Question about Toshiba MW27FN1 27 in. TV/VCR/DVD Combo
Toshiba DVR16 STB combi won't record on DVD's.
I am using the usual discs CD-R and it just comes up with a message saying the disc cannot be recorded or played. Also when I press the eject button it just says open and then does not do anything. I just wondered if anyone knew how to do a factory reset on toshiba?
I had to use the product title below as mine wasn't listed
SOURCE: Toshiba DVR recorder incorrect disk message
You could try the factory initializing process I found on another webesite (AVS Forums): "Had this message pop up a few weeks ago. Tried the solutions in the manual, no go. Tried unplugging it for 7 days, no go. Called Toshiba customer service @1-800-631-3811, the tech told me: 1) turn on TV and set to receive your DVD signal 2) Turn on DVD player and remove any discs 3) put Dvd / VCR selector on DVD 4) at the same time, push channel selector button UP (^) along with the PLAY button 5) hold the buttons down until TV screen shows "Initializing" message, release buttons, let DVD player go thru it's reset cycle and shut down 6) turn DVD player on and watch your DVD movies now Works like a charm. Put this in your manual for the next time." My unit has not worked since December of last year, I only had it for one year and it conveniently stopped working right after the one year warranty. My unit was not functioning whatsoever past turning it on, but when I did the factory initialization I was able to operate my unit again....UNFORTUNATELY, it still does not read disks, I still get the "Incorrect Disk" message. I guess I could consider it progress. But still try it, it may work for you. My unit just seems to be fried beyond repair. If anyone has any suggestions on how to correct the incorrect disk problem, I would be greatly appreciative. I'm not ready to throw mine away yet!
Posted on Sep 08, 2007
SOURCE: Toshiba SD-3980
http://www.tacp.toshiba.com/tacpassets-images/notices/sd-3980_sd-k750.asp
read that
Posted on Mar 23, 2008
  • 4234 Answers
SOURCE: Toshiba TV Combo MW24FP1, DVD player doesn't work on some discs
This is a common problem for all combo units. The high voltage of the TV section attracts large amounts of particulate dust from the air and often it collects inside the DVD unit. The best way to deal with this is to clean the lens of the DVD unit u sing a cotton swab and alcohol. The store bought "cleaners" MAY work, but that is rare. These cleaners are nothing but small brushes embedded into a disc. They attempt to brush off hte dust. This rarely works. Open up the unit (if you feel comfortabel in doing so) to access the DVD section. Remove the top cover and carefully clean the lens. That should resolve the problem.
Dan
Posted on May 21, 2008
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}To reset the Toshiba D-VRX4 DVD/VHSrecorder you turn it on and press and hold the "channel up" and"play" button until you get a message that says, "initializingto factory settings.". When done the machine turns off automatically, and you turn it onagain. Every time mine has stopped working this has fixed it. This might work with yours as well.
Posted on Oct 05, 2008
  • 21 Answers
SOURCE: Timer VCR Recording for a Toshiba MV13M2 13 in. TV/VCR Combo
Hello, you can go to the toshiba web site and download the manual from there.
The other option is to go into the TV menu, and select the timer rec set selection and access it there and fill in the times for the program you want to recording and that should do it.
I hope tihs helps.
BWLY
Posted on Jan 23, 2009
Which dvd +r discs are compatible to record on toshiba dvr20?
You can use any DVD+R or DVD-R disk .
Your device is compatible with
  • CD-R
  • CD-RW
  • DVD-R
  • DVD-RW
  • DVD+R
  • DVD+RW
  • DVD Video
  • DVD VR (-R/-RW, +R/+RW)
Apr 24, 2014 | Toshiba Dvr20 Digital Dvd Recorder And Vcr...
Cd not reading
This happens sometime when the drop
down menu in the recording program is
not set correctly for the dvd recorder it
may be set for another recording device
or the dvd player. If this in not the case
try removelng the dvd recorder in device
manager and leting it reinstall
Nov 21, 2007 | Philips DVDR630VR DVD Recorder/VCR
What do + and _ signs mean on blank dvds
- RecordNow! can record only to the same disc type
it records from. For example, you can record a
DVD only to a DVD+R or DVD+RW disc, and you
can record a CD only to a CD-R or a CD-RW disc.
you were using DVD-R, so it won't work.
hope this helps
Jun 18, 2012 | Verbatim Blank DVDR Discs/DVD R Media -...
I just purchased new blank Maxell dvd-rw 4.7gb/2hrs. discs and they wouldn't initilize past 8% so I tried re-formatting the disc and now the machine won't recoginize the disc or any disc, even...
Get a CD/DVD laser lens cleaner - the kind with optical quality brushes sticking out of the bottom of the disk. Run this in the player/recorder a couple times. Should clear it up.
You can get them at Best Buy, Radio Shack, online, etc...
Jun 16, 2011 | Emerson EWR20V4 DVD Recorder/VCR
Says blank DVD-RW is not formatted, then formats -- then error
I have same TOSHIBA D-VR4XSU VCR/DVD RECORDER. According to the
manual, you (COULD) can use for recording: DVD-RAM, DVD-RW and DVD-R (see page 50). WRONG!!! I bought all 3 types of discs, but after few
weeks I got same experience you got now. Just type DVD-R works. The other
types were - wasted money and a lot of time trying to finalize the disc. I had to
throw all into the garbage. Try DVD-R and you should?? be O.K.
Dec 13, 2008 | Toshiba DR4 DVD Recorder
E-4 54040990 Cannot record on this disc
I had this problem with my Toshiba DVR16 recorder; I was unable to format new DVD-RW discs even though old ones worked fine.
Initially I thought the laser lens was dirty, but no amount of lens cleaning helped. Then I thought the rated disk speed must be to blame, since it was some 4x disks that first presented the problem. But then I tried 2x disks and the problem persisted. So some aspect of the manufacture of these disks must have changed in recent months.
Anyway, the solution I discovered was to perform an 'erase' operation on each disk using a program on my PC called ImgBurn. This is a free program, which can be downloaded from imgburn.com. Just select Tools > Drive > Erase > Quick. Once that's done (it only takes seconds), take the disk out of your PC and pop it in your DVD writer, whereupon it should start its own format routine.
This has worked for me on 3 different brands of disk (Sony, Memorex, Datawrite). Which is just as well, as I was on the verge of throwing the DVD recorder out of the window. Hope it works for you.
<Neil G.>
Sep 29, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
My dvd recorder no longer records
take your DVD player to a tech and your problem will be all over.good luck
May 17, 2007 | Funai FDRV90E DVD Recorder/VCR
Problems finalizing discs
Check to see if you are using 16x media.  If you are you need to get a firmware upgrade from Toshiba.  Contact their support number listed inside of the manual.  They will ship you a dvd to insert into the unit.
Nov 02, 2006 | Toshiba DR4 DVD Recorder
Toshiba MW27FN1 27 in. TV/VCR/DVD Combo Logo
101 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
