Question about Nikon D80 Digital Camera with 18-135mm Lens
Faulty lens renders auto features kaput on D80
The auto features on my D80 do not work. My local camera store said it was the lens (18-135)... they showed me an F---- in the display and said that meant 'Feed' and there was no 'feed' between lens and camera.
They had a customer with a similar problem a few days before and tried a different lens and it worked. We did the same: chose a new lens from the display case, fitted it and all was up and running....?!!
I am on the tiny island of Bermuda and cameras have to be sent overseas for repair and it takes weeks! Any ideas?
  • pjuj Jan 06, 2009
    I have A Nikon D-80 camera with 18-200 VR lens. Since yesterday it is not auto focussing on my D-80 body. I understand that Nikons all the 3 DX lenses i.e. 18-70, 18-135 and 18-200 have this focussing problem. Nikon should take note of it and rectify this defect to retain their loyal Nikon customer. PJ . India
  • hejhog100 Jan 12, 2009
    Is this the same problem? When I try to focus, it won't, and I can't take a pic at all. However, the lens worked for a year. Did your 135 lens work at all? Are all 135 lenses like this? If so, what lens could you buy that would not be faulty?
    Problem Solver:
  • 8 Answers
This is a common known problem with the 18-135mm Kit lenses that come with the D80's, and D90's for that matter.
All you need to do is rotate the lens ever so slightly to make the connection, and you may need to turn off the camera and turn it back on. This solves the problem for about 90% of my clients.
Posted on Jan 20, 2009
I have a nikon d80 for the the last couple of years the live view on the monitor has worked ok. ie when i switch on the camera the monitor shows what i am about to shoot. Tonoght this feature stopped...
Apparently there was something seriously wrong with your camera, which has now fixed itself. Nikon didn't put the LiveView feature into the their DSLRs until the D3 and the D300, which were released after the D80. The more recent D90 has this feature, but not the D80.
Jul 02, 2011 | Nikon D80 Digital Camera with 18-135mm...
When I atach the lens don't have any image, only the menu and in the upper display the word "Err" flash. Thank you very much.
Err on any Nikon D series camera indicates that the lens is not communicating with the camera (among other things). There are 3 things to check:
1. Is the lens you have a full-auto lens for use with the D80? 2. You need to set the lens f-stop to its maximum number (minimum opening) with some lenses for it to work right. If the lens runs from say f 1.4 to f 22 and you've left it set for f 16, it will give Err message 3. The lens may just not be seating correctly. Remove the lens and CAREFULLY inspect the contacts on the lens and camera to see if there's any discoloration, bent pins, etc. If you find this, I would suggest professional repair.
If it is only the auto-focus feature that's messed up, you can switch to manual focus and the error should go away. Of course, you'll then have to manually focus.
Dec 08, 2010 | Nikon D80 Digital Camera with 18-135mm...
D80 Digital Camera with 18-135mm Lens: My nikon d80 will not auto focus when I push the s...
The r11 is in the lower right of the top LCD or view finder that is in the D80 manual page 36 it speaks about the buffer. The r with a number is how many shots the buffer at that moment can handle. It is not an error message. For auto focus issue is the lens in AF as well as the camera?
May 17, 2010 | Nikon D80 Digital Camera with 18-135mm...
Nikon camera
For the best under $1000, that would be the D90.
The 18-105VR will work on the D70s.
May 07, 2010 | Nikon D80 Digital Camera with 18-135mm...
My D80 nikon camera was not working specially on
Check the following:
- Make sure your lens is screwed on correctly. Try to remove it and put it on again.
- Make sure the dial is squarely pointed to Auto
- Make sure the Auto-Focus switch in front of the camera is turned to A (not to M)
Dec 29, 2009 | Nikon D80 Digital Camera with 18-135mm...
My D80 will not auto focus with any of my 3 Nikkor lenses. It will fire on auto focus when you manually focus while in that auto focus mode.
Press the AF button on the top of the camera (to the right of the window) to select an AF mode & make sure the M/A (Manual / Auto focus) switch on the lens set to "A"
More info below:
Oct 05, 2009 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 won't take photos!
The F-- error means that the camera does not think that you have a later AF type lens attached.
If you are using the 18-135mm then the camera is not properly connecting to the lens.
To test this, press the lens release button on the camera and slightly turn the lens as if you are going to release it then turn it back to lock.
This may fix the problem.
If not you can try remounting the lens a few times and if that doesn't work you could clean the lens contacts.
The contacts are the metal studs on the back end of the lens, the bit that goes into the camera.
Sorry if that is too obvious.
If you have an early lens it must be set to the smallest aperture using the ring around the lens.
This will be 22 or 32.
Then lock it using the little lock near the ring.
Jul 22, 2009 | Nikon D80 Digital Camera with 18-135mm...
In built Flash
In Shutter, Aperture, Program and Manual modes the auto feature does not function. Only in auto mode.
Mar 06, 2009 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 Digital Camera with 18-135mm Lens Logo
35 people viewed this question
Top Nikon Cameras Experts
Are you a Nikon Camera Expert? Answer questions, earn points and help others
