Question about Bosch Classixx WFC 2465 Front Load Washer
My Bosch Classixx 1200 washer causes the household RCD to trip
At certain points in the wash programme the washer causes the RCD on the household electrics distribution board to trip. This happens on a variety of programme settings. Any advice??
  • Anonymous Mar 23, 2014
    Washer is causing the electric to trip
  • Bosch Master
  • 3,463 Answers
The first thing I would recommend u do is to remove the motor and check the carbons for wear, Their should be at least 3mm of carbon showing, any less then u shud replace.
The other possibility is a faulty heater element, u cud try it with the element disconnected, if it does not trip then the element is faulty.
Plz rate my solution.
thanks.
Posted on Dec 31, 2008
Bosch diswasher,model Sms68m02AU trips circuit breaker
rcd units trip from the milliamps that are in a short
it trips the rcd to prevent electrocution and acts in nano seconds besides being a circuit breaker for excessive current
the trip can be from moisture allowing a current leakage to ground or some other simple operation
I suggest that you get in a qualified electrician / bosch service technician to find the reason for the problem rcd
Sep 15, 2016 | Bosch Dishwashers
Bosch Classixx 1000rpm. Trips out RCD each time turned on. Am able to use other appliances in same power point. Only 3-4 years old
If the RCD is tripping then the appliance has an earth leakage fault. You should remove the plug from the power point and not use it until you get it repaired. This is a potentially dangerous fault, and the RCD is telling you it is faulty.
May 19, 2016 | Bosch Washing Machines
Bosch 1200 classixx trips fuse unit
Possible that the program controller unit is faulty, it is possible that the power supply is short and so trips the fuse.
Remove the power panel and check for shorting, if so the program controller must be replaced.
Jun 27, 2012 | Bosch Exxcel WFO 2264 Front Load Washer
Our Bosch washer leaks but only during the spin cycle.It is a Classixx.
Try cleaning the detergent draw somtimes this can cause water to spill out and ofcourse check the filter and exit pipe :)
Hope this helps
TalkAppliance.co.uk
Apr 12, 2012 | Bosch Washing Machines
My bosch 1200 classixx express washing machine trips the RCD halfway through a cycle on a 30/40 wash.
Could be the heating element disconnect the wires to the element then tape them up of course make sure the plug is out before attempting any work,with the heater disconnected the machie may show another fault as not heating however should at least stop short circuit....
Jan 03, 2011 | Bosch Washing Machines
Bosch classixx 1200 washing machine stalling mid-cycle
I`ve just spoken with Bosch Product Advice service about this problem. This could be happen when door is open after programme has been started. I didn`t check yet is working.
Thanks, roman
Mar 31, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosh 1200 classixx does not finish the program, conditioner stays in the dispenser
I have cleaned the pipes going for rinsed water,plus the plumbing stuff like vertical pipe which has on top something like coupler for washing machine and dishwasher, here was problem. It was cloged up with rubish and becouse the pump could not make enugh pressure the machine has stopped in the moiddle of washing as it could not rinse.(Spin)
cheers
Sep 23, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Bosch classixx 1200 express
Not a programme error but carbon brushes on motor.Fixed by local engineer.
Aug 30, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Bosch Classixx WFC 2465 Front Load Washer Logo
1,105 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
