Question about Enlight Intel Xeon 470 WATT EN-470 MP (EN470MP) Power Supply
Paper jam in printer
I have a paper jam, but i don't see any paper been jam in it.. I've check the all of the printer and couldn't find anything. Its not dust because I just air it out and still coming up with paper jam...
  • Azrul Syahriman
    Azrul Syahriman May 11, 2010
    Is everything being shut tight?
Check paper moisture content. What kinda weather are you experiencing? - very damp?
Posted on Jan 02, 2009
I had a similar problem, my printer was chewing the paper and then I was getting a jammed paper message. I looked inside but couldn't see much anything. I then removed (unscrewed) all the panels, and next I know, a culprit materialized, in other words, something fell inside the printer. I then managed to put it all back together, ended up with a few extra screws, but heck it works like a clockwork. God bless screwdrivers with magnetic tips, they made my life so easier.
May 23, 2012 | HP Photosmart C6180 All-In-One InkJet...
Problem 391 on OKI C5200 printer but no paper jam was found.
Open the top. Pull on the top of the toner cartridge (don't release the latch, just pull it up). It will come up with the toner drum assembly attached. You will probably see another paper stuck there which can't be seen when the drums are installed. Also, open the back door and look for paper that might be stuck. But usually, when you've checked everywhere else, the remaining paper is flat under the toner drums. Once you get it out, just click the drum/toner assemblies back in place (careful not to let the green drum touch anything while it's out of the printer.
Mar 06, 2012 | OKI C5200n Laser Printer
Paper jam 202.33 Check rear door. I have checked and no paper jam.
the printer has either a switch with a little lever or an electronic sensor with like a little eye, some were around that rear door. its in the paper path. it makes sure the paper moves through this area OK. I've had the little arm get stuck closed or the little eye needing cleaning. ( a buildup of paper dust makes it think there's a piece of paper there ) clean and or fix sticking lever.
Also, don't let a that little piece of paper fool You. all it needs is the switch/sensor see it. ( tricked Me more than once. ) If You have had a paper jam just before the error, ( that's pretty much Your clue! )
Sometimes just cycling the power will correct the problem.
If all of this does not help, You may have a bad switch/sensor or circuit board. if that's the case, buying a new printer will be cheaper than the service call. ( if You have one of the personal printer's, NOT commercial)
Hope this helps, Ricky L
Jan 23, 2012 | Dell 5310n Laser Printer
I have a Canon MP210 scanner/ printer that is telling me I have a paper jam but there is no paper in the machine. I've turned off the power and turned it back on, I've looked for a small piece of...
Your printer might be out of paper.. so try this..... press Black/Color button... if it doesn't work turn off your printer and press paper feeder on the back side and press the power button with holding the paper feeder. Don release it until the process of printer is complete... thanks
Aug 26, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
I've had my brother mfc-7440n for over 2 years and it's been working great until this past week. Now, it has a paper jam every single time I try to print anything, causing me to have to remove the...
85% of paper jams are caused by worn rollers . The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease. If you plan to keep your printer,
Replace the pick-up and feed rollers.
Metal Tab Separation- Pull out your paper tray and examine either end where the paper sits in. If any of the corners are held down by metal tabs, this is your paper feed system. Chances are, you only have one rubber roller or one set of rollers arranged along side of each other. Reach in where the tray goes and feel up. You should feel some rollers. They might be completely round, or they might be shaped like a half moon. Clean whichever part of them you can with the solution, and this should stop your paper jams. It might be necessary to turn them, but don't force them if they don't move freely.
Pickup Roller and Separation Pad-
If your printer uses this paper feed system, you should see a small piece of flat or slightly curved rubber or cork. It would be towards the end of the paper tray, or deep inside the paper loading cavity on top loaders. This 'separation pad' rubs against the paper feed roller, so if you find the pad, you've found the roller. Clean it and your jams should stop.
Three Roller Paper Separation System- Pull your paper tray out, and look for a roller on either end of it. If you find one, clean it. Then look inside the printer where that roller would rest with the paper tray inserted. You'll find another paper roller there. Clean this one also. Finally, look further back or closer to the front of your printer (depending on which way your paper feeds) to find another roller or set of rollers. Clean all of these, and your paper jams will go away
Jul 10, 2011 | Brother MFC-7440N Laser Printer
Cannot copy two side.paper always jam
Are you sure there is not something blocking the paper going inot the duplexer. I've had one of the fuser separation claws fall off and block the path. Now if that is not the case then check to make sure some of the sensor arms don't have paper cuts in them. This will cause an intermittent delay jam. Jam codes in service mode will also help.
Jun 17, 2011 | Canon NP 6050 Copier
I have an Officejet J3608 model printer. its showing paper jam. But wen i checked i couldn find any paper jam in the printer. wat is the actual problem with my printer?
Perhaps the paper INDETECT SWITCH is faulty and so there is a false input to the CPU. You need to check this sensor/switch on the paper transport section where it is mounted.
Also check for loose connections on the main board, check for fault in the main board if the sensor seems to test correct.
Mar 30, 2011 | HP J3680 Officejet All In One Printer
Kodak 9250 problem error code 3527 cartridge jam. i fixed paper jam and reset this by unplugging machine touching okay and problem persites. Thanks Dan
Hello. I have this problem with my current printer, esp 9250. I don't know how you resolved it but I contacted Kodak via livechat (on their website) and the person told me I had to get a new printer. I couldn't get a new printhead because she said it didn't move to the center when i opened the cover, so that means the printer hardware is broken. Needless to say, I am frustrated. I asked her if Kodak would lessen my cost by sending me a coupon or ANYTHING, and she said sorry but no. So yeah. Basically you just gotta get a new printer... :(
Dec 18, 2010 | Kodak Office Equipment & Supplies
Paper won't feed into printer. Always gets jammed
you must have objects foriegn objects inside your printer. i.e. paper clip or some other object . Get your printer and move it side to side see if you can here anything moving about. once its out then perform alignment of rollers using epson maintenance menu.
Jul 19, 2009 | Epson Stylus CX4800 All-In-One InkJet...
Computers & Internet Logo
66 people viewed this question
Top Enlight Computers & Internet Experts
Larry Maranto
Jerry Umali
Are you an Enlight Computer and Internet Expert? Answer questions, earn points and help others
