Hotpoint WF640 very noisey drum bearings.
The washing machine is starting to make more and more noise from the drum. I suspect the bearings are worn. Is this a cost effective repair or is it better to replace the machine these days? If the repair is feasable can I do it myself?
  • torres07 Mar 29, 2009
    what is the easiest way to replace bearings on a hotpoint wf640 machine
  • 115 Answers
That is the bearing and it is not feasible to fix it is about a 2 hr job for a technician so it wouldnt be something you want to tackle I guess I am saying out with the old and in with the new sorry for the giver of bad news
Posted on Dec 30, 2008
Stiff drum.
You can attemt to take the side panel off the machine and look around with a flashlight. if there is something stuck it will be very apparent.
Apr 08, 2014 | Hotpoint Washing Machines
Hotpoint aquarius wml760 noisey when spinning with stuff in but ok empty
more than likely the rear bearing has gone bad and when a load is applied the difference in weight distribution causes the knocking.
Jun 15, 2012 | Hotpoint Washing Machines
Black powder and noisey spin on hotpoint washing machine
Black powder sounds like brushes are wearing down. If noise is severe, suspect bearings. With door open try wiggling the drum up and down. If it moves inside the tub, replace the bearings. Try new brushes first!
May 15, 2012 | Hotpoint Washing Machines
Hi, My washing machine drum appears to be loose. When the drum is turning slow it seems to go side to side as well as rotating. When the spin initially starts the drum seems to bang on the sides of the...
Sounds like worn drum bearing however check the top spring is not snapped.Remove lid you will see if spring is broken if not and suspect bearing its quite an expensive job,do you know Hotpint have a 5 year warranty on parts only call charge is around £105........Worthwhile considering as the parts would cost around this to buy excluding labour...Good luck
Jun 06, 2011 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wf640 makes too much noise whilst spinning level of machine is balanced perfectly makes same noise on every selected speed
sounds like the bearing but could also be the drum support bearing more likely discontinue use until it is sorted or it will collaspe completely or you will experience black oil marks on clothes or tearing, if in guarantee call the manufactuer.
Mar 31, 2010 | Washing Machines
Hotpoint aquarius WMF740 (1 year old) - noisey spin
its the drum bearings there worn out try opening the door and lifting the top of the drum with your fingers if there is any life and the drum drops back when you let it go its them bearings,, then spin the drum by hand is should grumble or growl,,,if it dont do any of this, it could be the "spider" broken off, its an ally part that holds the drum bearings and the drum up,
Mar 07, 2010 | Washing Machines
Noise when agitateing wash only
Remove the belt, and spin drum by hand from inside, there should be little or no noise, if there is then it is possible the drum bearings are failing.
I f no noise, but there is when you put belt back on, then possibly bearing in motor noisy
Mar 06, 2010 | Hotpoint WMA66 Front Load Washer
Washing machine noisey when drum turning
Hi, Try these out:
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion...
May 18, 2009 | GE WJSE3110A Top Load Washer
Noisey washing machine
i had the same problem check the holes inside the drum for a bra wire stuck in one of them which was my problem we also thought the bearings had gone but they were not hope this helps
Oct 15, 2008 | Hotpoint Aquarius WF000 Front Load Washer
How to replace drum bearing for hotpoint aquarius+ wf740
My machine is just over 3 years old and although there is no play in the rear drum bearing it is very noisey on spin.
It gets progessively loud the faster the spin speed.
Jun 18, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
412 people viewed this question
Top Washing Machines Experts
