110volt washing machine mistakenly connected to 220 volt,
Wihtin seconds I have disconnected the machine from the power, but when I tried to put on by connecting to 110volt, not working now, what would be the problem, its a Hitachi top loading automatic washing machine, is it a major problem?
    Habit-Forming:
  • 36 Answers
If you connected it to 220v you may have fried any parts that are 110v specific
Posted on Jan 02, 2009
How long will a 28v drill last with a 36v battery
about 1 minute before it burns out
28 volts require 28 volt power supply and just like a 110volt connected to 220 volts the end result is the same -- up, up in a puff of smoke
Apr 26, 2016 | Drills
How to fix after putting in 220v to110v
not sure what problem is ,driers even in US are 220 not 110
Jul 09, 2015 | Dryers
Worrng fully supply 220 volt in xerox 7345 110v now this machine is showing error like 009-383,380,382 and after NVM reset one or two copy diagonal bar type print come out and then code is come -
The last time I looked at one of these power supplies I'm sure you had to move over a small sheet metal cover but putting 110volt onto a 220 volt power supply shouldn't cause a problem the other way probably would. However as you seam to get prints out of the machine I don't think you have a power supply problem.
Further investigation needed.
Good Luck.
May 03, 2015 | Xerox Office Equipment & Supplies
Conection 220volt in A 110VOLT
Hi
You've made a great mistake indeed. Contact any service technician. With some sets, there will be a protection fuse [over voltage protection]. If your set have been included this protection device, your luck. If not, you might have to replace the power supply section to this device.
Gopakumar Gopalan Google
Feb 26, 2014 | Pioneer CDJ-800MK2 Turntable
We bought electrolux washing machine ewf 85761 in penang malaysia, before we brought on board ship test is done on the store,the washing machine is in good condition..Then we brought the washing machine on...
Just as a wild guess, the control circuit in the washer may not work with 60 Hz shipboard power. The motor probably is not affected. You must be getting awfully tired of hauling that washer back and forth!
Sep 07, 2012 | Washing Machines
Washing machine w/ 110v plug in to 220v
DON'T!
Never plug a 110 volt anything into a 220 volt supply and never plug a 220 volt anything into a 110 volt supply. They are just not designed to do so. Their electronic's power supply and their motors are specifically for the specific voltages. Changing the plug at the end does absolutely nothing.
I just hope I have got to you in time!!!
John C
retired Englishman in SW France
Feb 19, 2011 | LG Washing Machines
110volt or 220 volt are in use for this speaker
if u got the speakers from countries which use 110 u have it with 110 and if u got it from countries using 220 u have it with 220 capability
Feb 01, 2011 | Labtec LCS 2424 Computer Speakers
I own a Pioneer DVR-220 dvd recorder and my problem is that the unit will not power up. I've tried disconnecting the ac power cord from the Monster Power power source and connecting the power cord via an...
I replaced two capacitors, (1) 10 volt, 1000uf and 10 volt 3300uf..They both sit on the power board that can be removed from the unit..You will have to unsolder the bad capacitors and put in the replacements..This wasn't hard to do...
Jun 26, 2010 | Pioneer DVR-220 DVD Recorder
Plugged a 110 volt kenwood receiver accidentally to 220 volts
Considering 220 and 110 systems have different receptacles, you worked at doing this.
Since it is already inoperable, you may as well remove the housing and inspect the guts. If you see burned traces or boards, don't bother to have it repaired.
If you see a fuse in a clip, you might replace it once, two would be the waste of the second fuse.
Aug 23, 2009 | Harman Kardon AVR 135 Receiver
Change gas/110volt fridge element to gas 240volt
You need transformer converter 110 to 240VAC.
Regards ,
Edgz
Jan 26, 2008 | Refrigerators
Washing Machines Logo
Top Washing Machines Experts
