Question about Nokia N73 Cellular Phone
N73: difficault to open message ,dont ring when called,vol adj.
Takes time to open messages up to 30 sec.
when receiving call sometimes do not ring
vol adj key on sind does not adj the vol louder
    Problem Solver:
  • 18 Answers
Restore your factory setting or hard format your fone,,, to hard format, pres and hold *3 and the send key for 2 mins and ask someone to help switch it on while you still hold the three keys together,,thanks
Posted on Dec 31, 2008
Goes to voice main on first try on second try rings
According to iPhone faq.org: " How can set the number of rings on my iPhone before voicemail picks up?
You can set the iPhone to wait longer or shorter than the default 20 seconds before it goes to voicemail when receiving an incoming call. This will result in a different number of rings before the voice messaging system picks up the line and plays your outgoing message. To change the amount of time the iPhone will ring follow these steps:
1. Open the phone app and dial *#61# on the Keypad. Press the Call button.
2. Locate this text on the screen: "Setting Interrogation Succeeded, Voice Call Forwarding, When Unanswered, Forwards to +" and record the 11-digit number after the + symbol.
3. Touch the Dismiss button. Now enter this code on the Keypad: *61*+ followed by the 11-digit Forwards to number recorded in step 2, followed by *11 and *ringtime#. Ringtime is the number of seconds you want your iPhone to ring before voicemail picks up. Your finished code should look something like this:
*61*+18555513466*11*30#
In the example above the ring time is set to 30 seconds. Press the Call button.
4. You should receive the message: Setting Activation Succeeded. Press Dismiss and next time you receive a call it will ring for the new amount of time before going to voicemail."
According to Apple Tool Box.com: "having this problem, please try the followings:
  • Make sure that iPhone's Ring/Silent switch is OFF meaning ringer is ON. A bell will flash briefly on the screen when you turn on the ringer.
  • Make sure that the Do Not Disturb setting is not silencing calls (Settings > Do Not Disturb).
  • Make sure that Airplane Mode is OFF (Settings > Airplane Mode).
  • Make sure that your carrier software is up to date (Settings > General > About)."
    AccorA
Apr 15, 2015 | Apple iPhone 4S
How can I set full length ringtone in LG GR500
dial **61*(the your message bank number)**30# this will extend the time it takes for your phone to divert to message bank to 30 secs. If you dont want message bank you can cancel call diverts in your seetings menu after putting in this code and it will still ring for 30 secs. Note: this does not work for Vodafone Australia
Dec 10, 2010 | Cell Phones
RECEIVING THE CALL IS VERY SLOW,SOME TIMES IT IS RINGING SOMETIMES NOT (MAXIMUM TIME CALL RECEIVED WITHOUT RING TONE) OVER ALL OPERATION OF THE PHONE IS VERY SLOW
1. Make sure your phone is fully charged.
2.
Backup your contacts list and personal files to MMC memory card (if possible).
3.
Switch on your phone.
4.
Press and hold these three keys together:
* Red dial key,
* Sharp key (#)
* One key (1)
5.
5
Press the power on/off to swtich off the S60 phone. Do not let go the three keys until you see the "formatting" screen displayed
6.
6
Wait a few minutes until the format is complete. Your phone will now be at its original factory settings
Method 2
1.
Before you format your phone, make sure you back up all your ringtones, SMS and picture messages and most importantly yout contacts. You can use the Nokia PC Suite to do this.
2.
Press Red key, select disconnect.
3.
Once you've done this, key in *#7370# *#7780# . It will immediately prompt you to restart your phone.
4.
Select 'Yes' and the phone will restart after formatting. It takes about 2 to 3 minutes to complete the process. Also ensure that your phone is well charged before you format.
5.
5
Now restore all your ringtones, messages and contacts and you once again have a fresh OS.
Dec 02, 2010 | Nokia N73 Cellular Phone
I have a samsung propel and I am not receiving text messages I am I doing something wrong. I stopped receiving messages yesterday and yes people have sent me messages
first thing to try is a battery pull ..remove battery for 30 secs the power on the phone ...if that doesnt work call your carrier and make sure you have the correct message center number
Mar 17, 2010 | Samsung Propel Cell Phone
Can't send or receive text messages anymore!
Pull the battery out while the phone is still on, wait 30 sec. to 1 min and then put it back in, should solve the problem.
*Mine has done the same thing 3 times so far, just keep pulling the battery out and put it back in until they figure out what the issue is and make a fix.*
Apr 05, 2009 | RIM Blackberry 7100i
N73 hangs/works too slow
My N73 M phone hangs, sometimes doesn't ring and takes 15-20 secs to navigate between functions. Pls help with a solution.
i have already reset the phone by using the *#7370# code, but it still remains the same....
Help me with a solution.....
Mar 30, 2009 | Nokia N73 Cellular Phone
Cant send or recieve texts or calls off my samsung tocco
hi there,
you sim card does not work the phone or the phone might lock with other provider-- try to turn off the phone - take out the battery and sim card - wait for 30 sec - put the sim card then the battery in - wait for 30 sec - turn on the mobile .. i hope you will able to make calls now.
sms thing... go to message settings - look for message center number if there is then it will be ok when you restart your phone but if you didnt find it call custoer service and ask the message center number. get it write it and you are ready to seend messages.
Best of luck.
Mar 23, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
My Nokia N73 cant recieve text messages, it can send but cant receive.... :(
you need to format your phone so that you can receive messages again...input this code *#7370# and then click yes...enter your security code...after that your phone will reboot...it will automatically on..so please wait until the phone open..after that enjoy texting again..hope this will help you
Feb 04, 2009 | Nokia Cell Phones
N73
Firstly open the menu- then go to control panel- then log -open it up - optiions clear all log.
u must store your messages in memory card and not your phone memory. Deletae unwanted messages from the message menu.
Open messages- then press options then settings then "others" then "memory in use " select use memory card .
ambove this option is the no of messages that can be stored - there type in 999. Close all and come back. to your menu.
Please feel free if u have some problems
Mar 09, 2008 | Nokia N73 Cellular Phone
Nokia N73 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
