Question about NetGear DG834G Router
Two out of 3 computers not talking
My computer can access other two computers and ping everything ok.Number two computer cant ping itself or number 3 computer but can connect to my computer and internet.Number 3 is the same as number two accept it can ping itself but cant connect or ping number 2.In the router settings under attached devices number 2's network name doesnt show up and no matter how many times i run the wizard or check the firewall it doesnt show up could this be the problem? if so how do i fix it.
  • Tteresamark Dec 30, 2008
    my laptop will work mith my router my other 2 laptops can pick the router up but it will not let them connect to work wirelessly . they work well with the erthernet cable but want them wireless
    President:
  • 2,961 Answers
First make sure all pcs are on the same network name, usually either mshome or workgroup, to check this go to my computer>right click>properties then look at computer name tab, if any are different than the network you should be named as click change name, save and restart. Then go to each computers network adapters properties and go to the TCP/IP line nd click properties again and check that the cards are set to obtain ip address automatically and click ok, because if you hve used the wizard it would have changed your pc's ip addresses. Next go into your routers settings by typing it's ip address in your web browser (eg 192.168.1.1, depending on the router, refer to manual) and look in menu for DHCP and make sure this is enabled so as to automatically asign your pc's an ip address. If you are struggling for any of the pcs's to obtain an address, click Start>Run, then type ipconfig /flushdns to clear all ip and dns addresses.
Posted on May 01, 2007
SOURCE:
I cant open my ipod touch because of its pin number and now it says disabled and cant put into first computer it is broken
Ok, I'm not exactly sure what you mean by not being able to put it in to the first computer....but you should be able to plug it in to any computer with iTunes installed and when the ipod shows up in itunes, click the option that says to restore the ipod to its factory settings. This should erase the pin number and then you can reload you music and everything.
Mar 05, 2011 | Apple iPod touch
Wireless router was working now its not, now light showing wireless on the router, I have internet if i plug in derectly to the modem
Jus Powercycle the Whole N/w
Unplug Modem and Router
Plug Modem First and then Router
Check Wired Internet to Router if that Works, wireless will be Online
Oct 01, 2010 | Linksys Wireless-N WRT150N Router
Having problem internal network to connect outside but the router itself can ping the outside domain or public domain/IP. The Internal Network cannot ping the domain or cannot connect to the internet what...
1.Check whether there is ping to router from lan computers.
2. If there is no ping then check the cable b/w lan computers 7 router.
3.Else if there is ping to router, then check ur router for any ip blocks, access lists etc..
4. Turn - off the local firewall, so there also a chance of it blocking access to internet
Sep 27, 2010 | Cisco 881 Fast Ethernet Security Router
We ave lost our connection on our one computer to
Its sounds like it could be a number of problems. One problem may be that your computer's IP Address may have become invalid (expired, or other reasons). One way to fix this is to go to command prompt on your computer, and use the commands "ipconfig /release", and then "ipconfig /renew". After that, use the ping command to test connectivity. To do this, type in ping, and then your router's address (i.e. ping 192.168.1.1). If you get replies from your router's IP, then your connection is working. If you get a reply from an IP starting with 169, then your networks settings are probably incorrect. If your request times out 4 times, then you have other issues. In the case that your requests time out 4 times, try "ping 127.0.0.1". If this ping does not work, then you need to replace your NIC card.
If you still need help after performing these steps, or if you just have questions about the information in this solution, please feel free to contact me.
Feb 24, 2010 | Linksys Wireless-G WAP54G 802.11g/b...
Well i have a dell latitude d600 and i can get the wifi connection on my computer but cant connect to the internet whats going on
if u know the IP address of your router and ur servicve provider's server IP then ping it....
go to Start/Run
in the next window type this
ping 198.168.1.1 -t (the number is the IP address of ur router...replace the number written by me with ur router number)
ping 59.179.243.70 -t (the number here is the IP address of internet service provider server...replace the number written by me with one for your internet service provider server IP address)
the ping window will be a DOS window with responce from the respective server/router with milli seconds mentioned as responce time....if that comes then ur connection is ok
for further info check with ur internet provider
Feb 18, 2010 | Dell Inspiron 1501 Notebook
Uplink internet (PPPoE) will not be accessible after power cut
You are using the PPPOE connection. when you set up the router for the PPPOE connection, Do you see Internet IP address on the status page of the router.
If you have the internet IP address on the status page of the router then that is a very good thing. make sure that it shows the Internet connection type pppoe on the status page also.
your computer are communicating with each other they have the IP address that is a good thing also.
Now you can check the internet connection.
open the command prompt ( START ==> RUN == type cmd and click OK) In the command prompt try to ping the router IP address.
Suppose your router IP address is 192.168.1.1. then in the command prompt type " ping 192.168.1.1 " and hit ENTER on your key board.
You will get replies from the same IP address that is 192.168.1.1.
that means the connection between the computer and the router is working properly.
Now type in the command " ping 4.2.2.2 " and hit enter.
If you get the 4 replies from 4.2.2.2 that means you computer is communicating with the DNS servers. If you get the reply form different number or if you do not get replies that means the router is not set up properly or user name and password for the pppoe might not be proper.
