Question about Frigidaire FRT21H8 Top Freezer Refrigerator
Bad vibration problem
I pulled the refrigerator out from the wall yesterday to clean it. Blew the coils out and vac'd out under neath. Pushed the unit back against the wall and now it is making a terrible vibration noise. Could it be an easy fix before I have to call a repai$$ man. Thanks
  • 115 Answers
It is probably sitting uneven roll it back out and try to get it in the same exact spot it was before you vac it
Posted on Dec 30, 2008
Frigidaire refrigerator side by side model FRS26ZTH water on floor of freezer
pull it out from wall there is a tube that runs down to drip pan under neath also check door seal by closing door and sliding acard between seal and unit if loose or gap it will make unit sweat
Jul 13, 2012 | Frigidaire Refrigerators
GE Profile 21 cu ft. goes continuously except upon defrost, "once a day" for about 30 minutes. Unit cools both on freezer side and refrigerator side (ice cream ok and milk ok). Repairman...
open the doors and feel the middle strip.if that's hot check the condenser fan to make sure it's running and clean out the coil in the back.pull out the machine,remove the bottom panel,on the right side you'll see the coil,with a shop vac vac off the coil and then put it on blow and blow out the coil,that's the only way to clean this kind of coil and make sure the fan is blowing back there.let me know what you find,also send the full model number,open the fridge door,look at the right wall near the ceiling and you should see the model number.
Jan 23, 2011 | GE Profile Side-By-Side Refrigerator with...
The middle black strip on my GE refrigerator is burning hot. Model # GSL25JFPE BS. What is this and how do I fix it?
this is the wall between the freezer and the frg i think . it is warm when the compressor is running . and if hot / then look under neath unit and i thing you will fing the coils ar very dirty or the fan is not going or both . so clean coils every 3 to 4 times a year and repl fan if it has failed . and things will get better .. ,mm
Aug 17, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Our GE PTS25LHRBRWW refridgerator is running but it is slowing warming up to 50 degrees in both the freezer and the fridge. It seems to be blowing and running like usual.
ge has had alot of problems with the computer board that's in the back of the fridge.but first try this,open the freezer door,you should hear the fan blowing in there,if not you could have a bad evap fan motor,also touch the back wall of the freezer,if there's snow or ice on the back wall you have a defrost problem,you could have a bad heater or a defrost thermostat,also have you cleaned the coil on the bottom of the fridge?remove the bottom kick plate and vac it out,pull out the machine,remove the back bottom panel and vac that out,ashop vac works great for this vac out what you can and then blow out the coil and clean out any of the dust that you couldn't vac up.if the frame between the doors is hot that's one way of telling it's time to clean under there and when you have the back panel off make sure the fan is blowing back there.if everything looks good i would change the computer board,it costs around 150 to 200 hundred bucks.let me know what you find and if you need any more help let me know.
Jul 25, 2010 | GE Refrigerators
I have an amana arb2557csl top fridge that quit working today. yestarday was fine today hot. no noises that i am aware of. it is around 5 and 1/2 years old. can i fix it without paying a fortune? what...
you have a good brand . back to problem ck for ice on back wall of freezer if so you have a defrost problem and coil is blocked with ice . if no ice make sure the fan inside and down under neath are working and clean the coil. all of these will prevent the unit from cooling .. hope this helped mm
Jul 03, 2010 | Amana ARB2557CSR / ARB2557CSL Bottom...
My kenmore refrigerator is not cold
the coil under neath the unit may be dirty and need cleaning . . ck that both fan inside and under neath or working . and that your door seal are clean and in good condition . **** ..
Feb 23, 2010 | Refrigerators
NOT COOLING PROPERLY IN THE DOWN CHAMBER OF DOUBLE DOOR
remove bottom vent cover at front of fridge. just clips in place. look under neath and you should see a coil. its probaly caked with dust. use a shop vac or vaccum cleaner with small enough hose to insert under the fridge directly to the coil. remove all dust. dont use anythng sharp or pointed to clean coil, as coil can be punctured.
Jan 09, 2010 | Refrigerators
There is lots of dust under the refrigerator but I can't reach it to clean it. Does the bottom tray pull out to get at it?
The bottom tray on most units will pull out.
However I have found that there are some better ways to getthe dust and dirt out from under there.
A good shop vac with a crevice tool is a great way to get in there.
Another way that I have often cleaned under neath is to use an air compressor with an air nozzle at high pressure. You can blow everything clean and then vacum up the dirt.
It is very important to keep things clean so that your compressor stays cool and the coils have good air for heat transfer.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 05, 2009 | Amana ARSE66MB Side by Side Refrigerator
Amana botton freezer buzzing 10 sec, freezer not cooling
CHECK MICRO/ SW WIRES @ FREEZER INSIDE THE CABINET COULD BE LOSE
Aug 19, 2009 | Refrigerators
JCD2389GT
hi thanks for the question it would seem that the problem is with the drain hose, going to the drain pan very common problem with all fridges let the fridge thaw 24 hrs let the ice melt in the drain cavity clean after thawing make sure the hose is in the pan vac *** under neath & coils thanks the appliance doc
Jun 27, 2008 | Jenn-Air JCD2389G Side by Side...
Frigidaire FRT21H8 Top Freezer Refrigerator Logo
177 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
