Question about Canon PowerShot SD600 Digital Camera
Canon SD600 I accidentally submerged my camera in a cup of beer. It still turns on but the screen is discolored and its really hard to take pictures the button is really sticky. Is there anyway to fix this or am I looking at buying a new one?
    Novelist:
  • 198 Answers
Hello, You are facing several problems that must be first taken care of. The lens assembly is not sealed ermetically so if beer got into it..that's bad because no service center can dissasemble the lens assembly to clean them. However you should take your chance. First of all the camera needs to be dissasembled. Second, it's main board and buttons must be washed in something called izopropilic alcohol. Then the internal battery and external one must be removed and eventually a firmware update should be done. You may have all of these done in a service center, they aren't that expensive repairs. If after this repairs the pictures will come out blurry or distorded this means that the lens assembly was damaged. I think however that you should try these first. Please go to a service center, try the smaller ones, generic "camera repair service", not the larger ones working for large corporation (they tend to be expensive). Ask them for a cost estimate before actually repairing the camera. For more informations please reply back here. Good luck.
Posted on May 02, 2007
SOURCE:
My Canon powershot sd600 got submerged in water
http://www.fixya.com/support/r3771170-phone_water_damage
Oct 27, 2009 | Canon PowerShot SD600 Digital Camera
The screen on my camera will not display anything at all. The camera appears to turn on, but the screen is blank. Even when I switch it from one mode to another, there is nothing displayed on the screen
Have you tried taking pictures with it? Do the pictures show up when taken? If so, then it's likely that you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
Oct 26, 2009 | Canon PowerShot SD600 Digital Camera
My cannon power shot sd600 viewer doesnt turn on
Sounds like you accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD screen on and off to save batteries. You would then use the optical viewfinder in its place. Try pressing this button one more time to see if it turns back on.
Oct 13, 2009 | Canon PowerShot SD600 Digital Camera
Blank screen
Sounds like you accidentally pressed the DISP (Display) button on the back of your camera. This manually turns the screen on and off in picture taking mode to save battery power. You could then use the optical viewfinder in its place. To turn it back on, just the DISP button one more time.
Jul 07, 2009 | Canon PowerShot SD600 Digital Camera
When taking pictures there are lines across the pictures and sometimes the picts are really bright or discolored. What could be the cause of this?
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jun 30, 2009 | Canon PowerShot SD600 Digital Camera
Lcd monitor
Did you accidentally press the lower left "DISP" button on the back of your camera (turns the LCD on and off to save batteries)?
Oct 18, 2008 | Canon PowerShot SD600 Digital Camera
I have a Canon PowerShot SD600 Digital Elph, and the screen on the back has turned off while I try to take a picture. It will show on the screen when I try to take a movie, but the photos is just a black...
Did you accidentally hit the DISPLAY button on the back of the camera. It turns the LCD screen on and off in picture mode to save batteries.
Jun 23, 2008 | Canon Cameras
I am having the similar problem with my cannon sd600 camera. I have the pictures in my card but not able to upload to the computer. I used the memory card reader to upload the pictures and when I plug that to the computer the camera will be shutting down the power and system not able to see the pictures to upload. Please some one help me. thanks!
Apr 20, 2008 | Canon PowerShot SD600 Digital Camera
Black Screen When Open, but the Picture quality is fine
in the lower right hand corner there is a button that has disp. on it just click that during picture taking mode and it will return to normal
Dec 25, 2006 | Canon PowerShot SD600 Digital Camera
Canon PowerShot SD600 Digital Camera Logo
436 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
