NAD 302 stereo balance problem
In order to get equal output from both L and R channels, I need to set the balance pot fully left. The left channel is considerably down on gain, the right channel appears to be operating normally.
To get equal output on both channels requires the balance pot to be turned fully left and the main volume to be turned up quite a bit to compensate.
I've checked over the PCB for obvious signs of component failure and nothing jumps out at me. Q507 and Q508 have been getting hot, as there is some discoloration on the PCB around these components, but no sign of any overheating damage to resistors.
The balance potentiometer itself seems to operate well, no dry joints around it. Tried swapping speakers over of course to verify it's a problem with the amp, and tried differnet phono cables from differenet input sources too.
Any ideas ?
    Genius:
  • 1,175 Answers
I would replace the output transistors of the bad channel and any very low ohm resistors associated with them.
Whilst youre in there replace the electrolytic caps in the power amp section. Caps are cheap and plentiful.
I dont know what the rest of the circuit looks like but there might be a need to balance the DC offset after replacing transistors.
matelectronics.com and audiolabga.com carry many good replacement transistors.
Posted on Dec 30, 2008
Universal remote
ANYWHERE.. Walmart, bestbuy, dollar general, even dollar tree sells them.
Apr 07, 2016 | Clarion CX201 Radio / CD / MP3 player /...
Using two equalizers on two sets of Bose 901's
As I have figured from your question you are trying to independently control levels for two sets of Bose speakers attached to your NAD amplifier. The problem lies in that the amplifier can only read one signal at a time, so in theory it will only accept a signal from one equalizer and output it to speakers attached to A and/or B terminals. In order to process different eq settings to two seperate pairs of speakers you will need to use two amplifiers, or an amplifier with built in channel controls for speaker set A and speaker set B.
Feb 21, 2008 | Bose 901 VI Main / Stereo Speaker
I don't know how to use behringer feedback destroyer DSP1124p
Determine where in the mixer's signal path to connect the unit. Your options are:
1. One or two individual microphone channels via the mixer's CHANNEL INSERT in/out jacks.
2. The monitor mix output via the mixer's MONITOR OUT jacks.
3. The main mix output via the mixer's MAIN OUT jacks.
  • 2 Connect a balanced cable with the appropriate connectors from CHANNEL INSERT OUT jacks on the desired mixer channel to INPUT RIGHT or LEFT on the Feedback Destroyer's back panel for individual microphone channels. Connect a balanced cable with the appropriate connectors from the OUTPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel to that mixer channel's CHANNEL INSERT IN jack.
  • 3 Connect a balanced cable with the appropriate connectors from the mixer's MONITOR OUT jacks to the INPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel for the monitor signal path. Connect a balanced cable with the appropriate connectors from the OUTPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel to the monitor amplifier INPUT jack or amplified monitor speaker INPUT jacks.
  • 4 Connect a balanced cable with the appropriate connectors from the mixer's MAIN OUT jacks to the INPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel for the main mix (FOH) signal path. Connect a balanced cable with the appropriate connectors from the OUTPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel to the main amplifier INPUT jack or amplified house speaker INPUT jacks.
  • Oct 17, 2011 | Behringer Audio Players & Recorders
    Hi my amp left channel does not work. the speaker relee works at both channels and the amp works fine at the right side.it goes not in protect what do u think is wrong ?
    It could be a number of things. Try this test first though. Play some music and swing the balance control to the bad channel and turn up the volume all the way if needs be. If you hear any music breaking in the pre-amp is ok. If not it could be dead. Again if you hear faint music it's the power amp that's not working.
    Next have a look inside. You should be able to identify the channels by following the wires from the speakers. Remember that stereo amps are just two mono amps joined. So the Right Channel will act as a guide to what the left should look like. Plus if you are any good with a volt meter provide the correct voltage indications. Any burnt/damaged parts on the left and not on the right is an indication of the fault area. If you have no output from the above test pay close attention to those parts on the heat-sink for the affected channel.
    Ignore the power supply parts are anything that is on it's own, unless it's an IC with both channels going into it. As they can go faulty on one channel, but not the other sometimes.
    If you can't find anything it might be an idea to replace the left output device(s).
    May 19, 2011 | NAD 218THX 2-Channel Amplifier
    The balance pot of my NAD C370 is not working, will the amp still work if I remove the balance pot?
    Only if you replace the pot with two resistors of equal value. Both need to be also equal to 1/2 the value of the pot. Then at the point the 2 res tie together -- Tie that point to the middle lead location and the other leads to the other points where the pot was connected. Use 1/2 watt or 1 watt res.
