SOURCE: check engine light Mazda MX-6
Take the car to an autoparts store and have them scan the computer for stored fault codes. The light is to alert you that the computer has noted a fault in one of the car's systems. Most parts stores will do the scan for free and getting the codes will show what faults the computer identified, so you can take appropriate action. Hope this helped and best wishes.
SOURCE: Mazda 323 2002 Sting Immobilizer
Fcuk I got same problem with my Mazda 3 year 2004. Noone can help me at all !!! Even in Mazda they have no idea where is problem. For me it is at the moment only in cold weather. I cannot get throught immobilizer. After few turns it works, but not always (only when its bit warmer). I found out that if it is warmer, and I turn on ventilation for a while after it will let me go! Immobilizer starts flashing ... after few more minutes and turning key few times it will let me go !!! Please write me to [email protected] if you will know updates... I am desperate , cannot use my car in winter at all or cold weather. In summer works fine
SOURCE: Cold Air Intake - Mass Air Flow Sensor Adapter
i have a 91 mx6. the intake is all cattywompus and im just goin to take a piece of metal and tube and cut a hole in the peice of metal and weld the tube to it take my stupid box out and run that pipe staight to a coupling and then to the cone air filter. BAM!!!! problem fixed... i maight be able to fix yours too... e-mail me [email protected]. k?
SOURCE: First: alarm went off on its own.(mazda 6 2003).
there is often a small back up battery in the immobiliser unit itself, if you can locate this unit and replace the battery with the ignition on / engine running, then it should not need recoding and work fine after that. The other thing that could be wrong is the key battery (if the fob has one) or the transponder chip in the key head. If the key signal is low the immobiliser lamp will light during driving, but this does not explain the alarm going off. That is more likely either a poor vehicle battery, alarm / immobiliser back up battery, or another electrical fault such as water leakage into a tail-light or even the alarm unit itself when it rains. A lot of alarms are voltage sensing and when the vehicle is parked they will alarm if the battery voltage changes for any reason, though not during driving so the battery in the immob is my first choice to look at.
SOURCE: I have a 94 Mazda MX-6 2.5 DOHC I was driving on
The timing belt has broken. Fortunately though, according to my catalog, this is not an interference engine and the engine should not be damaged internally.