Now you got 4 replies from 4.2.2.2.
Then type the command " ping yahoo.com" and hit enter.
Now check if you get replies from yahoo.com ( there might be replies from the number 66.x.x.x. or 207.x.x.x).
If you get the replies then everything is working properly. the issue might be with the firewall or internet browser.
Now if you don't get replies from yahoo.com but getting replies from 4.2.2.2 that means you will need to assign static DNS numbers on the computer.
In preferred DNS = 4.2.2.2
in alternate DNS = 4.2.2.3
that will resolve the issue.
Click Here for more info about the networking
Oct 06, 2009 | Linksys Wireless-G WRT54G Router
Cant ping on a same network
the information you give sounds like your trying to set up a network, if this is the case you will need to set up the network in the netwok program on your computer....icon found in control pannel or on start menu ....shia
May 22, 2009 | Intel Computers & Internet
I cant get onto internet explorer it says dns error can you help?
Check out your internet connection and its settings, whether it is dial up or broadband oriented.
then you have to know about your ip address of dns server in the network setting places.
you just ping the ip address of dns server following as...
go to start, then run and type "cmd", and it shows the command prompt. type as following format.
ping 10.10.10.5 and press enter key.. this is the sample ip address only. if it gets reply, your dns server is ok. you can use internet. suppose, it wont comes, ask your service provider or support for another or different ip address of dns to check it out.
Jul 21, 2008 | Computers & Internet
High Ping When playing Battlefield 2142 Online
There are a lot of factors that can affect ping rates. Server location, server load, local internet load, and your computer and network setup. The server you access for Battlefield may be too far from you. Try typing "ping 69.147.114.210", at the command prompt,(usually found in "All Programs/Accessories") also without the quotes. You should get numbers in the 40-60ms range. (thats Yahoo.com by the way), then put in the IP number of the Battlefield server. Any returned numbers under 100ms are ok, if your getting higher numbers, check the Battlefield forums to see if there is a server closer to where your located. If your getting numbers over 250-300ms at both sites, then download Lavasofts Adaware SE which is free, and Spybot Search & Destroy, also free and run them both, (once a week after as well) they will remove spyware and adware from your computer. There is a possibility that spyware or adware is using network resources.
Aug 11, 2007 | ASUS V8420/TD Graphic Card
How to test Connections with Ping
Ping is one of the first tools to use to check computer, router and Internet connectivity. It's run at a command prompt, but getting the basic information is quite easy. You can do the whole thing in 30 seconds. 1. To run ping, type Start > Run. 2. Type cmd in the Run window, and click OK. A black and white command line window pops up. 3. Type ping followed by an IP address or a DNS address. 4. Press Enter to execute the command. Three useful examples: 1. ping 127.0.0.1 (This is a "loopback ping" ? your computer trying to talk to itself. This tests whether your computer is able to handle Ethernet traffic. If this has a negative result, the computer has an operating system problem.) 2. ping 192.168.1.1 (If the result is "Request timed out", type ping 192.168.0.1. If that also times out, then the computer is not making a connection to your router.) 3. ping www.netgear.com. (Tests whether your computer can contact Internet computers.) When there is no problem, the ping results look as shown in the following screenshot. Three items of interest in the results are highlighted with arrows. The first arrow shows the computer being contacted is replying. (The DNS address "www.netgear.com" is converted by ping into the equivalent IP address, 10.1.1.86.) This shows both that your network is connnected to the Internet, and that that computer on the Internet is running normally. www.netgear.com is always running, so this is a good test address to use. The second arrow shows that Ethernet packets have "0% loss". This is the best possible result. It means that the network connection is lightly loaded, and that it has not been necessary to transmit any of the same information twice. The third arrow shows the average time it took to answer. "Average = 0ms" is the best possible result. Probably you'll only get responses this quickly from computers on your own network. Interpreting Ping when There's a Problem As far as NETGEAR equipment, the problem you're most likely to run into is "Request Timed Out". This means there is no connection. Read these posts: http://www.fixya.com/ThreadView.aspx?prdid=252225&thid=102077 and http://www.fixya.com/ThreadView.aspx?prdid=252225&thid=102074 Another error is "Unknown host", which just means that the DNS or IP address you typed doesn't exist. Probably, you made a typo. Other problems are generally outside the scope of NETGEAR support. Often they are problems with your ISP ? contact them with concerns. A controversial situation is when packet loss is not 0%. Sometimes this indicates a severe problem, but in other situations it doesn't indicate any problem whatever. However anything higher than 5% is definitely a problem. If the average round trip time is > 500 ms, there' s possible latency problem. Again, contact your ISP. Limitations of the Ping Tool * Ping is not a good tool for diagnosing intermittent problems. * Good results are reliable, but ?bad results? could be caused by any number of things, and are not necessarily reliable! * Ping uses ICMP, which has low priority, showing speeds that are slower than regular network traffic. Some computers reject ICMP, and therefore pinging, entirely. * When an IP appears between the source and destination in a traceroute command it does *not* mean that that IP must be pingable.
Feb 19, 2006 | NetGear CG814M Wireless Cable Modem...
NetGear DG834G Router Logo
90 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