    Nov 02, 2010 | NAD C370 2-Channel Amplifier
    Mixer and an EQ & amp ?
    The order is mixer, equalizer and amp. The output of the mixer connects to the input of the equalizer and the output of the equalizer connects to the input of the amp. The equalizer has three types of input and output connections. They are XLR, 1/4 inch and screw terminals. The mixer will have one or two of the three. Choose XLR if possible on the mixer, choose line level output on the mixer if possible. A XLR male to female cable is needed for the connection. The equalizer has two channels, if the mixer has two output channels the two output channels of the mixer can connect directly to the two input channels of the equalizer. If the amp has two input channels, the two output channels of the equalizer can connect directly to the two input channels of the amp. If the mixer only has one output channel then only one channel of the equalizer can be used and one channel of the amp likewise. A XLR male to female connection cable can be used to connect the equalizer to the amp.
    Jun 23, 2010 | DBX 1215V Home Equalizer
    Technics SH GE70 : 1 bar doesn't do much
    I would want to know if it's just an indiction problem or an actual notch.
    Let's prove the signal is pure going to the EQ.
    Tune between FM stations with no automatic muting on your receiver so you can hear a loud hiss. Monitor the EQ display. There should be a lot of energy across the bands. If you see the notch swap the inputs to the EQ to prove it's in the EQ. Otherwise the signal is being affected upstream.
    Let's prove there's no audible notch in the bandwidth. This is the fun part.
    Set your system to just play Stereo with the FM hiss and if there is a Stereo Direct setting that bypasses internal circuitry, engage it. Adjust the EQ for equal level and flat response on both channels.
    Disconnect the two front speakers. Wire just one front speaker across just the Positive leads of the Left and Right amplifiers. This is not dangerous. (**)
    ** Back in the day we used this kind of wiring (with some proper resistance and circuitry to prevent interaction between the front channel speakers) to extract ambience (difference) information from plain stereo to drive a speaker at the rear of the room. Adjustment was done by selecting MONO and turning the Balance control for Minimum output, then going back to Stereo for listening. Ah, the old days.
    What this does is make the speaker play only what is DIFFERENT between the channels. If the source is truly MONO as it should be there will be a minimal output presented to the speaker. In an ideal world a true mono signal fed to both channels in this manner would result in total silence. There will always be some difference in the real world.
    You can prove the accuracy and fullness of the EQ signal by adjusting one channel of the EQ to be different and as you do the sound should start to rise as the Delta increases. Returning the controls to flat and equal should provide minimal output. If there is a solid audible difference in the treble range the EQ might actually be showing the 6.3khz deficiency accurately. To see if it's at 6.3khz adjust the LEFT channel downward to match the display of the RIGHT and the difference program material should become very low as heard from the speaker. That would indicate a true deficiency in the LEFT channel.
    Fixing it might not be possible but you might be able to use the EQ to offset it.
    Apr 29, 2009 | Technics SH-GE70 Home Equalizer
    Channel Problem
    It could be a bad balance control potentiometer or just broken/cold soldering joints due to the age. Bring it in a repair shop. Thanks. ebcelectronics
    Apr 06, 2009 | Audio Players & Recorders
    How to connect a sr430qx equalizer to abpm500 gemina mixer and a carvin dcm2000
    All of three of these components have balanced connections. There are many different ways to connect- but this is the best option. You will need 4 x standard XLR3(cannon) mic leads. Starting from the Gemini mixer:
    take the left output and plug it into channel 1(A) of the DOD EQ
    take the right output and plug it into channel 2(B) of the DOD EQ
    then...
    Connect the EQ output of channel 1(A) to the input 1(A) of your Carvin amplifier
    Connect the EQ output of channel 2(B) to the input of 2(B) of your Carvin Amplifier
    Happy DJ'ing
    Rus.
    Feb 19, 2009 | Dual Audio Players & Recorders
    NAD 7155 with one speaker channel not working
    In my case, if I push in on the balance knob, I can get the channel that quits to work for a while.
    This leads me to believe that the pot is dirty as opposed to a circuit or component failure.
    A couple of years ago, I sprayed circuit cleaner into the pot as best I could and the problem disappeared but, it has returned.
    My next attempt will be with one of the newer cleaner/lubricators that are available now.
    I don't know if this will solve your problem but, it might be worth a try.
    BTW, getting access to the volume/balance pots takes some doing. As long as you are there treat both pots.
    Greydog(1)
    G
    Jun 08, 2008 | NAD 712
    326 people viewed this question
     Grubhead
    Grubhead
