Question about NetGear WGT624 Wireless Router
Cannot get past the IP entering details.
I have followed the install details on disc for the WGT624 up to where it asks for IP address, IP subnet mask, Gateway IP address,Primary DNS and Secondary DNS. I have entered these details on several occasions now and every time it says there is an error and to begin again. I have found all the details from ipconfig/all on the computer is this correct?. Instructions also state that I have to turn off the firewall which I have done only once but it still comes back with an error at the same point on the install process. Could anyone tell me what I am doing wrong please.
  • 104 Answers
Hello.....If your ISP has given you a static IP address to use to connect to the internet, they should also have given you the Subnet Mask, and Gateway IP Address - these are the settings to use.
If you don't have these settings, you will have a dynamic (variable) IP address. If so, try logging in to the router again, go to Basic Settings, and configure 'Internet IP Address' to 'Get Dynamically from ISP'.
Similarly, if your ISP has given you one or two DNS addresses, enter these up - but otherwise set as 'Get automatically from ISP'.
You might need to reboot one or more times for the settings to take effect. Hope this helps, but please come back to Fixya if it doesn't ...
Posted on Dec 30, 2008
NEED QUINTUM PASSWORD RESETTING
The detailed description of Configuring Terminal Software/Assigning IP address to Tenor DX is given below.If you need only RESETTING GOTO STEP 18.
1.From your PC, click on Start> Programs> Accessories> Communications> HyperTerminal. The Connection Description is displayed.
2.Enter a connection name (i.e., name for each unit such as Tenor DX 1 and click Ok.
3.Choose the connection port on your PC from the Connect Using drop down list box (i.e., Direct to Com1). Click Ok. The Com1 Properties window will be displayed. See Figure 3.
4.From the Bits Per Second drop down list box, choose 38400.
5.From the Data Bits drop down list box, choose 8.
6.From the Parity drop down list box, choose None.
7.From the Stop bits drop down list box, choose 1.
8.From the Flow control drop down list box, choose None. Click Ok. A connection to the Tenor unit is established.
9.Click on Call>Call. A connection to the unit will be established. The login prompt appears.
10.Enter a login name. The default login name is admin.
11.Enter a password. The default password is admin. (Once you are up and running, changing the password is a good idea for security purposes). Step through each of the following parameters and enter the correct values for your installation: IP address, Subnet Mask and Default Gateway.
12.At the Quintum prompt, type ei to reach the Ethernet prompt and then type config to change to the configuration mode.
13.To set the IP address, type set ipa followed by the IP address.
14.To set the Subnet Mask, type set subnetmask, followed by the subnet mask.
15.Type siprd to change to the Static IP Route Directory.
16.To set the Default Gateway IP, type change 1 g followed by the IP address for the default gateway IP.
17.Type submit.
18.Type maint to reach the maintenance mode and then mc. Type reset. A confirmation message will ask if you want to reset the unit. Type yes to reset the unit. The reboot enables the Tenor to incorporate the new settings.
19.Once the IP information is set, you are ready to configure the unit.
Jun 04, 2011 | Quintum Tenor DX2060 (501-0122-00)...
How do I reopen my nat for xbox live
1> Go to your xbox dashboard and locate the "Network settings" section.
2> Select "Edit Settings" and change your IP setting to Manual.
3> Enter the following settings depending on your router type (Credit goes to http://live.tommccann.net):
Linksys
IP Address : 192.168.1.250
Subnet Mask : 255.255.255.0
Gateway : 192.168.1.1
DNS : 192.168.1.1
D-Link
IP Address : 192.168.0.250
Gateway : 192.168.0.1.
DNS : 192.168.0.1
4> Next open your internet browser and select the address bar.
5> Enter the 192.168.1.1 (If you use D-link 192.168.0.1)
6> A box will show up asking you for an ID and password. (your parents may have changed it)
Default ID- admin
Default Password - admin
7> Locate the "Applications and Gaming" tab, then click "Port Range Forward"
8> Forward both UDP and TCP
88
2074
3074
9> test your connection and if it should be open.
Apr 11, 2011 | Microsoft Video Game Consoles & Games
Am lost my cd how do i install my f5db231-4 wireless router
Please follow steps to configure router
  1. Open Internet Explorer and enter the address http://192.168.2.1
  2. Leave the password field blank and click LOGIN.
  3. Click INITIAL SETUP.
  4. Select STATIC IP ADDRESS then click SELECT
  5. Now enter in the IP Address, Subnet, and Gateway, then click ENTER. (If you don?t know the IP Address, Subnet, or Gateway, call technical support and they will provide you with that information.)
  6. Now enter in the DNS Addresses, then click ENTER.
    a. Primary DNS = 209.193.72.2
    b. Secondary DNS = 209.193.68.2
  7. Now click ENTER.
now try to go online
Hope it can resolve your issue
Thanks for using Fixya
Apr 13, 2010 | Belkin (F5D8231-4) Wireless Router...
