Question about Panasonic PT-AE700U Multimedia Projector
I have a Panasonic AE 700E. The picture is not very sharp
Bulb has been replaced but picture still not as sharpas it was when we first got it.  Tried running DVD directly from projector to eliminate wiring problem but no difference with picture.
    Sergeant:
  • 319 Answers
Check the focus, or try to reset it back to factory specs in the menu.
Posted on Feb 27, 2009
Lg 700e monitor settings
the correct settings for LG 700E CRT Monitor. Sometimes, the settings ofthe monitor change automatically. Also, even after resetting the monitorsettings, sometimes, they remain same. So, I'll tell you the correct settingsfor LG 700E CRT monitor. Let's move to the main part.
So, Check the following settings.
ForBrightness and Contrast:
http://is.gd/dMBn9
For Position:
http://is.gd/dMBub
For Size:
http://is.gd/dMBBU
For Shape:
http://is.gd/dMBDC
http://is.gd/dMBGe
Oct 20, 2012 | Computers & Internet
I have a PT 56DLX25 Panasonic hd projection tv that has a dim picture and we just put in a new bulb
Have you tried to do a system reset after installing the new bulb? I'd also check all of the visual settings, now that you've replaced the bulb, the settings will be different. Good luck! Chris Chrisab123@live.com
Feb 28, 2012 | Sony Grand WEGA KDF-50WE655 50" Rear...
A brief history: fixya helped me change my bulb (been receiving a "replace bulb" message for awhile until my picture went black). The picture now is snow, not black which seems to me to indicate the bulb...
Since you do have sound but snow for picture is your TV 54J or 54U chassis the PT50DL54J chassis shows 4 tuners also Have you look for Leaky or Bad capacitors if they are puffed up on top they are Bad 2200uf 25v 1000uf 25v Look for bad capacitors on tuner Boards, and I have seen where they are on Power supply board that will affect Picture.
Dec 04, 2009 | Panasonic PT-50DL54 50" Rear Projection...
THE POWER LED (GREEN) IS BLINKING CONTINUOUSLY
LG 700E monitor's power LED blinking continueously and there is no display solutin ........
May 30, 2009 | LG Flatron F700B 17" CRT Monitor
After 20 minutes of use picture shuts down. (Sharp XR-10X)
use canned air and blow every bit of dust out of every vent and hole. if you want to, you can remove the top (6 screws on the bottom, and the 2 top screws on the back) and blow dust out that way. i could also be a power supply problem. from excessive heat, the capacitors on the ps dry up and don't work as they should, causing shutdown.
May 24, 2009 | Sharp XR-10X Multimedia Projector
Panasonic PT50LC14 Power issue
We have a PT-50LC14. We replaced the lamp 6 months ago with a TY-LA1000 bulb we bought from a company online (not directly from Panasonic) and it worked for 6 months. Then the TV started turning off on it's own...sometimes it would not come back on for an hour or so. We called the lamp company and we luckily had 1 day left on our 6 month warranty!! They sent us a replacement bulb and the TV would never power on. It would try to power up, but the bulb would never ignite. The power light would flash and then the lamp light would flash every 5 seconds. I had a friend that has the same type of TV and she ordered her bulb directly from Panasonic. I borrowed her lamp and it powered right up. We then called the online company and they sent us yet another replacement bulb, and I tried it today and it works. It seems like these TVs are very particular about the type of bulb used. Next time, we will be ordering ours directly from Panasonic and just paying the extra $100. We have been without our big screen for 2 very long months! I had called a local tv repair shop, called Panasonic directly, and read through countless internet forums, and I thought we were going to have to replace the ballast or get a ballast repair kit and start messing with the circuit board.
May 22, 2009 | Panasonic PT-50LC14 50" Rear Projection...
No picture
ballast is not striking the lamp and needs replacing
Jan 10, 2009 | Sharp XR-10X Multimedia Projector
No picture, only sharp, squeaky noise
I'm having the same exact problem with mine! I'm looking for a solution also. I opened up the back of the TV and blew out the dust. Then I checked all connections. I put it back together and plugged it in. Now it doesn't make the high-pitched squeeking sound, but I still don't get a picture. My guess is the picture bulb is burnt out. I'm trying to find one online and am planning to fix it myself - wish me luck!
Aug 15, 2006 | Panasonic CT-36D32 36" TV
Panasonic PT-AE700U Multimedia Projector Logo
240 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
