Question about Cameras
Problem displaying slideshow on a Philips digital photo frame (7F
I'm not sure if this is the right forum but... I bought my mother a Philips digital photo frame (7FF1M4) two years ago and she has just told me she can't make it display a slideshow. The menu buttons work fine until she has to select slideshow ("yes" or "no"). Then, the "select" button on the back of the unit simply keeps toggling between yes and no and won't let her select either of them. None of the other buttons on the back works to select the option either. I've tried this and she's right--the button doesn't seem to be working.Is there any way to reset the frame or is it defunct? Although it's 2 years old she has hardly ever used it and I've no idea how long this problem has been there...
Thanks for any help anyone can give!
  • Anonymous Jan 21, 2009
    slideshow not working
  • 903 Answers
Go here and download the manual you need for your Mum's frame. Hopefully it will help you with troubleshooting your problem
Posted on Dec 30, 2008
  • Debs
    Debs Dec 30, 2008
    when the link opens there will be some numbers you need to type into a box then click on download, it will then give you the option of selecting which language you want to download the manual in.
How to start slideshow after selecting the pictures
When you power on the picture frame, a slideshow will automatically display the photos on your memory. (If you have not inserted a memory card yet, the slideshow will display the photos pre-loaded into the internal memory.)
To restart the slideshow, press
ENTER again, or press the Slide Show button on the remote control.
May 05, 2014 | PANDIGITAL 7-Inch Digital Photo Frame with...
Polaroid IDF-1030 Digital Picture Frame - Slideshow with Music
The manual for the Polaroid IDF-1030 is ridiculously simple and not very helpful. There's actually more information on the outside of the box.
One of the features that is not intuitively easy to figure out is how to get the frame to display a picture slideshow AND play music at the same time. The remote is the only way that you can set this up.
First, on your computer, create a folder for the images and a folder for the music. If you put music in the images folder, your slideshow will stop at the first music file it finds and just display the music player's equalizer interface. This is very boring.
Note on the pictures.. spend a little time and reduce the size of your pictures to 640 x 480 pixels. Dealing with large files on the photo frame is painfully slow.
images should be in JPEG (.jpg) format although it will also display .gif files. Music should be MPEG (.mp3) format.
Copy these folders to the root of your memory card.
Put the memory card in the Polaroid frame card slot and turn it on.
Use the remote and press the STOp button if it automatically starts displaying the pictures.
Press the MUSIC button and select the REPEAT button until you see REPEAT ALL at the bottom of the screen.
Press the PLAY/PAUSE to start the music, then immediately press the SLIDESHOW button to start the slideshow with music.
I hope this helps some of you who had trouble with this.
on Jan 07, 2009 | Polaroid IDF-1030 (826219006783) Digital...
Whenever I load photos onto my photo frame from the PC, they all seem to transfer just fine. But then when running the slideshow, not all the pictures are showing up. When I go into the photo menu on the...
The issue may be due to the file types of the pictures you are sending to the frame. You did not include the model number of the frame, so I can't be sure of the file types it can display but generally, JPG file types enjoy the most compatibility on such devices.
You should determine the file types of the images you are sending to the display. While displaying the slideshow, make a note of an image that displays properly. Look at the the image on your computer and check the file details to learn which file type it is. Play the slideshow on the frame and double check as many as you can against the list / thumbnails on the computer. After a short time, a trend show be visible. You may find that JPG and GIF files display properly, but TIF and others do not.
If you want those pictures to display, you'll have to convert them to one of the file types that does display. If you're finding that only some JPG (or other displayable file type) do not display properly, you'll have to see what is different. Sometimes, very large files may not display correctly, or it may have "too much color" information (they might be a 16 bit graphic or 16 million colors instead of an 8 bit graphic or 256 colors), or some other issue that isn't readily apparent. You can try resizing or converting to yet another format that is supported by the display (GIF for instance).
This is a starting point - hopefully you'll find the issue within one of these suggestions. Good luck! Please rate my reply - thank you.
Feb 24, 2011 | Philips 6.5-Inch Digital Photo Frame...
Slideshow freezes during slideshow
I wonder if ALL the pic's are correct Size & Format?
Feb 01, 2010 | PANDIGITAL 7-Inch Digital Photo Frame with...
I can't get my DP702 digital frame to save my pictures from my camera. Can you tell me how to do it ... ty
The DP702 frame only takes 14 pictures saved to the slideshow file. Install a memory card/device, then plug in the usb cable, electronic store carry it for 7 or 8 dollars. It's too bad, it doesn't come with the frame. Choose the photo you want saved, and press the save button on the remote to save the photo to the slideshow, if you press it again while you're on the same frame, I think it will delete that photo. I hope that helps.
Dec 26, 2009 | Coby DP-772 Digital Picture Frame
I bought a coby digital photo frame (DP5588). I was under the impression that it played the downloaded music along with the slideshow(so I was told at purchase). How do I get it to preform this function or...
Hello you were not misinformed about the audio capability but you may have been misled. The only audio formats which your frame supports are these two: MP3 and WMA.
Here is a link to all of the specs on your purchase:;rnav
Regards, Joe
PS please rate my answer. Thank you and happy holidays.
Dec 26, 2009 | Coby DP-5588 5.6-Inch (4:3) Clock &...
How do i put my photos on slideshow
you can only do that with the remote control;
Oct 26, 2009 | Coby DP-772 Digital Picture Frame
How do I turn off the clock option during slideshows?
While the Slideshow is playing hit the setup button then go to Enable Clock Display and hit enter. Arrow to off and hit enter. That should do it.
Mar 25, 2009 | PANDIGITAL 7" Digital Photo Frame With...
Sola SL D-104 Digital Frame Reading Flash Drive Pictures
I too gave a Sola SL D-104 for Christmas with 580 pictures on an 8 GB flash drive. I had no problem with the frame reading and displaying all pictures in continuous slide show plus looping at the end and starting over. Simply use the "Slideshow" button on the remote. Perhaps there were hardware problems with the drive or the frame. My 580 .jpg photos only used about 0.9 GB, so it might be easy to try another drive for only 300 shots. Were they all .jpg formats? The frame is fussy as to file format. Hope that helps.
Dec 18, 2008 | Cameras
Cameras Logo
349 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