Cannot install netgear wgps 606 wireless print server on vista laptop. I have 2 other laptops with windows xp and have no problems setting up the print server. I get message that the subnet address needs...
Here's the toll free number for
  • Netgear Tech Support 1800-211-2069
  • Netgear Tech Support 1-888-638-4327
  • Make sure that you are able to go online when the modem is directly connected to the computer.
    Contact the above numbers for a first call resolution.
    Good luck.
    regards.
    Apr 08, 2010 | NetGear WGPS606 (WGPS606NAR) Print Server
    I have DWL2100AP i can open the IP address
    To enter the menu of your device follow the following directions :
    Your device default IP is 192.168.0.50 - Connect the device to your computer with an ethernet cable and set up your computer IP address manually, make it 192.168.0.49 , subnet 255.255.255.0 When connection is established, enter 192.168.0.50 in your internet browser, you will be able to reach the console.
    Nov 08, 2009 | D-Link AirPlus Xtreme G DWL-2100AP...
    I can't connect to the internet
    Is the issu on the wireless connection or wired connection through the router. Could you provide the below information:
    # Connect your computer directly to your modem and perform the following tests.
    A. Click on Start—Programs—Accessories—Command Prompt.
    B. In Command Prompt window, type in 'ipconfig' and hit 'Enter'. Note down the IP Address, Subnet mask & Default Gateway here. Also, mail us the same IP configuration.
    Above information will help me provide u an accurate resolution
    Jul 06, 2009 | NetGear WGT624 Wireless Router
    Wireless linksys wrt54gs router
    I have fixed this problem many times by entering just the gateway in the TCP/IP properties or all values as static e.g ip address, subnet mask and gateway as follows:-
    Limited Connectivity | wireless network
    Connect with an ethernet cable and find out the IP Address
    Also note the Subnet Mask, Gateway, and Primary and Alternate DNS values
    To get these :-
    1. Double click on Local Area Connection under Control Panel --> "Network Connections"
    2. Click "Support" --> Click "details"
    Enter these values for the wireless area connection like this :-
    1. Click "Start" -- > "Control Panel" --> "Network Connections"
    2. Right click on "Wireless Area Connection" --> select "Properties"
    3. Click on "TCP/IP" (in th middle box) -- > Click "Properties"
    4. Click "To use the following ip address"
    5. Enter the values you got from wired connection above
    6. If you get any duplicate warning messages ignore these
    This will resolve the issue, I have used it many times
    Jan 10, 2009 | Linksys Wireless-G WRT54GS Router...
    Installing the compaq home internet appliance
    does the appliance have a dchp ip address option or auto ip address option. The IP address is used by the wireless network to identify each computer device in your house.
    In your wireless router there will be a dhcp server that will lease out ip addresses to devices automatically.
    the ip address would be 10.0.0.1 for your router or 192.168.0.1 usually most used ip addresses .
    A subnet mask is usually 255.255.255.0 which is also needed.
    Go to your desktop computer and go to command prompt . Google your version of windows and command prompt to work out how to do this.
    then type in ipconfig
    press enter key
    note the default gateway address and the desktop's ip address
    you may need to enter the default gateway ip address into the fridge also.
    if the desktop was 10.0.0.2 subnet mask 255.255.255.0
    then make the fridge if manually have to set it
    10.0.0.254 subnet mask 255.255.255.0
    or 192.168.0.254 subnet mask 255.255.255.0 if it is 192.168.0.2
    the first three numbers are called the network address eg 192.168.0
    10.0.0
    the last number 1 - 254 are individual address part
    192.168.0.1 {router uses this 1 usually } to 192.168.0.254
    Jan 16, 2018 | Compaq iPAQ Home Internet Appliance IA-1...
    Cannot install D-Link router
    1. check your wireless adapter TCP/IP settings if its set into "Obtain as IP address Automatically".
    2. if the settings is set as Automatic and your not getting IP address then select "Use the following IP Address"
    3. use IP address followed to your router address like if192.168.0.1 in router type 192.168.0.2 or192.168.0.3 just check the next address IP in your network.
    4. after typing subnet IP will automatically set
    5. type the router IP address as your default gateway
    6. click OK to save your new settings
    Hope this will help
    Nov 24, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
    Installation problem with edimax 6104kp
    Hi Omdi,
    Please proceed with the following instruction as follow.
    1.) Connect first the modem to your pc, if you find it is working then get the IP Address, Subnet, Gateway, Primary DNS, Alternative DNS at the network properties TCP/IP.
    2.) Open your router where you can configure the static IP or manually enter the IP address, subnet, gateway, primary dns, alternative dns.
    3.) Make it sure you used the cable properly by connecting it to the appropriate line. For the modem to router you should connect the cable to WAN port. And the LAN port must be go through the computer.
    If you still experience the problem, please let me know.
    Best regards,
    Philip
    Oct 02, 2007 | Edimax BR-6104K Router (br6104k)
    NetGear WGT624 Wireless Router Logo
    53 people viewed this question
    Top NetGear Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
