Rear tail light blew out replaced and still doesnt work
SOURCE: My 2003 750 shadow spirit tail light/brake light is always on
Ensure the bulb is correctly fitted!!
You must have a foot hand brake switch mal-adjusted / faulty. back them both off (If possible) and it should extinguish.
Does it still work with headlamps off?? If so then one of the switches are faulty / need adjusting.
SOURCE: my honda hornet 250,99 model has a problem with
do you have a high beam when you switch it to high?? i ask because this will help find the fault. get a test light this is the first tool i get when things like this come up. start at the head light plug and check for power high beam and low beam. No power check the same at the switch plug, Nothing go to the switch and check for power in got that but no power out your switch is likely at fault. if your pass light is working then you should have power in. check that and if you have no love please let me know and i'll gladly help you with more things to check
Good luck
Mark
C.C. Motorsports
Testimonial: "i will try it and let you know,cheers "
SOURCE: Hi all, got a prob with no rev tacho,neutral light
I would lean more to checking your battery, sounds like a charging problem
Testimonial: "This did happen just after i topped the battery up BUT also put a new indicator on connected into the head lamp loom.Cant see loose wires?"
SOURCE: 00 CBR F4 brake lights dont come on when applied
Have you tried powering the brak circuit itself at bulb. If it comes on then you need to find broken wire between light and switches. Since neither work if you can trace to where they meet break should be behind that.
This is on my Brother Wolfin Soulhunters bike & we still have The Proublem of no tail light, the Headlight turn & brakelights work fine...Still trying to locate the proublem so we can repiar it...Can any one Help us?
