Question about Kenmore 62882 Electric Dryer
Dryer Problem - Kenmore
I am having a little problem with my dryer. I can get it to turn on. The outlet works, I plugged in an old dryer and it works. The one I am trying to replace with has been in storage for about 2 years. I didn't know if there was some sort of reset button or something like that. I disconnected the power supply and clean and reconnected, still no luck. Not sure what the problem may be. Please help me!
  • 1 more comment
  • Scott Langford May 07, 2007
    I have ohmed it out, everything seems to be in working order. I cleaned everything out, and I still can't get it to turn on. Any other suggestions?
  • Scott Langford May 08, 2007
    Checked the door switch it is fine. I tested the high limit cut out, and it seemed fine, but I didn't jump it out. Should I try yo jump every piece out? They all check out when I test them. Also, when I try to start it back up, do I have to have all of the piece back on the back? Not sure what to try next. Thanks for your help, keep the suggestions coming. Thanks again!
  • Scott Langford May 14, 2007
    Okay Catriver, I finally got the dryer to turn on. It was actually the power cord that was bad. I switched the power cord and it turns on now. The first time it fired up, it ran fine with heat. Then I put it back together, and now I don't get any heat AND the timer does not count down. I jumped the high end voltage fuse on the heating element; that did not make a difference. Then I actually reset the breaker, and I got heat again and the timer couted down. Then I put it back together, and no heat and timer does not count down. Not sure what it going on here. Suggestions? Again, thank you for your help.
    President:
  • 878 Answers
Scotty, this is an electric dryer, as long as you are sure the power is ok, start with the thermal fuse. The dryer won't run if it's bad. Remove the back panel and ohm it out. Or you can jump it temp. to verify that's the problem but don't leave it that way. Check the pic. start there and post back...Catriver.
Posted on May 01, 2007
  • 1 more comment
  • Ron Marek
    Ron Marek May 07, 2007
    Scotty, next move would be the door switch itself, make sure it's working and then the high limit cut out. This would be the top one on the heater housing. Jump it out and see if it starts. Catriver..post back.
  • Ron Marek
    Ron Marek May 10, 2007
    OK, Scotty, if you sure all those switches are ok, lets go to the push to start button. Should be a black and white/red (you may need to look at your schematic, should be under the consol.) You should have 120V going to the black. Then with someone pushing the button in,door closed, you should have 120V to the black and white/red. If you have this voltage, the next move is to the motor belt safety switch. This switch has to be making in order for the motor to operate. This is why it's important to follow the shematic with your machine. Just follow the line up from the drive motor to the push to start switch. The colors I posted may be wrong. If you don't have the voltage to the push to start switch (black) then our problem might be in the timer. Catriver.
  • Ron Marek
    Ron Marek May 11, 2007
    Scotty, I got a hold of your schematic, looks like this is a even heat dryer. When you hold the push to start button, does the dryer run? If so, it's the even heat board. It looks like there are two black wires coming off the push to start. With the unit on timed dry and air fluff, should have 120V to the black coming in. With the button pushed, 120V across both the terminals. With the dryer on timed dry, air fluff setting, check the BK terminal at the timer to any nuetral, should read 120V. If no voltage, check terminal L1 to nuetral, should have 120V. If L1 is ok, check voltage at BU, if no voltage there, replace the timer. Catriver.
My kenmore gas dryer end buzzer goes off and dryer shuts down before cycle is complete
Instructions Things You'll Need:
  • Kenmore gas dryer
  • Vacuum with hose attachment
  • Replacement fuse, if necessary
    Dryer Not Heating
  1. Remove lint from your dryer's lint screen. Remove the lint screen from your Kenmore dryer and vacuum the area behind the lint screen with your vacuum's hose attachment.
  2. Check to make sure that the dryer temperature is set appropriately, and has not inadvertently been turned to "Air Fluff."
  3. Ensure that the gas valve on the supply line to your Kenmore dryer is completely open.
  4. Check the room temperature in your laundry room to make sure that it is at least 45 degrees. Your Kenmore dryer will not operate properly at temperatures below 45 degrees.
  5. Make sure that the dryer outlet grill is not blocked by a fabric softening sheet.
  6. Dryer Not Running
  7. Check to see that the dryer cord is properly plugged in to the electrical outlet.
  8. Check your fuse box to make sure that the fuse is not blown, or check your circuit breaker to make sure that it has not tripped. Replace the fuse if necessary or throw the circuit breaker.
  9. Check the outlet itself to make sure that it functions properly by plugging in a portable device.
  10. please comment on these solution on how it works by rating or voting.
Dec 30, 2010 | Kenmore Dryers
My kenmore superba is not working. Does not turn on. It is plugged in and the outlet works. Push the button...nothing. Please help.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 29, 2010 | Kenmore Dryers
Kenmore Elite HE4 dryer- can I change the plug from the present 4 pronged utility plug to a standard 3 prong plug and still work safely?
NO, You will need to get an electrician to install a NEMA 14-30R outlet for your dryer, the electrician will know what you need, in anycase a 240V 30amp outlet is needed if you dont already have one. DONT replace the plug.
Jun 20, 2010 | Kenmore Elite HE4 Electric Dryer
My Kenmore 600 is not even 2 years old. It spins and appears to have heat but the clothes do not dry. I cleaned a ton of lint from the flex pipe/elbow joint in the rear of the dryer but this has not...
You are on the right track by cleaning the vent elbow.
Also check:
The entire vent line to the outside diverter (the little thing that looks like a hood). Depending on your dwelling, the vent line can also become obstructed with lint and sometimes other things like bird's nests, especially near the discharge outlet. This can happen when the flapper valve at the outlet sticks.
Make sure the lint screen is always kept clean
Another thing to try - empty the dryer and pull it away from the wall until you can get behind it. Disconnect the vent line and turn the dryer on air only. The air velocity coming out of the dryer air exhaust line should feel pretty strong. If it doesn't, the fan could be full of lint as well or there could be an issue with the exhaust fan itself. If the fan is plugged or bad, the back of the dryer will have to be removed and the fan checked.
The dryer should not be overloaded and be sure the clothes being dried aren't too wet (possibly indicating a washer spin cycle issue).
Jan 01, 2010 | Kenmore 62602 Electric Dryer
Pilot working but will not dry completely.
Check the burner vents--both intake and outlet for lint plugging. With the pilot working, it is supposed to heat a thermocouple which generates electricity that opens the main gas valve.
Aug 21, 2009 | Kenmore 74602 Gas Dryer
We have a Kenmore 70 series Electric dryer and it heats just fine and stays hot, air flow is good,(checked), however the clothes are not getting dry. My husband replaced the cord to the outlet from a 3...
Did the dryer get clothes dry in your old home with the 3 prong plug?
If so, id put the 3 prong plug back on it, and switch to outlet to a 3 prong...
Jul 10, 2009 | Kenmore 63942 Dryer
Dryer Won't Start
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 27, 2009 | Kenmore 73952 Gas Dryer
Kenmore dryer plug does not fit
Probably a 220V machine and you have a 110 outlet. Or Vice-Versa.
Feb 26, 2009 | Kenmore 63942 Dryer
New kenmore dryer, set up right from box, wont turn on
call Sears your dryer is guaranteed for 1 year, parts and labor
Jan 18, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE3 Dryer (3 yrs. old)
when u push the buttons do all lights light up if so ,, machine is in lock mode ,, press and hold the little icon that read lock for about 3 seconds unitll lights are off then run ,, let see
Nov 19, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 62882 Electric Dryer Logo
970 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
