Question about Dell Inspiron 6400 Notebook
Hi. i am using Dell inspiron 6400. i have been using it for more than a year now. since yesterday i am experiencing a new kind of problem. my display was working fine untill yesterday. i have windows XP as well as ubuntu. in the boot menu, the option screes appears, for choosing ubuntu or windows. i normally use windows. but yeaterday, when the selection screen came on, the display went from black to reddish kind of colour, then pitch black. i immediately turned my laptop off. then later i restarted and the same thing kept happening. then as soon as i turned it on again, i reduced the brightness to the minimum level and the display remains. but with red as the main colour. all the black stuff on my laptop appears red with reduced brightness. i have managed to connect it to my tv with the tv out cable, but the display is not coming on again. please help.
  • smka_khalid Dec 31, 2008
    thankyou soo much. your answer really helped.
    Novelist:
  • 101 Answers
Sounds like you have a failing backlight. The flourescent tube at the bottom of the LCD that make the screen bright enough to see will change to a reddish tinge as it goes bad. Eventually the tube will not generate light at all and the screen will go black, but you can still see the image faintly if you use a flashlight at an angle to the LCD surface. You might also hear a faint buzzing sound, just like when an overhead flourescent goes bad.
Replacing the backlight is a tedious and difficult job. First the LCD panel has to be removed, and then it must be disassembled to get to the backlight. The tubes can be purchased on eBay but they are leaded glass and very thin, so they tend to break easily. There are two contact tips must be desoldered and then the two new ones soldered before the LCD panel can be reassembled and then put back into the upper half of laptop.
For a beginner, it is much easier to replace the entire panel with a new or known good used one. Best bet is to check your warranty first, otherwise a full LCD panel will cost at least $75 plus the labor to install.
As for the TV out, the preferred method is to hook an external by VGA cable to test the video card. You should get full picture with proper colors since the problem is in the laptop's display itself. The TV out jack requires drivers and a functioning XP to display.
Posted on Dec 30, 2008
Hello..i recently purchased a new dell battery GD761/KD476 for dell inspiron 6400. But the problem is that the computer doesn't recognize the battery and says that it is not gonna charge the battery. Does...
Hi
I think the battery you bought is not compartible with your pc notebook that is why you are experiencing such problem.All you need to do is to get to the store or outlrt where you got the battery and get it replaced for a compartible battery or better still you should go along with your system.
GOODLUCK
Jun 21, 2010 | Dell Inspiron 6400 Notebook
Need bluetooth drivers for dell inspiron 6400
Hi! You may click here for the bluetooth driver for your Dell Inspiron 6400. Please go to the network section and use the bluetooth module driver. Thanks for visiting FixYa.com!
May 20, 2010 | Dell Inspiron 6400 Notebook
Missing display adapter driver
Hi:
The best way to find the proper driver for your Dell Inspiron 6400 is to search the Dell support site , using your service tag, and not just the model. This way it should point you towards the driver that it was shipped with!
Mar 24, 2010 | Dell Inspiron 6400 Notebook
Dell inspiron 6400 faulty spacebar?
You need to have the keyboard replaced. If you can't get it fixed locally, contact me for shipping information, I fix these kinds of problems a lot.
Jan 05, 2010 | Dell Inspiron 6400 Notebook
I have a dell inspiron 6400 and im getting a black screen once the dell logo comes up and windows xp loads...I see no icons or nothing..just a black screen
it sounds like your display backlight has gone bad. If your handy you can get a new display. If you are really good you can replace the back light.
Nov 07, 2009 | Dell Inspiron 6400 Notebook
Dell inspiron password fault
Hi my inspiron 6400 cannot boot up after trying several time .I press switch on, then after 3 second it goes off again.Battery fully charge.
1)battery new
2)rep used mother board
3)rep touch pad
4)rep keyboard
I hope anyone that know this fault .Kindly help me with the issue.
Mar 08, 2009 | Dell Inspiron 6400 Notebook
Dell Inspiron 6400 PC Notebook-touchpad working erratically,help!
i cant figure out how to turn on the croll for my inspiron 6400 touch pad
Mar 05, 2009 | Dell Inspiron 6400 Notebook
No power
type DEL key at startup go in the Bios settings look if poweron is disabled and all related (dont change any if not known to u) otherwise tell me more about your inspiron : is it a new install os(any?)which kind?
Oct 21, 2008 | Dell (E210882) Motherboard
Networking with LAN
The most laptop now comming with recovery software loaded on one of their disk partition (generally D: drive). So it will help you to get back all sofware and driver as it was issued by company.
So you can use this utility to get back your OS and drivers.
If this is not the case with you. then you should go the dell website, navigate the drivers and downloads section and enter your service tag no (not model no.) and then it will give you all the supported drivers for you laptop. Download as per your requirement. And install them.
Thanks
iqbal_delphidev@yahoo.com
Mar 06, 2008 | Dell Inspiron 6400 Notebook
Laptop goes dark
You can refer to this document for display assembly. It looks like the display is going bad. By checking the seating of the display cable, you're isolating the fact that the cable is connected.
http://support.dell.com/support/edocs/systems/ins6400/en/sm/display.htm#wp1022270
Hope this helps :) Kindly leave a rating. Thanks..
Nov 27, 2007 | Dell Inspiron 6400 Notebook
Dell Inspiron 6400 Notebook Logo
122 people viewed this question
Alun Cox
