Question about IBM ThinkPad T23 Notebook
IBM t20/t23 Hi - I have a T20 that went dead (bad mother board I'm told) last year, so I got a used T23. After a few months, it's screen started flickering, then finally went almost totally black (I can barely see the image of the desktop so I know the machine is running, just can't DO anything since it is too black). Can a non-expert (I'm tool handy, just not a laptop geek)take these things apart, then move parts (video?) from the dead T20 to make the 23 work again? How do I know what to move? Thanks... Bob
    Novelist:
    Scholar:
  • 104 Answers
Hey, Laptops are very fragile and sensitive components! If you feel that you are capable of task like this then godspeed! Something like that could be three things! 1.) Your screen inverter has gone bad! The inverter is the device that provide high voltage power to the lamps in your screen! 2.) The lamps in your screen are bad! These things are usually rated for like 50000 hours. 3.) It could be as simple as servicing the laptop(cleaning up the contacts and ensuring good connection) Laptops come in all shape and sizes, and worse some come with a thousand screws of different sizes! It should be relatively easy to take down but the hard part is putting it back together. I have this friend who, after he re-assembled a laptop, always has extra screws!! He says the laptop don't need em! LOL What i would suggest is moving the entire screen, that way you don't have to take it apart to get to the inverter( should be the only other device located in your screen aside from the actual LCD(the lamps are in the LCD) The models sound very similiar but not sure about them either, it the screen looks the same then you can change it! Practice taking down the t20 first then if it breaks you'll know how NOT to break the t23! lol I would always recommend getting a pro to handle something like this though, cause is very tedious you have to be real careful! Best of Luck! regards, babb
Posted on May 01, 2007
How do I remove the backup battery from my Thinkpad 2647 T23? I'm trying to remove the POP.
ThinkPad T23 2647
Manufacturer - IBM
Series - T Series
Subseries - ThinkPad T23
Machine Type - 2647
1) Remove ALL power. Remove the AC adapter (Charger), and Battery.
2) Battery removed, Battery Compartment facing you.
Look at the right inside edge. There is a small plastic cover inside the Battery Compartment.
Remove the one Philips head screw, then remove the cover.
Backup battery, CMOS battery, or RTC battery. SAME/same.
(Real Time Clock battery)
Also, here is the Service Manual,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-ibmlenovo
Drop down to the 8th line. (ThinkPad T20. T20 in blue)
Scroll over, and left-click right on - T23
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name, (T23), it may take up to 30 seconds, before the first page comes up.
Start on Page 66. Backup Battery is on Page 67.
OR,
In the Bookmarks menu to the left, click on -
1) The + sign to the left of -
ThinkPad T20, T21, T22, and T23 series.
2) The + sign to the left of -
Removing and replacing an FRU.
(Field Replaceable Unit)
3) Left-click right on - 1010 Battery Pack, and 1020 Backup Battery.
Nice to have when you are going to clean that puppy out.
(BUY, and wear an ESD wrist strap. Connect it's alligator clip to a good ground source.
Average price is around $3 to $6)
Also nice to have to upgrade the Processor, and a myriad of other things.
Regards,
joecoolvette
May 11, 2012 | IBM ThinkPad T23 2647 Notebook
How to turn on wifi
hi
the T42 does not have WiFi, instead it facilitates internet connection via 16 BIT & 32 Bit PCMCIA slot to install a WiFi card , in order to go on the internet.
The ThinkPad uses the following adapters: v 360, 365X, 380, 600: 16-Bit PCMCIA v T20, T22, T23: 32-Bit CardBus and MiniPCI v T23: 32-Bit CardBus and MiniPCI Daughter Card v T30: 32-Bit CardBus and LAN on Planar Board (LOB) v T4x: 32-Bit CardBus and LAN on Planar Board (LOB). 16- and 32-Bit PC Card adapters are configured during ThinkPad initialization. Network Interface Controller data rates are: v For Token Ring: 4/16 MBps v For Ethernet: 10 Mbps...........16 bit PCMCIA 10/100 Mbps.......32 bit CardBus 10/100 Mbps.......MiniPCI and Daughter Card 10/100 Mbps.......T3x and T40 LOB 10/100/1000 Mbps..T42 LOB The MiniPCI Ethernet adapter is accessed behind a removable plate located on the bottom of the ThinkPad directly above the Model/Type S/N sticker. For T20 and T22, the MiniPCI adapter may be an Ethernet/Modem combination card. The Daughter Card (T23) is secured with two screws and is located next to the MiniPCI modem adapter.
please go to this link to read the manual -- it will explain the features for this ThinkPad of various series T42 model-type .
http://www-01.ibm.com/support/docview.wss?uid=isg2ffa39ae31a2f590e85256ced00828893&aid=1
please rate my service
Nov 22, 2010 | IBM ThinkPad T42 Notebook
ThinkPad T23 white screen
1. your issue may be a bad hard, a damaged or loose flex cable to the LCD screen, a defective CPU (central processing unit, a cmos battery that needs replacement ( this is the battery that retains the information for the motherboard), a bad power supply regulator on the mother board.
2. this is just a few of the issue that have caused a white screen.
3. Laptops are mostly disposable and are usually good for 2to 3 years of service depending on the care taken.
Your friend probably thought he was helping by giving this to you to see if you could use it or part it out.
Not worth the work unless you are into PC repair or project work.
2.
Mar 03, 2010 | IBM ThinkPad T23 2647 Notebook
How do you dismantle a thinkpad?
though it at a wall NO lol, there are screws located on the bottom and back near hindges and under battery also under the keyboard, but start with bottom as there is one there that holds the keyboard on
Feb 12, 2010 | IBM ThinkPad T23 2647 Notebook
When computer is turned on screen stays black and fan races fast
If you put it in another T23, Windows will recognize the hardware change and ask you to re-activate Windows. Microsoft may or may not require you to pay for Windows again.
Mar 16, 2009 | IBM ThinkPad T23 Notebook
0175: bad crc1, stop post task, system bios shadowed
Go on tis forum and post your problem. There is also the Lenovo forum. I have a T23 and haven't seen this error before. These Forums are very good for information on your laptop.
http://forum.thinkpads.com/viewforum.php?f=28
http://forums.lenovo.com/lnv/board?board.id=T_Series_Thinkpads
Oct 02, 2008 | IBM ThinkPad T20 2647 Notebook
IBM ThinkPad T20 how to disassemble
Here is the link to the ftp: location for the maintenance manual:
ftp://ftp.software.ibm.com/pc/pccbbs/mobiles_pdf/62p9631.pdf
This applies to IBM ThinkPad T20, T21, T22, and T23 series machines.
Mar 08, 2008 | IBM ThinkPad T20 2647 Notebook
T20 Laptop will turn it self off
Failing or clogged fan fan is a good possibility. Fans are cheap on ebay for those and easy to install (2 screws underneath the laptop to remove the keyboard and 3 for the fan assembly itself. I would pull the keyboard and check for dust then replace the fan if that doesnt help.
Dissasembly guide for t20-t23 is online here:
http://www-307.ibm.com/pc/support/site.wss/MIGR-4UYM3F.html
Jan 10, 2008 | IBM ThinkPad T20 2647 Notebook
IBM ThinkPad T23 Notebook Logo
98 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
