Question about CMB NC6120 CM/1.4 512MB 40GB 15 CMB WLS WXPP (PZ340UAABA) PC Notebook
Notebool hangs Hello how r u dear sir i m facing problem with my hp nc6120.when i start may laptop it hangs on hp logo.i changed every thing like hard drive,combo drive and ram but problem is same.sometime it boot after taking a long time but in windows while working it hangs then after sometime start work. please give me the solution
  • 1 more comment
  • otpisani1 Apr 09, 2009
    I have the same problem, did u solve the issue.
  • Anonymous Apr 15, 2009
    I have same with about 4-5 laptop. Every morning ...same problem. After few hours it start works.
  • Gerhard Stoll
    Gerhard Stoll May 11, 2010
    have you checked the cpu fan ?
    can you clear your bios settings ?
    Perhaps an Missconfig.
On startup os logo hangs up
Is not compatible with your device
Mar 20, 2013 | HP Compaq 6730b Notebook
Compaq nc6120 factory reset
change le hard disk c la seulle solution
Sep 30, 2012 | HP Compaq nc6120 Notebook
HP 4530s hangs at HP screen
Sub out the ram memory one at a time, next remove the hard drive and reseat it back in place, if none of these work try your recovery disc if possible, no change! have the hardware tested for possible replacement.
Jul 02, 2012 | HP Computers & Internet
I just installed new HDD in HP laptop, run XP installation disk there was an installation error. so i switched off laptop and got another xp disk, switched on laptop,inserted disk then screen went very dim...
Can you turn on the laptop at all, does it go through the initial hardware tests, can you see the HP logo? Can you go into BIOS?
the nc6xxx series is known for the Maxim chip problem, and your laptop may just have arrived at that time when its Maxim chip needs resoldering. Take a look at this post for more detailed explanation, diagnostics and repair guide for repairing the non-booting, dead HP nc6120 laptop.
Dec 01, 2010 | HP Compaq nc6120 Notebook
My HP compaq nx6110 windows xp sp3 hangs at boot
Take a look at this post that deals with a HP nx6110 laptop with random freeze ups. If the described symptoms also happen on your laptop. If you do experience random freezeups or slow DVD you're facing the same FSB chip problem. All peripherals, USB ports included, are connected on the Front Side Bus. Poor soldering causes intermittent contact which in turn results in hanging, slow, or totally non bootable (stuck at HP logo) laptop. Hope this helps.
Nov 14, 2010 | HP Compaq nx6110 Notebook
WHEN MY HP COMPAQ NC 6120 BOOT UP IT ONLY STOPS AT THE HP LOGO
You need to perform a Hard Reset and a RAM remove and reseat.
But Unfortunately I think its a hardware issue.
If the notebook is under warranty The best option to contact HP right now if not in warranty then contact Best Buy
Jun 15, 2010 | HP Compaq nc6120 Notebook
I HAVE NOTEBOOK HP NC6120 , WHEN I PRESS THE BUTTON TO START UP IT STILL AT THE HP LOGO AND DOSNOT MOVE AGAIN , AFTER I TRAY 20 ONCE IT START UP , AND THE SAME PROBLEM IF I SHUT DOWN IT , WHAT IS THE...
Hi, Hang at start up logo may cause by hardware.
You can try to take out hard disk first. See weather it can go through the start up like normal or not. If cannot, try put the hard disk back and take out the CD/DVD ROM. And try again to start the notebook.
If the problem still remain, your motherboard problem. Change it but it might costly.
May 09, 2010 | HP Compaq nc6120 Notebook
Reset bios password
Most laptops do not have one and clearing the cmos will not help.
Contact HP, they have a master password that can get you in. You may have to fax them proof of ownership to get them to help. I had to do this on a laptop.
Hope this helps
Apr 28, 2009 | HP Compaq nc6120 Notebook
Hello
go into your bios setup utility program and change boot settings there.. enable fast boot, and switch the first boot device to your hard drive..
Jun 07, 2008 | BenQ Joybook 5100U Notebook
Computers & Internet Logo
140 people viewed this question
Top CMB Computers & Internet Experts
EKASYS IT SERVICES
EKASYS IT SERVICES
vojvodabudva
Masood Rasool
Level 1 Expert
Are you a CMB Computer and Internet Expert? Answer questions, earn points and help others
