Question about Symantec AntiVirus 10.0 with Groupware Protection Business Pack for PC
How to enable auto Protect in Symantic anivirus 2006
Enable Auto Protect(Disabled)
is the message that comes in the Configure.>autoprotect
How do I enable auto protect to ensure that SAV is resident to monitor the virus threat.
Regards Vishen
    President:
  • 949 Answers
Want to turn on Auto-Protect permanently
1 Start Norton AntiVirus. If Norton AntiVirus is part of Norton SystemWorks or Norton Internet Security, then start that program. 2 Click Options. 3 In the left pane, click Auto-Protect. 4 In the right pane, check Enable Auto-Protect and Start Auto-Protect when Windows starts up (recommended). 5 Under "Select the duration," select Permanently from the drop-down menu. 6 Click OK. 7 Exit Norton AntiVirus. 8 Restart the computer.
Posted on Dec 30, 2008
Upside down screen on ipad
The Auto-rotation setting must be disabled. Enable it on the settings menu. Or if your tablet is running iOS 7, then enable auto-rotation on the Control Center. Simply swipe up from the bottom of the screen to launch control center. (It is like the opposite of pulling out Status Bar or Notifications Bar above.)
Apr 22, 2014 | Apple iPad 2 Wifi 16GB
Game on ps3 won't load automatically
There's a setting on your PS3 which has likely been disabled. There is a Disc Auto Start in the System Settings Menu. Make sure that is set to 'Enabled'.
Jan 01, 2011 | Video Game Consoles & Games
How to enable Symantec auto protect
There are couple of ways to enable Symantec auto protect.
Step 1: Right Click on the little shield like Icon on system tray (Right next to date and time). Left click once on enable Auto Protect.
Step 2: Click on Start and then all Programs. Look for Symantec Client Security and then Symantec antivirus. Click on the Configure Tab and click on file system auto protect. Check the Option Enable Auto Protect and then Click on OK.
Dec 18, 2010 | Symantec AntiVirus 10.0 with Groupware...
I disabled it from the Device Manager, how do I re-find it and re-enable it?
If you just disabled it, go back into Device Manager and it will automatically show with a large X over the icon of the disabled device. You most probably Uninstalled it in which case, a restart should let Windows auto detect it again. Go in Device Manager again to view and enable it if needed.
Dec 02, 2010 | LG GCR 8523B Internal 52x CD-ROM Drive
Please can you give steps to disable the onboard usb controllers to use the CPI USB Card. I've installed the PCI Card after the onboard stop working
2.4.2 USB Configuration
The items in this menu allows you to change the USB-related features.
Select an item then press <Enter> to display the configuration options
USB Function [Enabled]
Allows you to enable or disable the USB function.
Configuration options: [Disabled] [Enabled]
Legacy USB Support [Auto]
Allows you to enable or disable support for USB devices on legacy
operating systems (OS). Setting to Auto allows the system to detect the
presence of USB devices at startup. If detected, the USB controller legacy
mode is enabled. If no USB device is detected, the legacy USB support is
disabled. Configuration options: [Disabled] [Enabled] [Auto]
USB 2.0 Controller [Enabled]
Allows you to enable or disable the USB 2.0 controller.
USB 2.0 Controller Mode [HiSpeed]
Allows you to configure the USB 2.0 controller in HiSpeed (480 Mbps) or
Full Speed (12 Mbps). Configuration options: [HiSpeed] [Full Speed]
BIOS EHCI Hand-off [Disabled]
Allows you to enable support for operating systems without an EHCI
hand-off feature. Configuration options: [Enabled] [Disabled]
NOTE!!!
Do not disable the BIOS EHCI Hand-Off option if you are running a
Windows® operating system with USB device
hope above given details with give you a detailed description as you desired.
good luck
Feb 04, 2010 | ASUS P5LD2-VM Motherboard
In setup
Here are the settings.
The fine clock ratio stayed at 0.5 after I loaded optimized defaults.
Robust Graphics Booster___________ [Auto]
CPU Clock Ratio ____________ [8]
Fine Clock Ratio ____________[0.5]
CPU Host Clock Control_ [Disabled]
CPU Host Frequency (MHz)__________ [333]
PCI Express Frequency (Mhz)_______ [Auto]
C.I.A. 2__________________________ [Disabled]
System Memory Multiplier (SPD)____ [Auto]
DRAM Timing Selectable_______ SPD __ [Auto]
Performance Enhance = [Turbo]
CAS Latency Time________________ Auto (7)
Dram RAS# to CAS# Delay_________ Auto (7)
Dram RAS# Precharge Delay_______ Auto (7)
Precharge Delay (tRAS)__________ Auto (20)
ACT to ACT Delay (tRRD)_________ Auto (4)
Rank Write to READ Delay________ Auto (5)
Write to Precharge Delay_________ Auto (10)
Refresh to ACT Delay______________ Auto (60)
Read to Precharge Delay__________ Auto (5)
Static tRead Value_______________ Auto (6)
Static tRead Phase Adjust________ [Auto] (0)
CPU/PCIEX Clock Driving Control [800mV]
CPU Clock Skew Control [normal]
GMCH Clock Skew Control [Normal]
System Voltage Control____ [Manual]
DDR2 OverVoltage Control__ [normal]
PCI-E OverVoltage Control_ [normal]
FSB OverVoltage Control___ [normal]
(G)MCH OverVoltage Control [normal]
CPU Voltage Control_______ [1.25]
Limit CPUID Max. to 3.....................: [Disabled]
No-Execute Memory Protect............: [Enabled]
CPU Enhanced Halt (C1E)................: [Disabled]
C2/C2E State Support....................: N/A
x C4/C4E State Support..................: N/A
CPU Thermal Monitor 2(TM2) ...........: [Enabled]
CPU EIST Function.........................: [Enabled]
Virtualization Technology................: [Enabled]
Integrated Peripherals
Legacy USB Storage Detect___________________[Enabled] *Note* Must be enabled to flash from USB
Hope this Helps, Please Rate My Response! Thanks!
PREM
Feb 20, 2009 | Gigabyte GA-8S661FXM-775 MATX MBD SIS661FX...
Update problem with symantec antivirus
Close the antivirus program and reopen it. When it isclosed, the icon yellow for norton will not appear on bottom right hand side along with volume icon etc. You may also restart the computer to see id that helps. Right click the Norton icon and see id it says ENABLE AUTOPROTECT or DISABLE AUTOPROTECT. Try enabling.Try the same update after a while. If that does not work, try reinstalling Norton. I get 100s of viruses from 100s of friends and all sorts of things happen to me anti virus etc
but I am told that pretty normal
Dec 13, 2008 | Symantec Norton AntiVirus 2008: Windows
Auto protect
May be your infected by virus that your autoprotect cannot delete it. try uninstall and reinstall the autoprotect program in your system do not forget to update.if see same problems try any potent antivirus like kaspersky, AVG and many others.
cheer,
mel
Dec 04, 2007 | Microsoft Office Outlook 2003 for PC
Symantec AntiVirus 10.0 with Groupware Protection Business Pack for PC Logo
600 people viewed this question
Top Symantec Computers & Internet Experts
Tony
Are you a Symantec Computer and Internet Expert? Answer questions, earn points and help others
