Question about Hotpoint 18 in. BCI45 Slim-Line Built-in Dishwasher
I have a hotpoint bc1450 no water coming into machine
I just got my washine machine fixed it sits beside my dishwasher however now my dishwasher has gone seems that there is no water coming into machine yet my taps at sink are all flowing properly. i can here a clicking/wurring noise but nothing happens. any help please i dont want to pay a fortune to get this fixed after paying for washing machine.
  • rico61 Jan 31, 2009
    Yea, I have the same no water problem. Clicking but no water !! Someone suggest a technician could reset the swithing mechinism . . . how do you do this?
    Problem Solver:
  • 18 Answers
Did the problem start directly after the washine machine was fixed ? I wonder if when the washing machine was moved back, the hose to the dishwasher has become trapped and kinked behind the washing machine. Or maybe the supply to the dishwasher is separate to the washing machine and has been turned off by mistake.
Posted on Jan 01, 2009
Hotpoint BC1450 Light 2 normal flashes
Flashing lights, pump running even when turned off. Had to switch off at the socket. The vibration from the machine had managed to give a quarter turn to the appliance gate valve, the type with the little blue handle. I could see the indentation in the rear rubber panel on the back of the dishwasher. Unscrewed the little blue handle, pushed the machine back in and started working as normal. :)
Oct 07, 2012 | Hotpoint 18 in. BCI45 Slim-Line Built-in...
MY WASHINE MACHINE DOES NOT SPIN
hello. andrew check the pump first it has drain before it spins if the pump is ok then the cause could be the module board this sits at the back of the machine usually has a load of wires coming off it hope it helps
regards
shaun
Mar 12, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Machine has power and appears to be running but no water is coming through
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble
No Water entering Dishwasher
heatman101
Dec 30, 2010 | Hotpoint 24 in. DWF34 Built-in Dishwasher
Hi i have a hotpoint washin machine and it kepp showing H20 on the csreen can you please help th model number is WT740
H20 indicates a problem with water supply.
Check the inlet hose/s for restrriction or kinks, ensure water supply pressure is o/k, also check the filter screens in the inlet valves, you will have to turn the water off to do this.
Dec 06, 2010 | Hotpoint Aquarius WD63 Front Load...
Hotpoint machine is not throwing the dirty water out
blocked drain piping or blocked impeller on drain pump or failed coil?complete pump,that would be the area that should be looked at to solve problem
May 05, 2009 | Hotpoint Washing Machines
Hotpoint dishwasher full of water after cycle complete
If the motor is running, the diverter solenoid valve is probably not functioning. It is attached to the pump. With the power off, take the solenoid apart and remove whatever is jamming it. Toothpicks are a favorite as are any large food particle. It may also be bad. Not the problem...you may have a defective timer or your outlet hose is clogged or kinked.
Feb 10, 2008 | Neff 24 in. S5443X2 Built-in Dishwasher
Not enough water going in or draning properly
air brake blockage more than likely the cause.
see air brake systems in haynes dishwasher manual
Jan 12, 2008 | Hotpoint 22 in. 7892 Built-in Dishwasher
Dishwasher just draines and nothing else??
this sounds like it could be the heater element has gone faulty, it is quite difficult to get to test it with it being built in, but basically gain access to the underneath of the appliance and you can test it with a test meter for open circuit, it is also possible that a wire has either come off or broken, the pump pumping out is like a safety mechanism, the eco wash may work because this uses no heat? (some models) the answer i have given you is based on the info you have supplied if i have helped please rate me, thank you, please work safe unplug when working on appliances
Sep 22, 2007 | Hotpoint 18 in. BCI45 Slim-Line Built-in...
Hotpoint Ultima dishwasher dwf70
Press and hold the start and the on/off buttons together. It should come out of demo mode.
Aug 25, 2007 | Hotpoint 24 in. FDW60 Free-standing...
DISHWASHER IS LEAKING A LOT OF WATER
I had the same problem with my machine - ie lots of water coming out front about two thirds of the way through the cycle - engineer (local and very reliable) knew as soon as he came in that I had started bying Powerball 5 dishwasher tablets - they produce too much foam (try opening the door during the cycle and see the amount of foam) and it therefore comes out of the overflow parts on the door. I tried Magnum 5 and got the same problem. Now I stick to either Asda's own basic (not the 5) or I buy the Magnum ones and cut them in half. Has never leaked since!
Jun 11, 2006 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint 18 in. BCI45 Slim-Line Built-in Dishwasher Logo
332 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
