Question about NEC WT610 DLP Projector
Pink shade more in NEC WT-610 PROJECTOR
More pink shade,all colors not proper
Using the on screen menu, check the hue or wall color settings. [Hue]
Varies the color level from +/- green to +/-blue. The red level is used as reference. This adjustment is only valid for
Video, Component and TV standard inputs (not valid for RGB and DVI digital).
Using the Wall Color Correction [Wall Color]
This function allows for quick adaptive color correction in applications where the screen material is not white.
The following nine options are available.
• OFF • Blackboard
• Blackboard (Gray) • Light yellow
• Light green • Light blue
• Sky blue • Light rose
• Pink
Posted on May 13, 2009
  • R Gremillion
    R Gremillion Oct 23, 2013
    I don't see a "Wall Color Correction" option. Where is it located?
What's causing a pink hue?
Typically a pink hue is caused by a bent pin on your VGA cable. Each pin carries a specific color, so if one of the pins doesn't make a full connection it will turn your image a certain shade.
Mar 01, 2011 | Mitsubishi XD280U Projector
I have an Epson EMP-S4 projector. When I hook it up to my laptop the light comes on, but everything is in a shade of pink. I've tried adjusting color to no avail. Tried with another computer, same...
Check your cable you are missing a primary color and it could be that your cable is missing a pin/bent ck on both ends and even the projector input.
Jun 15, 2010 | Office Equipment & Supplies
The projector is an NEC model VT590 and is connected to my computer for use with a SMARTBoard. In the bottom left hand corner a pink colour is starting to grow inwards. In the upper left hand corner, there...
It is not the smartboard, lamp or the computer as well know, it's the projector itself. This may not work but you at least need to try press the auto adjust button on the projector and then adjust the clock/phase in the menu. If not you will need to send in to NEC it could by the color wheel. Usually they have a warranty for a couple of years.
Jun 05, 2010 | NEC MultiSync VT590 LCD Projector
5100 HP Desktop printer--magenta ink comes out pink not red (right out of sealed package!)
magenta is just a fancy name for pink.... its usually a darker shade of pink not overly dark but not a bright pink that most associate with the color.
most hp printers use the ckmy color format as opposed to the rgb that most are used to. check your other ink levels to ensure that they are at least half full and when you print out a doc or pic requiring red, the other inks will assist in creating the proper shade
Mar 27, 2010 | HP Office Equipment & Supplies
My NEC mt1075 projector is projecting a shade of blue all over. The entire screen is showing the correct image, but also with a shade of blue. I think something is wrong with the internal wiring. Is this a...
If you're using component video (red/green/blue rca cables) one of the colors may be disconnected, or the wires may be swapped into the wrong color input. If you are using a 15 pin VGA connector, one of the pins may not be getting good contact at the source or at the projector. Or if the VGA cable is split into 5-wire to make a long cable run, one of the five wires may be disconnected. Any of these problems will cause a global color shift while not affecting the color of the projector's on screen menus.
Jun 22, 2009 | NEC MT1075 Multimedia Projector
Pink cast in images from NEC VT540/440 projector
Sounds like one of those problems only cureable with expert knowledge of for example Chroma feed , Lcd function , lamp luminence, not to be a killjoy but it sounds like this is one for the engineers an estimate should be free and even if you dont have it fixed you'll know whats wrong if you want to do it yourself providing you have adequate training of course .... Regards vortash
May 08, 2009 | NEC Office Equipment & Supplies
My NEC MT850 projects with a pink picture you can still see image but it is a very bright pink.
A pink image normally means a loss of green signal.If you are using Computer input you should try replacing your input cable to see if this is the problem. If it is pink with video also then the projector most likley has a internal problem.
Mar 05, 2009 | NEC MT850, MT1050, MT1055, MT1056...
Showing to of the same thing and colors
ghosting or convergance issue is what u have. if the image is in diff colors then deff a convergence issue. however, if the image isthe same color or shaded from the original then this is ghosting. this may be corrected through the menu settings(sinc settings).
Jan 15, 2009 | Toshiba TLP-380, TLP-780, TLP-781UF...
Double display
Hi yaali
Try using a different cable.
If the problem however persists , then you will have to get the Mainboard either repaired or replaced.
May 17, 2008 | NEC VT460 Multimedia Projector
NEC WT610 DLP Projector Logo
1,406 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
