Question about LG RC897T DVD Recorder/VCR Combo
How to change regional settings
Hi there bought from cash converters and no manual can you help me out on changing the regional settings to play all
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Appreciate the direct "Ask Me:.
Initially, for the LG RC897T, pls try:
  • Click the HOME button on the remote with the unit in 480i resolution
  • Click the setup page
  • Click Start
  • Click TV Aspect
  • highlight the 16x9 wide aspect ratio
  • enter on remote control this coded sequence:
  • 1 3 9 7 1 3 9
Edit specific "Options"
  • Option 2: 35 (enables Divx/Xvid playback)
  • Option 4: ff (enables Vcd and SVCD playback)
  • Option 5: ff (enables region free playback (region 0) DVD playback)
  • Option 6: ce (enables Insignia brand startup logo on boot)
  • Option 6: c0 (enables LG brand startup logo on boot)
This has been posted on the Internet here and here for an LG RC797T and was discussed here.
Good luck and Thank you for using FixYa. Happy New Year.
Pls be informed that due to my current rank and rating, even a Helpful wouldbe detrimental to my status. Should this solution not address yourconcern, it would be appreciated if you could just not rate this at all. Cheers.
Posted on Dec 30, 2008
I bought an acer laptop ...thelanguage setting is in Italaina nd wnat it converted to english, how can i do that
I think if the langauge of the OS is set to italiana,you need to reformat and then choose english as an main language.
Sep 13, 2011 | Acer Aspire 3623WXCi Notebook
I bought a DVD set from Ireland and it won't play on my DVD player or my Wii. Is there a setting I need to change?
Hi there!
North American TVs, consoles and DVD players play video and games in the NTSC format (region 1), while Ireland's and most of Europe's play in PAL(region 2). You best bet to be able to watch your dvd set will be to purchase a dvd player that plays multi regions (these will be a bit more expensive) or to order a region 2 dvd player from Ireland or somewhere in Europe that uses region 2.
Hope this helps!
Jul 05, 2011 | Nintendo Wii Console
I bought my dvd player from Malaysia but I am using it in Middle East where I am currently residing. Initially, we are able to play all dvds (which we bought original) but suddenly, it kept popping a...
Are you using WMP or any third party players to play the dvds ?
I suggest you to check if the DVD region code is set to one (US) or not. If not, change it to one.
The region can only be changed five times, before its set permanently.
How do I change my DVD region?
DVD movies are encoded for different world regions, and your DVD-ROM drive must be configured for the appropriate region in order to play the DVD.
If you have DVD-decoder software installed on your computer, you can usually change the DVD region setting in the DVD decoder program. Follow the instructions in the program's Help file for changing the DVD region setting.
If you have a software or a hardware DVD decoder installed on your computer, you can use Device Manager to change the DVD region setting in your DVD-ROM configuration:
1. Click Start, right-click My Computer, and then click Properties.
2. On the Hardware tab, click Device Manager.
3. In the list of devices, double-click DVD/CD-ROM drives, right-click the DVD drive for which you want to change region settings, and then click Properties.
4. On the DVD Region tab, make the desired changes.
You must be logged on as an administrator or be a member of the Administrators group in order to change the DVD region.
Note that the DVD region for most DVD-ROMs can only be changed up to five times, and the number of changes still available is located on the DVD Region tab. If the tab shows that you can only change the setting one more time (Changes remaining = 1), you won't be able to play DVDs that use a DVD region that is different from your last selection. If you run out of opportunities to change the setting (Changes remaining = 0), contact your DVD-ROM's manufacturer to reset this value.
Also install DVD decoder as an issue with codec or DVD decoder could even cause the issue with DVD region code.
http://www.microsoft.com/windows/windowsmedia/player/plugins.aspx (Also applies to Windows 7)
Mar 26, 2011 | Vacuums
My jwin model jd-vd509 does not play all regions,how can i change that? iwas given player in macau in macau as a gift,but find that the origanal dvd`s i bought in the uk and australia wont play,it comesn...
Don't know if it will work on your. I have a jWin JD-VD141 and the code works. Have the DVD tray open (means ejected) then press 9735. A menu will pop up and choose Regions 0 then exit. You DVD player should play DVD from all regions.
Dec 08, 2009 | Jwin JD-VD509
Would like to unlock region codes from dvd/hdd combo recorder
hi
you can try to change the region to play using your dvd by highlighting your dvd drive in the my computer folder then click on properties from there you will get to see the region tab and you can change the region setting for the dvd you will be using. but you will only be allowed to change region 5 times
Jun 12, 2008 | Medion Computers & Internet
Dvd WRITER
you need to go into the control panel. click on clock,region,language. In there you can change the region.
Apr 12, 2008 | Computers & Internet
Multi region support
Unit is programmed for respective regions and cannot be changed, however, you can also find discs that are "region free" and they will play fine...accordianman
Feb 22, 2008 | Sanyo HV-DX2E DVD Player/VCR
DVD Writer does not respond when DVD movies are inserted..
YOU WILL PROBABLY CHANE THE REGION SETTING TO GET THIS DRIVE TO PLAY THE DVDS FROM Canada
Jan 16, 2008 | LG (GSA-4167B) DVD RW Dual Layer Burner
Incorrect region code DVD player
if you use a PAL broadcast system where you live ..Use the menu on dvd to set it to PAL system..If you use NTSC change it to NTSC .
Dec 05, 2007 | Televison & Video
LG RH277H - won't play bought DVD'S
The cd tray eject after put in the DVD movies, but VCD working fine...it is means that the drive's region code haven't set yet .(please refer to user manual to setting the region code) ..or unplug the recorder drive from the dvd player,using the computer setting to change the region code by connecting to computer's IDE cable .
Oct 19, 2007 | LG RH177 DVD Recorder/HDD Recorder
LG RC897T DVD Recorder/VCR Combo Logo
633 people viewed this question
Computer Repairing
Computer Repairing
