Question about Yamaha HTR-5850 Receiver
Yamaha HTR-5850/5840 AV receiver
I used the "silent cinema" option to listen with headphones. Now, even if the headphones are not plogged anymore, the "silent cinema" indicator lights are still up in the front panel display. I can't get rid of it and of course, there is no sound coming out. Thank you for your help and suggestions.
SOURCE:
avenger77
SOURCE: Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Solved problem with Yamaha HTR-6040 AV Receiver. My daughter had inadvertently changed the program to "Direct Stereo" mode which allows sources to bypass the decoders and DSP processors so you can listen to 2-Channel PCM and Analog sources. Nothing to decode digital audio in this setting!
Posted on Aug 10, 2008
SOURCE: Yamaha HTR-6130 Front right and left speakers with no sound
As simple as this sounds, try hitting the speaker a/b button on the front of the unit, next to the headphone jack. I had the same problem, and was about to package the whole thing back up and go back to Best Buy when I hit this button and then the audio test worked.
Posted on Dec 05, 2008
SOURCE: Bi-Amping my speakers with HTR-5850
You can at a minimum, bi-wire your speakers by wiring the speakers with the A and B speaker outputs. The A speaker outputs end up running the tweeters and the B will end up powering the woofers.
Posted on Dec 30, 2008
  • 4234 Answers
SOURCE: no sound from htr-5840 when switched on. I hear
These units have protection circuits that will prevent the speaker relay from engaging if there is a problem detected. There is also a circuit that causes a delay in the engaging of the relay to allow the amp to "settle in". This prevents the old "thump" that was common in older models when the set was first turned on. In your case, either the RC circuit is faulty causing excessive time to pass before turning on the relay, or there is excessive voltage floating around that the protection circuits are detecting and thus preventing the relay from turning on.
In any case, this will require additional diagnosis using some test equipment. This is not a problem that will be easily resolved remotely. Please bring this unit to a repair shop for an estimate. Once you have that info, we can assist with the actual repair.
Dan
Posted on Aug 25, 2009
  • 128 Answers
SOURCE: How do I connect pc to htr-5850
You will need an adapter cable available on ebay or at radio shack.
Should have a 1/8" mini male stereo plug on one side and a set (left and right) male RCA plugs on the other end.
Simply plug into the output of your sound card or motherboard (usually blue or green) into any available input (EXCEPT PHONO) on your receiver.
select that input and it should work
hope that helps
Posted on Jan 12, 2010
Stuck in headphone mode
There should be a cable going to the headphone pcb. If you unplug that cable, it should clear the false h/p detection that is happening. Of course, you won't be able to use the headphones then. To completely fix it, you would have to replace the headphone jack.
Jun 19, 2013 | Yamaha Audio Players & Recorders
Tip
Reset factory default settings for yamaha HTR-5650 AV receiver
How to reset yamaha HTR-5650 AV receiver (maybe others) to factory default settings:
1. turn power off.
2. press the 6ch input and stereo button simultaneously for 4 seconds. Then while holding down these 2 buttons, turn the power on.
3. press preset tuning to the right until option #9 is selected.
4. Then, press program button until the *RV option is selected.
5. turn power off, wait 10 seconds.
6. turn power on, settings are reset.
on Feb 10, 2009 | Yamaha HTR-5650 Receiver
Yamaha receiver silent cinema
are there headphones plugged in? Otherwise something is wrong with the headphone jack probably.
Apr 21, 2013 | Yamaha RX-V363 Receiver
Where can i get firmware download for yamaha htr-3063
Hi al_sha,
Please be informed that Yamaha did not release firmware that can be downloaded by users, however they provided a step by step procedure on how to update the version of your unit. Please visit this link to have the Firmware update procedure for Yamaha HTR-3063.
Hope it helps.
Thank you for using FixYa.
Jun 16, 2011 | Yamaha HTR-3063
How do I reset my yamaha receiver htr5730
http://www.retrevo.com/support/Yamaha-HTR-5730-Receivers-manual/id/1075bh230/t/2/
Page 52
1 Hold down STEREO on the Front Panel
"Factory Preset" appears on the front panel
2 Press STEREO to select the desired setting.
'Reset' To reset to factory presets
'Cancel' to cancel without making changes
3 Press STANDBY/ON to confirm your selection
Jan 15, 2011 | Yamaha HTR-5730 Receiver
I have a yamaha htr-6160 AV receiver. I have hooked up my DVD to it using using component video cables but I can't sound out. Video no problem but no sound.
it is sad your having a sound problem with your Yamaha
to resolve these problem , check the audio out settings of your DVD
player, it might have been set to digital and not analog.
Dec 26, 2010 | Yamaha HTR-6160 Receiver
What connections do I use to plug in my iPhone to listen through my receiver?
Use a 3.5mm headphone plug to rca cable. Can be picked up at any electronics store or even check your local wal-mart
Aug 04, 2009 | Yamaha HTR-5740 Receiver
Is Yamaha HTR-640 a receiver? Try HDMI from PS3 to receiver or Sony HDTV. If HDMI from PS3 to receiver the you need and HDMI from receiver to out Sony HDTV. You could connect everything to receiver and HDMI out to HDTV. You can not have an HDMI cable AND an optical cable coming out of the PS3, only one or the other.
Dec 30, 2007 | Yamaha HTR-6130 Receiver
Sound cutting out
I'm presuming you are referring to a Yamaha HTR,right???(Night Listening Enhancer (Cinema/Music) and SILENT CINEMA)..see page 32 in this manual at this link,here's the owner's Manual,also available to download for free in .pdf (Adobe) format.......https://www.manualslib.com/manual/197349/Yamaha-Htr-5940-Av.html
May 09, 2017 | Yamaha HTR-5850 Receiver
Yamaha HTR-5850 Receiver Logo
109 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
