Question about Nintendo DS Lite Console
Unit not switching on
The charge light is on when AC adapter plugged in, when power is switched on to unit the lower screen flashes once then switches off.
The unit is only 12 months old.
  • Anonymous Dec 30, 2008
    my ds wont charge and light wont come on but new charger
Either the system has a blown fuse or it needs the top screen replaced. Either is simple to fix if you are a little bit technically inclined..... You can get replacement screens off ebay for less then $10.00. I have fixed a few of these and its really not to hard....
Posted on Dec 30, 2008
How to charge
• IMPORTANT: This unit is delivered partially charged.
Plug into an extension cord FOR 40
hours before using.
You cannot overcharge the unit using the AC charging method.
• To recharge this unit, use only the supplied AC charging adapter.
• All ON/OFF switches should be in the OFF position when the unit is charging or not in use. Make sure all switches are in the OFF position before charging. Here is the instruction book:
http://ecx.images-amazon.com/images/I/81US%2Bom6xKS.pdf
here is the booklet.
Jul 21, 2014 | Stanley Tools 500W Portable Power Station"
I have an almost similar problem. When plugged in, the AC/ Battery LED indicator does not light up and I can't power up the unit. Sometimes when I take out the battery and put it back in, the unit powers...
Yes this fault is in the mother board but the fault is the switching/regulation/charging section of the pwoeer supply section.
Somehow it is not switched on auto and so the malfunction. Might have to remove and check the powerr section for errors in the regulator.
Sep 23, 2010 | Acer Aspire 4520-5582 Notebook
Just bought a second hand acer travelmate 4200. I have never owned a lap top. How do I change from using battery power to outlet power
On the left side, towards the rear is a DC jack. Plug the power cord in there. It should automatically start operating on AC power, and charge the battery.
Feb 24, 2010 | Acer TravelMate 4200 Notebook
My sony reader is frozen. I cvharged it
The Reader may not turn on, or it may appear to be frozen if the unit needs to be reset, the battery is completely discharged or moisture condensation has occurred.
Please perform the below mentioned steps and check whether it helps.
Because each of these steps represents a possible solution to this issue, check the Reader status after completing each step.
1. Connect the Reader to a USB connection or optional AC adapter. Allow approximately 5 min for it to turn on. If it does not turn on automatically, try to turn it on again. If it still does not turn on, continue with the rest of this procedure.
2. Perform a soft reset. Just press the RESET button using a sharp-pointed object
3. After the RESET button has been pressed, slide the POWER switch to activate the Reader again. If the Indicator light next to the power button on the Reader is yellow , the unit is attempting to start up. If this is the case, allow it a few moments to complete startup.
4. If startup did not complete, connect the Reader to the computer or optional AC adapter and perform a soft reset again.
5. Disconnect the Reader from the computer (if applicable) and then slide the POWER switch to activate the Reader. Check if the Indicator light next to the power switch on the Reader is yellow (indicating it is turning on) and if the unit is responding.
6. If the unit is not responding but Starting up... is displayed on the screen, attempt a hard reset.
7. If the unit is still frozen, connect it again to the computer or optional AC adapter and while connected, check if the Indicator light next to the power switch on the reader is red . If this light is red , allow the Reader to charge for one hour so there is sufficient charge for troubleshooting.
* If your computer goes into hibernation or sleep mode, charging will stop and the red charge indicator on the Reader will turn off.
* It is recommended to charge the Reader while you are using the computer or to adjust your sleep/hibernation settings of your computer to avoid any interruption in the charging process. You also can use the optional AC Adapter model ACS-5220E.
8. Once the Reader has sufficient charge, perform these troubleshooting steps again.
9. Under certain circumstances, moisture condensation can occur. Moisture condensation can be caused by moving the Reader between temperature extremes or if the Reader has come in direct contact with moisture. If you suspect moisture as the cause, allow the Reader to sit for a few hours before attempting to turn it back on.
General notes regarding the battery status:
* You can verify the charge status by disconnecting the Reader from the computer and checking the battery indicator. The battery indicator will display 4 black bars when it is fully charged.
* It will take approximately 4 hours to achieve a full charge with a computer. It will take approximately 2 hours to achieve a full charge with the optional AC Adapter.
If the issue still persists, service of the Reader is required. Please follow the below link to get it repaired:
http://eservice.sony.com
Jan 20, 2010 | Sony E-reader Portable E-book MP3 Player
The USB connected screen is frozen on my reader and I don't know how to fix it.
The Reader may not turn on, or it may appear to be frozen if the unit needs to be reset, the battery is completely discharged or moisture condensation has occurred. Please perform the below mentioned steps and check whether it helps. Because each of these steps represents a possible solution to this issue, check the Reader status after completing each step.
