Question about Zodiac Duo Clear System Chlorine Generator
ZODIAC DUOCLEAR 25K DOESN'T FUCTIONING WELL
NEW ISTALLED ZODIAC DUOCLEAR SALT CHLORINATOR WITH THE FOLLOWING PROBLEMS:
1. THE SWITCHES ON THE CONTROL BOARD DO NOT FUNCTION
2. I CAN'T SWITCH ON/OFF THE POWER
3. I CAN'T MAKE SUPER CHLORINATION
4. THE LIGHTS FOR REPLACING THE CARTRIDGE ARE ALL ON DESPITE THE FACT THAT IS NEW (2 MONTHS OLD)
  • dknecht79 May 09, 2009
    After replacing the cartridge, the system worked but aftera week. when ever the pump turns on the duoclear panel blinks super chlorinate and then suts off. then the on/off buttom won't turn on or off.
  • Robco Water
    Robco Water Jun 24, 2014
    some of these units are dual voltage. it is possible that it was hooked up 220v instead of 110v or visa versa
I have the zodiac duoclear system and have used it for nearly two years. All in all, it's a very good system. I have had similiar issues on occassion. Have you tried the master reset button on the lower right hand face of the control board? I've been able to clear up the lights by resetting the system.
If the salt content in the pool is not correct, the system will not allow you to superchlorinate. Your salt level should be at 4000 ppm. The add salt light is programmed to come on if the system gets below 3600 ppm. When the system is below 4000 ppm, it is unable to generate the chlorine needed. The lower the salt, the less you can chlorinate. Might not be your problem, but I've run into this before too.
The lights for replacing your cartridge puzzle me. I'm making an assumption that your pool is probably dirty if you're trying to superchlorinate. The dirtier the water, the faster the electrode in the cartridge will get covered in scale from the current and conversion process. Try cleaning the new cartridge by placing it in a bucket with a 75% water and 25% muratic acid mix. Let it soak for a few minutes and gently swirl it around in the mixture. This will clean the contacts in the cartridge.
Keys with the Duoclear system: Salt content and clean the filters regularly. Don't know if this will solve your problem or not, but good luck.
Posted on Jan 26, 2009
When you tourn on the super chlorinate button, does it turn itself off?
To properly start up the system, add the salt, let circulate for 6 hrs then turn on the generator. running with extremely low salt can damage the unit. you will need a minimum salt reading of 4000 ppm with the duoclear.
when you activate the superchlorinate feature, the electrode will run at 100% for 24 hrs and then revert to the regular programmed level.
Jun 19, 2014 | Zodiac Duo Clear System Chlorine...
Zodiac lm3
The lm series chlorine generator has a tri-sensor inside the cell that measures flow, water temp, and salt level in pool. If the controller is indicating no flow after it has been cleaned properly, then the cell is most likely in need of replacement.
Jan 06, 2014 | Zodiac Lm3-24 Salt Water Chlorinator...
Duoclear can't remove salt cell
over heated cell distorted case need new case
May 24, 2012 | Zodiac Duo Clear System Chlorine...
Cannot get zodiac duoclear salt cell out flap
possible cell overheating and distorted plastic housing might have to replace
Jan 04, 2012 | Zodiac Duo Clear System Chlorine...
DuoClear 20 can't get salt light to go out unless
I have a Duoclear 25 for 3 years now. The unit has been nothing but trouble. I too have a low salt light even when the pool is tested at 4500ppm. 4500ppm for our taste is too high. The main board has been replaced for erroneous errors and now one year later the salt cell generator is non functional. The quality is poor. Furthermore most pool stores don't even know how the nature 2 works and alwasy recommend chemicals that are harmful. The company Clearwater has poor customer service.
Aug 25, 2009 | Zodiac Duo Clear System Chlorine...
DuoClear 25 doesn't chlorinate well, chlorine output lights
have water checked see if chlorine is locked that will act like chlorinator not working also crack output union so water drips out test with strip if chlorine oxidize water if no chlorine unit not working
Jun 12, 2009 | Zodiac Duo Clear System Chlorine...
Zodiac Duo Clear System  Chlorine Generator Logo
1,876 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
