Question about ASUS PCI Express Graphic Card
P4p800-vm pci slot is not recognising the add on card ( TV tuner)
I m having p4p800-vm motherboard with p4 2.8Ghz cpu my pc is working absolutly fine but the add on card is not being recognised even the found new hardware window doesnt popup. in device manager also i dont find the added device. i tried it doing manually but still it is not working. my ram is of 512MB. kindly suggest me what to do is my motherboard pci slot dead?
    President:
  • 948 Answers
There is no PCI-E slot on this motherboard. It has an AGP 8x slot and 3 PCI slots, but no PCI-E. Therefore, even if you could manage to get the PCI-E card physically into the slot it will never work.
Here is a link to the manual - http://dlcdnet.asus.com/pub/ASUS/mb/sock478/p4p800-vm/e1338_p4p800-vm.pdf
Posted on Dec 31, 2008
How to install saa7134
Open your CPU casing then install your pci capture card to one of your motherboard PCI slot you can Find it just read the slots of your motherboard they have a label on it some times PCI slot of a motherboard support multiple PCI slots just connect it on one of that slot..After installing install the installation software CD which is included in the package.
Jul 07, 2011 | Philips SAA7130 TV Tuner/FM Radio/Video...
I have got zenith TV tuner card purchased along with zenith TV before 10 years back,which was suitable for window's-98 O.S. Now I am using windows-7 o.s. on which above tv tuner software is not being...
I know all driver of hardware PCI zenith TV tuner can work with windows 7 O.S. try first open your CPU then transfer to other PCI slot of your PC motherboard. then power on PC.
May 30, 2011 | Computers & Internet
Can I instal an agp video card to the motherboard p4bgl-vm?
Please check inside the computer case if the AGP slot is there, according to the user manual there is no AGP slot and so a AGP card has no connector on the mainboard to be connected to - No it can not be installed to this mainboard.
You can only use PCI Video cards if there is no AGP slot.
Jan 23, 2011 | ASUS P4BGL-VM Motherboard
I have a Intel X58so Board and Quadro FX 580 Graphics card,But i don't know,where can i find the serial port,
what is the need for serial port you have graphics card plug in PCI E fit in the slot and enjoy
Nov 15, 2010 | ASUS P4P800-VM Motherboard
PC not booting when AVERmedia TV tuner card is inserted
Techguru2009: Seems you might have a conflict with your I/O. You need to reset the bios either by loading defaults or just remove the CMOS battery for ten minutes. After start the computer without the pci card. If all is well, then shutdown. insert the card in a different slot on the motherboard. Power up and the bios should recognize the update. Hope this helps.
Jan 28, 2009 | Gateway GM5084 PC Desktop
ASUS M2NPV not recognising PCI E adaptor. any solution?
Install the drivers first before installing the card in the slot , then insert the card adapter until you know you have securley fitted in the slot ,
Jan 25, 2009 | ASUS M2NPV-VM Motherboard
PCI slot / TV tuner error
i am not an expert, but have lots of experience with my own media center. by moving the tuner card you changed the address of it which if the os does not recognize new hardware, it will not install the drivers for it. i believe you will have to use the device manager to reinstall the drivers for the tuner card. also will have to redo the setup for the tuner in media center. another problem with the softare change is you have to update the security components to be able to view certain channels.
you can find the best information for all these subjects at your computer manufacturers support website and of course microsoft for the security components. good luck, it should not be too difficult to solve your delemna with a little research and searching there.
Oct 07, 2008 | Sony VAIO VGC-RB42G PC Desktop
Installed GeForce 8500 GT PCI-E video card and pc will not turn on
If your mboard has a builtin video card you should configure that b4 u can use that add on card.
1. connect the add on card.
2. connect the monitor to the built in VGA.
3. start system and press "F2 or Delete" to go to bios setup.
4. on bios setup " refer to the manual on installing addon PCI express card".
you find it here: http://support.asus.com/download/download.aspx?SLanguage=en-us.
or enlosed in the board.
After configuring your system restart and unplug in the wall outlet and then connect the monitor in the add on card.
Hope you find in order.
Jan 18, 2008 | ASUS P5GD1-VM Motherboard
ASUS PCI Express Graphic Card Logo
253 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
