Question about RCA HDLP50W151 50" Rear Projection HDTV
TV will not pick up cable signal
Tv has to be left on for hours to pick up cable signal.
  • 147 Answers
SOURCE: does not pick up cable satellite signal
Do you have the satelite hooked threu the regular cable input? If so hook it thru one of the video inputs instead; composite video or component video. the picture and sound will be better and you will be by-passing the problem area of your Tv ( the tuner).
Posted on Apr 25, 2009
TV is showing no signal. So I did a channel search and it stops and says unable to continue channel search due to error. I even unplugged - left for an hour and still does the same thing. I then hooked...
this could be a fault with the tv actual connector for the cable check the connection on the tv and try again or try a manual search to pick up one channel and then do a full scan also are you doing a scan to add channels to the current list as I would personally try and do a complete scan for all new channels list and see what happens
Sep 21, 2013 | Televison & Video
I was playing my PS3 and moved it from my tv upstairs to my tv downstairs. After plugging my PS3 in my tv downstairs, on which it had worked just 1 week previously, my tv picked up no signal from my PS3....
Try this.
Plug your PS3 on either TV. Turn on the backswitch. When the red light in front is on, put your finger on the on/off button in front AND KEEP IT THERE. You will hear some beeps; don't worry about that. Keep your finger on the button until the front power light goes red again. This resets the PS3 video settings. Turn the PS3 on and the TV should pick up the signal.
Hope this helps. Keep us posted.
Jul 04, 2011 | Sony Playstation 3 (PS3) Console
Hi, My Samsung UE46C8000 is suddenly showing left half of the screen fine, right half is simply colourful blurry vertical lines. After about 3 seconds the TV then restarts itself, but the problem...
if you have this tv connected to the internet try and see if it needs updating. it also could be the pip settinmg picking up an air signal instead of a cable channel.
Jun 25, 2011 | Televison & Video
Can't get the tv input to come up. all i get is no signal and no option to pick tv to get scan option.
Unplug tv and cables or satalites boxes,replug both back like an hour later.Now the tv it resetting itself back to factory setting.The cables or satalites boxes is resetting and it upgrading it softwares.The tv should work now.
Nov 08, 2010 | AOC L22W861 22 in. LCD HDTV
Sharp digital tv cannot receive digital signal
This television would benefit from an hdtv indoor outdoor amplified antenna not obstructed by trees, aluminum, bricks, and etc. Make sure the signal type is air and not cable and complete a channel scan during primetime tv hours after connecting to this antenna. Buy a large one that you can mount to the wall usually in a large flat box on the shelf in the store. Philips has one sold at Walmart.
Jun 07, 2010 | Sharp LC-26SH10U 26 in. LCD Television
Panasonic plasma viera tv will not auto tune, can not pick up any signals at all. All cables are plugged in correctly. Model number TH-P46G10A
Reboot all cables,satalites,and telicoms boxes.Like unplug,replug the box an hour later.Let the boxes up grade software,go to ur tv menu setup rescan all channels again well get them back.Ur signal not there after that, than ur Tuner Signal board is dead.Need it replaced.
Mar 13, 2010 | Panasonic Viera TH-46PZ85U Plasma TV
Does not pick up cable satellite signal
Apr 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
No receipt of signal or antenae
Since it has voice or sound then I don't suspect the tuner but probably the tuner does not have the 33 volts that goes through r106 location number on the board. It is a 27K resistor and can be bought for about a dollar at Radio Shack. (pack of 2or3) A repairman or someone experienced in electronic soldering and desoldering can change it easily. Could cost around $50 to repair depending on the serviceman. If it has rca jacks (red, white and yellow) The tuner can be bypassed if you have a cable box that passed these signals: audio left and right and video. Hope this helps
Dec 30, 2007 | Sanyo AVM-3258S 32" TV
RCA HDLP50W151 50" Rear Projection HDTV Logo
272 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
