to configure the IP address as well as other features.
"Features such as full support for HP JetAdmin/Web JetAdmin"
Utility located here:
http://h20338.www2.hp.com/Hpsub/cache/332262-0-0-225-121.html
That same site also has this information about the ExtendView utility which may help you as well.
TROY LAN Administration Tools
  • ExtendView - 32-bit utility allowing most versatility and functionality available in network printing. Ability to view and configure print servers from unlimited number of views and quick and easy Windows IP address assignment are 2 key benefits. Features such as bulk configuration allow configuration changes for multiple print servers with simple steps. Save and restore feature allows a standard configuration to be saved and later recalled to restore same configuration
  • WebView - web based configuration tool allows complete status and configuration changes simply by typing the print server's IP address into a standard web browser
  • NetworkAlert - specialized Windows printer error utility providing proactive notification of printer problems through the use of SNMP traps
  • ExtendNet Connect - serverless (peer-to-peer) printing for Windows 95/98. Excellent tool for small businesses and remote offices
  • ExtendNet Connect NT - performance enhanced port monitor helps to improve the speed of data flow to the printer
Dec 22, 2010 | Troy ExtendNet 100s Print Server
My computer beyond ISA server and also have note book, when cable wire not attach with router then my wire note book connect easily, when i put my cable connection in router, wireless indication light stop...
First of all, routers come with static ips... (the default is usually 192.168.1.1). So I am going to assume you mean your internet ip is a dynamic ip. Now Im not an ISA expert, so I may be wrong... but ISA should work with a dynamic external IP. And lastly if you cant get it to work, a quick call to your ISP will get you a static IP.
or
Try to configure the IP address of the external NIC in the same network as your router with the default gateway pointing to your router´s IP address.
In the internal NIC, configure the IP address of the internal network in the same subnet as your internal clients, set no default gateway and set an internal DNS.
In the internal network definition, you should put only the networks behind ISA trust interface.
Create access rules according to your needs.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 21, 2010 | D-Link DIR-300 Wireless Router
Dell Power Edge 2600. It has an ERA nic but can't configure it?
The ERA is not like the more modern DRAC's ... it must be configured through the OS.
Feb 21, 2010 | Dell PowerEdge 2600 Server
How to get into the configuration utility to set the nic/ip address
The dell PE server should have a PXE boot menu. You probably need to go into PXE menu and configure, or they need to provide a PXE server so the server can boot from PXE automatically.
Dec 30, 2008 | Dell PowerEdge 4400 Server
Connecting a Oki C5300N as a 2:nd printer in my Mac-network..
Good Day Joromich,
Sounds like your problem is just an IP address conflict. The easiest way to fix this is going to be through the front panel of the printer. You will need to configure the NIC to DHCP AUTO. This will allow the switch/router to configure the printer to the IP address schema your network is using.
You should also check you switch/router settings to ensure if you are using MAC address filtering (this has nothing to do with your Mac computer). The MAC address is the physical hardware address of any NIC device. It is the "permanent" device identifier that the manufacturer has assigned to the NIC. If your switch/router is configured to use MAC address filtering you will need to know this address. It will be a series of HEX values similar to this:
AE:02:4F:3B:55:2F
And is usually located on a sticker on the outside of the NIC adapter, if not you might need to remove the card from the printer to check it, however you should be able to obtain a NIC configuration page from the printer through the control panel. If you are using this additional level of network security (helps to prevent rogue devices from attaching to the network), you will need to add the MAC address to the switch/router filtering table. Most home network users do not use this additional layering of security, but when using wireless access points/routers, every extra bit of network security helps.
Once you have reconfigured the printer for you network IP schema through the use of DHCP, the network should now see the device. If you are configuring your printer drivers to print to the IP address of the device, you should disable the DHCP AUTO setting once everything is working. Otherwise the switch/router will replace the printer IP address once the lease is expired then causing your printer not to be accessible again.
Once the switch/router has provided the new printer with an IP address, you will be able to access the internal web page of the printer through your Internet browser. At this point you can then change the IP address configuration to DHCP OFF. This will prevent the printer NIC from making an IP address request and keep the IP address that has been assigned as a STATIC address.
Configuring the printer driver on the Mac is easy, once the device has been added to the network, the Mac Add Printer Utility will see the IP address of the printer and you can use this to print directly to it rather than using AppleTalk. As for problem of not having the orignal install CD, not a problem as the printer is listed within the Mac OS printer table. If you want to use the Oki OEM driver follow the link listed here:
http://my.okidata.com/pp-C5300n.nsf/openingdrivermenu?OpenFrameSet
Select the one you want and install it as usual. Hope this helps get you going.
Cheers, Happy New Year!
Keith
USA
Dec 26, 2008 | OKI C5300n Led Printer
Problem with IBM T42p?
Usually your ISP requires your network configuration to obtain an IP address from the DHCP server so you can access the Internet via your ISP.
Why do you want a static IP address?
Are you trying to set up a home network together with a wireless access?
Nov 17, 2008 | IBM ThinkPad T42p Notebook
Can't assign ip configuration to NAS 208
Probably the NAS got the same IP address of the router/switch. Something like 192.168.1.1. Try changing your router default IP address to 192.168.1.3. Look for the NAS now.
Dec 22, 2007 | Computers & Internet
Dell PowerEdge 4400 Server Logo
134 people viewed this question
Alun Cox
