Question about Gateway MT3705 Notebook
Battery not charging
Battery will not charge my laptop will only work when plugged into the mains
  • Geekwanabe Jan 19, 2009
    MY laptop will not charge. according to the computer wizs at a local computer shop the amps are working but thereis not votage going to the batery. Anyone got any ideas how to solve this?
  • 50 Answers
Hi
Please refer the following links
http://support.gateway.com/support/Default.aspx
Notebook battery recall
http://www.gateway.com/battery/
Posted on Dec 30, 2008
    Sergeant:
  • 279 Answers
How old is the battery? If this laptop is a couple of years old, you may need a replacement, depending on how many recharge cycles have been done.
SAMSUNG LAPTOP PLUGGED IN NOT CHARGING
try removing the battery and just use the mains power. If the laptop works you may need a new battery. If it doesn't your charger is faulty.
Nov 26, 2012 | Samsung R580 Notebook
The battery on my c650 laptop has a charging problem
Your battery may not be securely in the laptop.
You may also need to purchase a new laptop battery.
I would go to ebay or amazon to find a decent priced laptop battery.
Aug 26, 2012 | Toshiba Computers & Internet
No turn on notbook compaq 1711t
Hello The mandatory requirements before you try anything else are the main battery must be installed, it must work correctly, and there must be nothing wrong with the AC adapter or it's connection to the laptop. -Your model is recent enough the main battery must be installed - it won't start up on the AC adapter alone. - The main battery must be capable of being charged up to at least a minimal capacity. - The main battery does not last forever. Typically it works as it should for a year or so then begins to deteriorate - by the second year it can't be charged to anywhere near it's rated capacity. It gets worse as time goes by. Older batteries often develop internal shorts that makes it impossible for them to produce the voltage they're supposed to produce (you can test for that with a volt meter), and they may get HOT when you attempt to charge them for a while, rather than a little warm, or they may never get warm at all. - If you haven't replaced it since the computer was new, this model is old enough the main battery should be replaced! There must be nothing wrong with the AC adapter or it's connection to the laptop - if there is, the main battery cannot be charged properly. A common thing people do when they unplug the AC adapter is to pull on the cord rather than the plug on the end of the cord as they are supposed to do. Doing that eventually damages the plug and/or the wiring near the plug, and over a longer period of time, doing that damages the jack in the laptop the plug plugs into. The jack in the laptop should move when you wiggle the plug in the jack. Most laptops have an led that lights up only when the AC adapter is plugged in, there's nothing wrong with the AC adapter or it's connection to the laptop, and the AC adapter is charging the battery. That led should come on at least briefly when you unplug the plug from the AC adapter, then plug it back into the laptop jack, even if the main battery is fully charged. The led should not blink on and off randomlyIwhen you wiggle the plug in the jack. If that led never comes on, there is something wrong with the AC adapter or it's connection to the laptop, or the main battery is shorted (check it's voltage). If that led never goes out even after a long time, the main battery is probably no good - replace the main battery. The plug on the AC adapter cord can be replaced, but if you damaged it by pulling on the cord you will probably continue to do that at least part of the time, so since a plug molded onto the cord stands up to abuse a lot longer than a replacement plug, it's often a better idea to replace the cord from the AC adapter to the laptop if it can be unplugged at the AC adapter (a laptop repair place may stock that), or if that can't be done or you can't find that part, replace the AC adapter. The jack on the laptop can usually be replaced but that requires taking apart the laptop and careful removal and replacement of the jack. A laptop repair place does that sort of thing frequently, and often have the more common jacks in stock, though they may have to order one. Hope this helps, if so do appreciate my effort by rating the solution Good Luck, Cmptrlink
Dec 31, 2010 | Compaq Presario 1711T Notebook
Y laptop will only work on mains power. When I put in the battery, laptop shuts down.
This is either a problem with the battery or the motherboard.
If you can find someone with a similar Toshiba you can try their battery in your laptop, if it works then it's obviously a problem with the battery itself and you'll need to order a new one.
If it doesn't work then it's a motherboard problem which can be pretty expensive to fix (hopefully you're still under warranty)
Aug 21, 2010 | Toshiba Computers & Internet
Laptop wont charge battery
its a comment fualt with laptops the micro switch that switches between charge and main power goes faulty on them, you could be acutally onto some thing here because ther eis alot of people with laptops that wont charge at all, and if they knew ur little sequence you got going on there maybe you could save their laptops been door stoppers.
Dec 01, 2009 | Dell Latitude D410 Notebook
The battery won't charge on acer aspire 3610. I replaced battery with a new one which arrived with 65% charge. I fitted it and laptop worked until no charge left. The charger is plugged into mains and...
check the output of the charger and see if it is charging if so the conector might be bad does the plug wiggle when it is plugged in? it should feel very solid
Nov 27, 2009 | Acer Aspire 3610 Notebook
Battery won't charge
a car battery? how eactly do you do that?
May 22, 2009 | HP Hewlett Packard Pavilion DV9500T 17"...
Charging Problems with FUJITSU SIEMENS AMILO PRO V2055
SOunds to me like the charge board inside the laptop has gone bad. If it will not run off of the mains supply without the battery and will not charge the battery, this is your problem. AS far as where you can get the parts or have it repaired. I am unsure of because I would need the full model and make of the laptop which didn't fit in the listing title bar above If you could send me more info, I would be glad to try to help.
Dec 30, 2008 | Computers & Internet
BATTERY is charged, but will not work without being plugged in
Your battery is old and worn out, even though it indicates as fully charged. The battery capacity is practically zero. Rechargeable batteries have a finite number of charge and discharge cycles.
You need to buy a new battery if you wish to use the laptop without connecting to the mains.
Dec 01, 2008 | HP Compaq Evo n610c Notebook
Battery wont work
The battery is dead and it won't charge or hold its charge (all rechargeable batteries have a finite number of charge and discharge cycles). You need to buy a new battery, or just use the laptop connected to the mains supply.
Oct 29, 2008 | HP Compaq Evo Notebook N600c
Gateway MT3705 Notebook Logo
94 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
