Question about GPS
Brake light on
The brake light is on the dash and it gets brighter and dimmer when rev engine
  • 158 Answers
You almost cetainly have a bad earth on the light or more likely on a break light so the bulb ( in the brake light ) not the dash light , is having to source its earthing through the dash light and this makes more current flow through that light causing it to brighten. I am puzzled though as to what this has to do with a GPS , as this is where you have "posted" your query ?
Posted on Dec 31, 2008
Have taillights but no brake lights or dash lights
Those are different unrelated circuits. The dash lights are from the Head/park light switch. Make sure the dimmer rheostat is not turned way down-you know, how you turn the knob for brighter or dimmer interior. If the bulbs are good on the backside of the cluster, it may be the switch.
The brake light switch is on the brake pedal. If no power to the switch, check the stop light fuse. I believe it may be same fuse as the hazard lights.
Nov 22, 2015 | 1986 Jeep Comanche
How do I reset abs and brake light on 1997 dodge ram 1500. Replaced speed sensor. Also unplugged Pulse control box under dash. Light is determined to stay on. Please help
Some cars/trucks run the ABS power through the brake light bulbs!
Does brake light and ABS light come on separately,key on,engine off?
Be sure that the parking brake switch is not bad.
The brake light should flicker/get brighter/dimmer when actuationg the parking brake.
Also,defeat the low fluid warning sensor.Defeat the pressure differentail switch.
I know some MFRs make both lights come on when either system fails.
Check for signal FROM the sensor at a wheel Use A/C voltage mode. I have spun the undriven hub with an electric drill to see A/C output.
Please note that the brakes will work OK but you not have ABS function.
See if you can get the brake warning light out,separately.
Nov 12, 2014 | Dodge 1997 Ram 1500
2002 Grand Caravan. Overhead console lighted switches are not lighting. The Map lights that shine straight down works but none of the others back lights. Side door switch,rear gate switch, garage door...
The first thing that comes to mind is that the dash lights scroll dimmer is scrolled all the way in one direction which manually shuts off all the interior lights, even if a door is opened. At night turn on the parking lamps and then scroll the dash lights dimmer until the dash, radio face, overhead console, etc is brighter. Turn off the headlamp switch. Shut off the engine and exit the vehicle. Interior lights on? Hope this helps.
Jan 26, 2018 | 2002 Dodge Grand Caravan
My 98 merauder discharges when it gets hot out
check wires from stator coil normally 3 the same colour disconnect plug and test from stator side wires should have continuity between each other but not to earth if no continuity or going to earth replece or rewind stator if tests ok run bike with headlight on light should get brighter as you slowly increase revs if however lights go brighter and then goes dimmer as revs increase replace regulator rectifier
Jul 18, 2010 | 2001 Suzuki VZ 800 Marauder
After jump-starting my van, the panel lights don't come on when the headlights are on. How do I fix this?
this either a fuse that bew or your dimmer switch that makes the lights brighter and dimmer on the dash is turned down all the way if the fuse is good and it's nit turned down all the way then the bulbs are all blown or the dimmer switch is bad
Jan 14, 2010 | 2002 Dodge Grand Caravan
Dodge d150 dim headlights when running and dies
you may have a bad alternator, bad battery, or simply dirty battery terminals.
Clean the battery terminal connections with a battery terminal brush and reinstall. Check to see if that helps your problem.
Usually this is an alternator problem. If the headlights get brighter when you rev the engine, then it's most likely the battery. But if the lights just get dimmer and dimmer, it's most likely the alternator. If the voltage gauge doesn't show proper voltage, 14 or more volts, alternator is probably the fault.
Dec 09, 2009 | 1987 Dodge D150
I have a 95 cad. deville no dash lights
the dimmer switch would be where I would look first. See if the conditions change after turning the lights brighter and dimmer.
Jul 14, 2009 | 1995 Cadillac Eldorado
GPS Logo
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
