Question about Kenmore 23313 Whispertone Bagged Canister Vacuum
Can't shut off my vacuucm, it keeps on working despite the fact that I place it on OFF.
My vacuum keeps on working even when I turn it off. The only way to shut it is to pull the plug out of the outlet. I have unscrewed the nozzle and checked the switch, i have also taken out the switch and it still does the same thing.
I have resolved this issue, I just opened the nozzele and checked the wires for any damaged ones. In deed one was damaged, therefore i soldered it.
Posted on Jul 04, 2007
My rainbow stop working.no red lights.3 times try to start and then switch off by itself.what should I do?
PDF]3 - Rainbow
rainbowsystem.com/.../Rainbow_e2_2011_R14449A-1_English_P...
RexairAs part of Rexair's Customer Care program, each Rainbow and Power Nozzle receives a ... If the Rainbow is not working ... Do not clean the unit or unclog the hose until theRainbow is switched off and the plug is removed from the wall ..... alone or with the Jet Brush attached. ..... The Power Nozzle brush is stopped and.
My Rainbow Vacuum Cleaner Won't Turn On ' eHow
Rainbow keeps shutting off Vacuums Questions & Answers ...www.fixya.com > Forum > Tags > keeps shutting off > VacuumsRainbow vacuums keeps shutting off related questions and answers. ... My Rainbowstopped running I was using the Rainbow and it stopped running. ... the switch . my electrolux has the same problem but wont always turn on.so it probably is ...Three common problems with Power Nozzles and how to fix ...
Dec 03, 2015 | Rainbow Vacuums
Why would the filter in the ball keep unlatching while vacuming? The ball get hot also.
Hi there, it's Jack at Dyson.
Please be assured it's normal for the Ball to become hot in use. This is where the motor is housed, to give the vacuum a low centre of gravity. The motor will generate heat as it runs, but it's protected by a sensor which will shut the vacuum down for protection if it starts to overheat.
However, the HEPA post-motor filter should stay in place in use. It's worth checking the filter is correctly in place, as shown in the video below. Press the filter firmly down into place until you hear an audible 'click' from the release catch:
If you're confident the filter is still coming out of place in use, despite being correctly and securely fitted, we should be able to help you further. Please give our experts a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Jul 23, 2014 | Dyson DC25 All Floors Bagless Upright...
Hoover uh70035b
If it shuts off after being used for a whirl and won't come back on for a while it is probably overheating. The heat sensor shuts the machine off and won't let it turn back on until it cools down. If this is the issue it could be the filters are clogged and not allowing enough airflow to keep the motor cool. Most bag less vacuum filters should be replaced frequently even if they are cleaned regularly.
Oct 30, 2013 | Vacuums
My back wheel won't roll on my electrolux 2100. If I turn the cannister over, I can spin the wheel, but when I place it right side down, it just drags on the floor. How do I replace it?
Hi you need to find a local Vacuum repair place one that deals in Electrolux, and go there and take the vacuum or the make and model, and ask for a replacement part, that is the only way that you would be able to obtain spare parts, in fact while you are there, perhaps even inquire as to how much it may cost to do it? ask for a "Quote" and go from there.
Oct 07, 2011 | Electrolux UltraLux 2000 Bagged Canister...
My vacuum turns on for a second and shuts off. I have replaced the bag and filter, and it still happens. The replace bag light turns on after I do this.
1. Detach the hose and turn on. If it runs, place hand over opening. If it shuts off, the control valve assembly is dirty or worn out and needs cleaned/replaced. This is a job that should be done by an authorized Aerus Electrolux service tech. It's most commonly caused by use of "made-to-fit Electrolux" bags, rather than the genuine bags made by Home Solutions.
2. If the vacuum keeps running after detaching hose and placing hand over in port, then check the hose. Drop a coin or similar small item through the hose. If it doesn't go through, there's a clog. It will probably be at the bend of the handle. Plug hose into exhaust port and turn vacuum on. Make sure the other end of the hose is in a bag to catch the dirt and stuff coming out. If you have problems, it's easily removed by a service tech.
Dec 04, 2010 | Electrolux Epic 6500 Vacuum
What do to if keeps spitting things out even if new bag is in?
It sounds like the roller brush is going, but the vacuum isn't working, i.e., no suction.
If you have a canister vacuum, disconnect wands from hose and place hand at end of hose. If there is suction, it's fine. If not, disconnect hose from vacuum, turn on vacuum, and hold hand to intake. If there's suction here, then the hose must be clogged; or holey hose can result in greatly reduced suction.
If it's an upright, the hose could be clogged. Or the fan broken, which would also result in no suction. It would help to know what model you have.
Oct 21, 2010 | Oreck Vacuums
Belt Keeps Coming Off
Replace the belt with afresh, proper sized one. Yours is stretched. It will be shiny on the underside. hoover belts are meant to fit snug. Check the bearings on the end of the brush roll to remove dirt and thread. The proper belt will need to be stretched into place using the brush for leverage. Likely that your low carpet is more dense causing enough drag to throw the stretched belt.
Sep 13, 2009 | Hoover U6616-900 WindTunnel Bagless...
My vacuum will not pick up even fuzz on the carpet
If the suction is strong through the hose and its still not picking up, then something is definately clogged despite the strong suction and rolle brush. Check all inspection tubes including the main dirt channel behind the roller brush. You may find something that keeps getting in the way when dirt or hair is trying to bypass through.
Jan 23, 2009 | Kenmore 31913 Progressive Direct Drive...
U5180-910 vacuum shuts off on own
I had same problem. Turned out to be the filter that sits above the waste cannister. Remove the waste cannister. There is a little orange lever that releases the filter. It was caked with dirt not allowing any air flow causing the motor to overheat.
This foam filter gets dirty pretty fast.
Nov 18, 2007 | Hoover U5180-900 Vacuum
Same Shut Off Problem as Hamster71
The part that you call the particle size sensetivity adjuster is bad. There are 2 seals in the assembly, the lower seal is slipping out of place because the plastic lip which keeps it in place is broken. Split housings and replace part. This machine is alot of work to take appart and get back together correctly. Might want to bring to local vac shop. good luck.
Nov 15, 2007 | Vacuums
Kenmore 23313 Whispertone Bagged Canister Vacuum Logo
129 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Marvin
Marvin
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