1. Connect the Reader to a USB connection or optional AC adapter. Allow approximately 5 min for it to turn on. If it does not turn on automatically, try to turn it on again. If it still does not turn on, continue with the rest of this procedure. 2. Perform a soft reset. Just press the RESET button using a sharp-pointed object 3. After the RESET button has been pressed, slide the POWER switch to activate the Reader again. If the Indicator light next to the power button on the Reader is yellow , the unit is attempting to start up. If this is the case, allow it a few moments to complete startup. 4. If startup did not complete, connect the Reader to the computer or optional AC adapter and perform a soft reset again. 5. Disconnect the Reader from the computer (if applicable) and then slide the POWER switch to activate the Reader. Check if the Indicator light next to the power switch on the Reader is yellow (indicating it is turning on) and if the unit is responding. 6. If the unit is not responding but Starting up... is displayed on the screen, attempt a hard reset. 7. If the unit is still frozen, connect it again to the computer or optional AC adapter and while connected, check if the Indicator light next to the power switch on the reader is red . If this light is red , allow the Reader to charge for one hour so there is sufficient charge for troubleshooting.
* If your computer goes into hibernation or sleep mode, charging will stop and the red charge indicator on the Reader will turn off. * It is recommended to charge the Reader while you are using the computer or to adjust your sleep/hibernation settings of your computer to avoid any interruption in the charging process. You also can use the optional AC Adapter model ACS-5220E. 8. Once the Reader has sufficient charge, perform these troubleshooting steps again. 9. Under certain circumstances, moisture condensation can occur. Moisture condensation can be caused by moving the Reader between temperature extremes or if the Reader has come in direct contact with moisture. If you suspect moisture as the cause, allow the Reader to sit for a few hours before attempting to turn it back on.
General notes regarding the battery status: * You can verify the charge status by disconnecting the Reader from the computer and checking the battery indicator. The battery indicator will display 4 black bars when it is fully charged. * It will take approximately 4 hours to achieve a full charge with a computer. It will take approximately 2 hours to achieve a full charge with the optional AC Adapter.
If the issue still persists, service of the Reader is required. Please follow the below link to get it repaired: http://eservice.sony.com
Jan 02, 2010 | Sony Reader Touch PRS-600
My reader's menu is frozen and it wont respond to any buttons. How do I fix it?
Nov 17, 2009 | Sony E-reader Portable E-book MP3 Player
No response
First follow procedure to try to reset the power.
  1. Unplug the ac adapter. Keep ac adapter unplugged.
  2. Remove the battery and keep the battery unplugged.
  3. Hold the power button down for 15-20 seconds. (Nothing will appear on the display and none of the lights will light up.)
  4. Release the power button and plug in the ac adapter ONLY. (Please note that a power indicator light should be lit on the ac adapter when it is plugged in).
  5. Normally power on the notebook.
  6. If the unit does not power on, remove the ac adapter and insert the battery into the system.
  7. Plug the ac adapter back into the system, the battery charging indicator light will light up.
    If the battery charging indicator light does not light up, the ac adapter may not be providing proper power to the unit, and may need to be replaced.
May 23, 2009 | Acer Computers & Internet
Couldn't switch on my laptop;adapter light blinking !
Please take out the battery, and use the AC adapter to boot up only, then put the battery on.
If any abnormal situation occurs, please do a battery calibration as instructed in the manual. Adapter info:
Power problems with AC adapter
Step1 :
Please remove the battery first to verify the AC adapter's problem
Step2 :
Please check the power outlet on the wall by plug another device to the outlet
Step3 :
Please plug the adapter directly to the power outlet on the wall
Step4 :
Please make sure both the wires between the adapter to the wall and to the notebook are well plugged and the LED on the adapter is alight
Step5 :
Please check the power status indicator to make sure whether the notebook is powered on
Step6 :
Please make sure whether the CPU fan perform the testing run when the power is switched on
Step7 :
Please stick into the hardware reset button at the bottom of the machine and reboot
Step8 :
Please remove all of the removable hardware (exp. mouse, PCMCIA card, power adapter, battery, external drives, memory and etc) and install only the necessary components.
Step9 :
Please remove the AC adapter and re-install the battery
Step10 :
Step11 :
If possible, please change another battery to make sure whether it's the battery's problem
Step12 :
May 04, 2009 | Computers & Internet
Wont charge while powered on or run on ac power
Sounds like a lose or burnt charge terminal.  Fixing would require disassembling the laptop and resoldering the loose or broken connections.  You might want to try a different AC adapter first.
Apr 21, 2009 | Toshiba Satellite A75-S211 Notebook
Cannot turn on
most of the time this is caused from slight water damage, or the top screen isn't functioning.
I have seen many of the top screen ribbon cabled that have sent an electric arc across 2 of the pins on the connector which causes the ribbon cable to burn out the connection on those pins resulting in an improper circuit and will flash the screen and shut off. I have repaired many units and would be happy to take a look at yours.
Thanks,
ninja_freak318@hotmail.com
Dec 30, 2008 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
26 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
