Question about Maytag Dependable Care LAT9706
Maytag model MAV5000AWW won't agitate. All other cycles OK.
Motor continues to run. The machine sounds like transmission is operating properly but the agitator only moves very slightly with only water in the tub; no movement when loaded with clothes.
  • 11 Answers
SOURCE: Agitator not working on Maytag PAV2300
Sorry to be the bearer of bad news, but the transmission in your unit is bad,it has internal gears and the ones involved in the agitation are broke or bad, to replace the transmision is a lengthy process, your best bet is to just scrap it and get a new washer. I don't know if you know this but maytag company is no longer in business. They were purchased by Whirlpool back in November of 2006. One of the reasons is all the poor quality of their appliances. I am a technician that has been doing this for 15 years. The best unit I have seen to date is the Whirlpool Duet. I hardly ever have to work on them. Sorry for the bad news. Hope this helps.
Posted on May 20, 2007
SOURCE: Maytag won't spin or agitate
I have had the same problem and found that the teeth on the under side of the agitator had been worn down to nothing... I assume this is from years of over loading (not from me) and so the agitator could not spin any more... i would tighten the bolt that holds th agitator on and it would come loose after a few loads. So my solution was to get a little bit longer bolt and newer plastic washer and tighten it as tight as i could and it seemed to work. Versus buying a new agitator base that would cost about $20-$30 and would have to wait for the part to be ordered. hope this helps
Posted on Oct 23, 2007
IFIXALL
  • 868 Answers
SOURCE: Maytag Performa washer dead.
Your door lid has a switch that makes these functions work.First open the lid and look at the right side of it.Does it have a arm on it?If it does follow the direction where it is going to hit and now listn closely while your lifting the door up & down at this contact  can you hear it click?If its not clicking  or the arm is broken  off the lid replace  the lid switch/or the broken lid switch arm.
Posted on May 23, 2008
huuum
  • 750 Answers
SOURCE: Maytag Atlantis black oil like residue and can't remove agitator
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
this is a very common happening and it means
This usually means that a seal is degrading or dissolving.
This washer is a top loader, Right!
I believe it calls for HE ( High Efficient) laundry detergent.
If we use to much of either it will cause this !
This usually happens due to using to much detergent or bleach.
You said, Black oil like residue discharged from washer during use. Stain clothes, almost impossible to remove. Loosened nut on agitator but it will not budge, and am afraid of damage if I try to pry between agitator and bottom of drum.
Please remember to leave a rating before you go!
Thank you
Posted on Sep 28, 2008
SearsTechToo
  • 261 Answers
SOURCE: maytag mav6200aww removing inner tub
I broke a hammer removing the basket on a 6000 series today. These are known to be a real ***** to remove. Once those screws are out there is a seal nut to remove and the basket hub assembly is what it sits on. Look at 5 and 7 below.
Posted on Oct 12, 2008
Maytag Model LA610 - Newton - old style counterweight transmission (mfgd.1981)
check motor coupler, agitator spindle, drive block and shaft, cam dogs and motor windings
Mar 23, 2017 | Washing Machines
My candy GOFS262 washing machine is filling the drum to the top with water on every cycle but doing nothing else after that, the clothes jst sit there in the water, I've left it to see if something...
see this causes and fix it. God bless you
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission.
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Oct 11, 2012 | Washing Machines
Hi, I have a Maytag Alantis Washer (model: MAV
Does it not spin just in the final cycle or not at all during the wash cycle? Also, does the wash cycle agitate normal?
Regards,Richard
Nov 07, 2011 | Maytag Washing Machines
It does not agitate when in the normal cycle and does not drain.
"Does not agitate" sounds like a broken or worn drive belt. "Does not drain" sounds like a broken or worn pump belt. Since it is unlikely that both belts are bad, I suspect that the next common link, the drive motor, is bad, i.e. your drive motor is either defective or not getting power during the agitate and spin cycles. The primary symptom for a non-operating drive motor should be obvious, i.e., the machine just doesn't run after the wash fill, and it doesn't empty when the timer advances to the spin/drain cycle. If the drive motor does sound like its running, I would then inspect both belts and drive motor pulley for proper operation.
Oct 04, 2009 | Maytag Dependable Clean Top Load Washer,...
Maytag Atlantis 6451 noise when on and agitator doesn't work.
it does sound like a bad motor.
they are rather expensive on that machine,
you would be looking at 300 or so
May 28, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Washer fills no agitation spin cycle ok
It doesn't agitate If your washer doesn't agitate, check these:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission The transmission could have either of these problems:
  • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
  • The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
May 07, 2009 | Washing Machines
Neptune washer will not go past the first wash cycle
All functions operate normally except the machine will not agitate.
The agitator is driven by a couple of different methods. The first is the agitator is splined and slips onto the matching splines of the agitator shaft from the transmission. The second is the use of a bell coupling which is splined to the agitator shaft as well and the agitator snaps onto the coupling. If the agitator does not agitate, first remove the agitator and watch the agitator shaft to see if it is working properly. This will require a small load setting of water and the machine set to run. If the agitator shaft is working properly, it is either the splines on the agitator or the bell coupling that is defective. If the agitator shaft does not work properly, the problem is in the transmission.
Apr 07, 2009 | Maytag Neptune FAV6800AW Top Load Washer
My washer wont agitate ?
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Feb 07, 2009 | Maytag Performa PAV2200
Maytag washer won't agitate
your transmission is no good and needs to be replaced
Dec 14, 2008 | Washing Machines
My Kenmore series 70 washer will wash and then the machine stop. If I move it to the rinse cycle it will start agitating again and then it will shut off again. It seems li9ke the spin cycle isn't working
Welcome
Either of these three problems may be occurring.
Faulty Direct Drive Coupling (Whirlpool / Kenmore / Roper / Estate)
The Direct Drive (motor) Coupling may be broken. Many Whirlpool/Kenmore brands washing machines utilize a small, relatively inexpensive direct drive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other.
It can wear out over time or fail under overloading conditions. This protects your transmission from excessive loading.
Defective Lid Switch
Check lid switch for proper operation. Check the switch for continuity. If it is found to be open, replace the switch assembly.
The agitator is driven by a couple of different methods. The first is the agitator is splined and slips onto the matching splines of the agitator shaft from the transmission. The second is the use of a bell coupling which is splined to the agitator shaft as well and the agitator snaps onto the coupling. If the agitator does not agitate, first remove the agitator and watch the agitator shaft to see if it is working properly. This wil require a small load setting of water and the machine set to run. If the agitator shaft is working properly, it is either the splines on the agitator or the bell coupling that is defective. If the agitator shaft does not work properly, the problem is in the transmission.
Thank You Please remember to leave a rating.
Dec 12, 2008 | Kenmore 23822 Top Load Washer
Washing Machines Logo
156 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
